Question about Samsung DV331AEW Dryer
Where is the thermal shut off fuse located and what does it look like. DV331AEW/Xaa
  • 398 Answers
The thermal fuse is located on the blower housing. You should check out this link to www.repairclinic.com
for a lot more info on this and other possible items that could cause no heat. The link is; http://www.repairclinic.com/Shop-For-Parts/a8b160c44d1067187/Model-DV331AEW-Samsung-Dryer-Fuse-Thermal-Fuse-Breaker-Parts
Good Luck!
Rich Lilja
Posted on Dec 04, 2014
My Samsung DV488AEW/XAA Dryer keeps blowing the thermal fuse. It has good airflow; there's no lint buildup. I've replaced the fuse 4 times now and also the thermal cutoff and the heating element. Help
Check the airflow if it is restricted at the output, you need to have the vents cleaned. The airflow is backing up and causing overheating inside the unit.
Oct 15, 2015 | Samsung Dryers
Samsung dv331aew/xaa check filta
You can still operate it while it is drying.There is a bad sensor much like an O2 sensor on a car.
Jan 24, 2015 | Samsung Dryers
Error codes for DV209AGW/XAA
either a bad door switch a bad thermal shut off fuse or a bad push start switch check all with a multi meter
Aug 27, 2014 | Samsung Dryers
Dryer heats for maybe 1 minute then stops. Samsung Model DV328AGW/XAA
In the rear of the dryer is a thermal limiter which will kick in when the exhaust temp is too high and can cause a fire. One link will show what the limiter looks like and the other will show how to commonly get to the limiter. Your mileage may vary.
Samsung Dryer Model DV328AGW XAA Fuse Thermal Fuse Breaker Parts Take Apart Samsung Dryer Samsung Dryer Repair Help
Jul 30, 2014 | Dryers
Samsung DV331AEW Dryers, Why My Dry it does not have heat?
Did you install the unit? Has the heat ever worked?
May 27, 2014 | Samsung DV331AEW Dryer
DV350AGW/XAA will power on, but does nothing when you push start
i have a bsch was3274 does the same turns on here the relays click 2 or 3 times and water dosent start going in to the machine
Feb 14, 2014 | Samsung DV331AEW Dryer
Drum will not spin.
first disconnect your cord from the dryer, and ohm out the cord. place your test leads to each end of each of the wires. you could have a bad cord. one side of the cord could still give 110 to your board. check to see if the broken belt switch is tripped. if all this checks out, then should be your relay board. the one above the drum.
Dec 16, 2013 | Samsung DV331AEW Dryer
I have a Samsung DV331AEW/XAA dryer that will not run. i have 240V L-L at the plug. the LCD works as normal, meaning it thinks it is drying clothes. the child lock is not on. the dryer is empty. it...
2 things possible here the belt broke or the thermostat by the thermister opened both scenarios will cause your problem if its the 2nd problem, clean the vent and the drier. inside and out
Sep 03, 2013 | Samsung DV331AEW Dryer
Samsung DV331AEW Dryer Logo
239 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
