Question about Kitchen Ranges
Cata chimney cooker hood just stopped working in the middle of cooking whag could the problem be
Haven't tried anything cos haven't a clue what to do
SOURCE: cooker hood not working
Check power from the wall.
Check power in the wiring coming into the hood.
Check to see wiring is not broken.
Posted on Feb 18, 2008
  • 171 Answers
SOURCE: internal cooker hood
Hi judav,
I'm Harvey the Master Plumber.
Your problem is: You live in a flat with no chimney and you would like to install a cooker hood. how do you do this please?
Is there living space above? If so you can't go straight up. If your range is on an outside wall, it can be piped out the back. If only attic or roof above, no problem. Just pipe it straight up useing B-vent pipe or equivlent. If you can't do any of this just get a hood that vents filtered air back into the room.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Oct 14, 2008
  • 142 Answers
SOURCE: CDA CPX9 COOKER HOOD - how to remove chimney/disconnect power
remove filters, inside there will be mounting screws, support the unit prior to removing screws. there might be ducting inside clamped on, and a power plug(hopefully) to disconnect.
Posted on Jan 27, 2009
heavyt15
  • 91 Answers
SOURCE: designair 60cm chimney hood chk60ss what gap
If gas cooker you have to get specs.....We usually get the chef of the house to stand in front...Head banging will be a call back we hate...
Posted on Nov 04, 2009
  • 8404 Answers
SOURCE: Problem with cooker hood
Filters clean? Fan running? No clogs in the exhaust?
On the one hand, you want the disagreeable stuff out of the kitchen - on the other hand, you want to keep your heated or cooled home air to stay inside.
Posted on Mar 09, 2010
Stop working at the middle of cooking
do not believe rice cookers are made to simmer chickens in .
Aug 07, 2015 | Kitchen Appliances - Others
The chimney can extend to just over 1000 mm, can you buy additional ducting to further extend?
needs to be a gap of just 1 meter from the top of the cooker to the hood any lower and you will hit your head or it will suck out the heat has you cook taking longer to cook
Mar 30, 2015 | Kitchen Ranges
My rangemaster cooker hoos has just stopped working.. no fan working and no light coming on ??
The same happened to me. I found a 3-amp fuse which I changed, and now it's ok.
I removed the chimney casing and located the electrical connection into the wall. You'll find a fuse unit within the switch which swings out.
Hope this helps.
Dec 20, 2010 | Rangemaster Kitchen Hood
Designair 60cm chimney hood chk60ss what gap between cooker and hood ?
Oct 27, 2009 | Kitchen Ranges
What is the height of britannia omaggio 90 cooker hood?
Here are the dimensions that relate to your cooker hood. The measurements are in mm.
Width 980 front 578 rear
Depth 480
Minimum height 1015
Maximum height 1170
Main canopy height 750
(excl chimney)
Chimney section width 436 main body/340 sliding section
Chimney section depth 170
Mounting height 650 - 750
Regards
Alan Hood
ami-man
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Jun 16, 2009 | Kitchen Ranges
Jan 26, 2009 | CDA Kitchen Ranges
Internal cooker hood
Hi judav,
Thank you,
Oct 03, 2008 | Kitchen Ranges
Rice cooker stopped working after one month's use
You probably should bring it to a service center. since youve mention a span of time not using your cooker, the thermal capacitor may be busted.
hope this helps.
Nov 12, 2007 | Panasonic SR-SH15PS 8-Cup Rice Cooker
Rangemaster cooker hood. model no.LEIHDC120SC/
hood should be connected to a fused spur outlet which you havent found. try removing the chimney and you may find it there. chimney only held by 2 screws at top usually.the fuse in the outlet sometimes goes when bulbs blow
May 31, 2007 | Rangemaster Broan 614804 BALLISTA 48IN...
Kitchen Ranges Logo
67 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
