Question about Thule 2000 Ford Escort - Sedan - Base Rack System
One headlight dose not work bulb replaced still nothing
New bulb checked connector
    Master:
  • 519 Answers
Probable multi-function switch.
Posted on Dec 04, 2014
Right front side turn signal does not work replaced all bulbs and checked fuses headlight flashers work when hazards are on front to back except driverside turn signal ,in dash right stays solid left
I don't believe it would be a bad ground for just one light. It could be a wire, a socket connector, or the bulb socket itself. See if the wire has power at the socket when signaling left, with key on. If there is power, probably a bad socket or connector. If no power, check for power coming from flasher-the wire going to front left, or driver's side. If you have power from the flasher, but nothing at the socket, the wire has probably broken.
Good luck.
Feb 06, 2013 | Cars & Trucks
Rf highbeam doesnt work,after new bulb install 02 monteSS
Check for 12VDC at the connector with your high beams on. Could be the wiring or the connector and no they run on the same fuse.
Dec 30, 2012 | Cars & Trucks
Removing low beam bulb on 05 subaruoutback
Whether they become damaged in an accident or simply burn out over time, your Subaru Outback's headlights may eventually need to be replaced. Fortunately, once you've purchased the right replacement bulb for your model year, performing the repair yourself is relatively easy. These instructions only apply to Outback models made after 2000.
  1. Undo the clips on the air intake ducts using a screwdriver and remove the duct from the engine compartment (driver's side bulb removal only.)
  2. 2
    Loosen the secured clip on the washer tank with a screwdriver and slide the tank horizontally to allow easier access to the headlight assembly (passenger's side bulb removal only.)
  3. 3
    Turn the bulb cover counterclockwise and remove it from the assembly.
  4. 4
    Disconnect the headlight electrical connector and undo the assembly retaining spring.
  5. 5
    Pull the old bulb directly out of the socket and replace it with the new one. Press the retaining spring back into place and reattach the electrical connector.
  6. 6
    Replace the bulb cover, and then turn on the engine. Test the new headlight to make sure it works before replacing the air intake duct or the washer tank and closing the hood.
    Replacing the High-Beam Bulbs
  1. 1
    Undo the clips on the air intake ducts using a screwdriver and remove the duct from the engine compartment ( drivers side bulb removal only.)
  2. 2
  3. 3
  4. 4
    Turn the headlight bulb counterclockwise and pull it out of the socket.
  5. 5
    Reinstall the new bulb, replace the retaining spring and reconnect the electrical connector.
  6. 6
Sep 14, 2012 | Cars & Trucks
How do I replace the headlight bulb in my chevy malibu?
Open the hood. There is an electrical connector going to the headlight bucket assembly. Turn the connector counterclockwise and pull gently. The bulb is attached to the connector. Pull the bulb out of the socket and replace with new bulb. Be careful not to handle new bulb with greasy fingers or hands if bulb gets soiled wipe down with alcohol. Halogen bulbs burn very hot oil from your skin will shorten the life of the headlight bulb
Apr 08, 2011 | Chevrolet Malibu Cars & Trucks
The left front low beam headlight does not come on. have replaced the bulb, but only hi beam works.
Since you've eliminated the headlight itself as the source of the malfunction, the problem is most likely the headlight bulb connector - the female connection inside the connector to the hi beam is good, but the connector supplying power to the low beam is bad. Your fix is to replace the headlight connector.
How: buy a replacement headlight connector at your favorite auto parts store, cut off the old connector, then (a) solder and heat-shrink or (b) wire nut and E-tape, or (c) crimp connector the new headlight connector onto the existing wiring (being careful to route the conductors to the correct wires on the connector).
Your cost: about $3 for a new connector
Feb 14, 2011 | 2003 Pontiac Grand Am
How to install a headlight
Locate the headlight bulb in the engine compartment, in the rear of the headlight assembly. It has a wiring harness connector attached to it.
Remove the wiring harness connector from the bulb. Release the locking tab on the connector and pull it off the bulb. Lay it aside
Locate the locking ring on the back of the headlight assembly. Turn the lock ring 1/8 of a turn counterclockwise to release the lock from the headlight assembly. Remove the lock ring and set it in a safe place.Remove the headlight bulb from the headlight assembly, pulling it straight back toward the engine. Discard the old bulb, unless you are reusing the bulbs in the Jeep.Insert a new bulb into the headlight assembly. (Be careful not to touch the glass when handling the bulb. The oils from your hands can cause it to overheat and shatter.)Install the headlight lock ring onto the headlight assembly and turn it clockwise 1/8 of a turn to lock the bulb into the assembly. Connect the wiring harness connector to the new bulb, ensuring that it seats completely on the bulb.Move to the opposite headlight and repeat the process to replace the second bulb. Turn on the lights to verify they are working correctly.
Jan 13, 2011 | 1993 Jeep Cherokee Country
How to replace toyota matrix front headlight bulb
Replacing a headlight on a Toyota Matrix is a simple process that only requires the use of a screwdriver and a replacement bulb. The Matrix uses 9006 bulbs for the low beams and 9005 bulbs for the high beams. Headlight bulbs can be purchased at auto parts stores.
Replacing Low Beam Bulb
  1. Turn off the engine of the Matrix and open the hood
  2. Rotate the bulb base in the headlamp assembly counterclockwise to remove the low beam bulb. Unplug the electrical connector. If the connector is too tight, wiggle it slightly to help remove it.
  3. Install a new bulb into the connector and place it into the assembly. Rotate it clockwise to lock it into place. Close the hood.
Replacing High Beam Bulb
  1. Turn off the engine of the Matrix and open the hood. If replacing the left-hand headlight, remove the air cleaner duct by removing the securing clip with a screwdriver and pulling the duct out of the vehicle.
  2. Turn the bulb base counterclockwise to remove it. Unplug the electrical connector.
  3. Install a new bulb into the connector and place the bulb into the assembly. Rotate it clockwise to lock it into place. Reattach the air cleaner duct if replacing the left-hand headlight. Close the hood
I hope this helps.
Best regards.
Oct 29, 2010 | 2005 Toyota Matrix
Passenger headlamp out. nothing fixes it. bulb is not bad/
Get a meter to the headlight harness connector, to see if you have power and ground there.
Sep 21, 2009 | 2003 Dodge Durango
Headlight not working...bulb and fuse are good
check fuses first... if ok, buy an electrical tester from walmart for $5 and see if it's getting any electrical to the headlight.. if it is.. replace bulb
It's at least a good starting point.
Aug 30, 2009 | 1992 kawasaki VN 750 Vulcan
Thule 2000 Ford Escort - Sedan - Base Rack System Logo
845 people viewed this question
Top Thule Wine & Spirits Experts
Don Hart
Dave braun
Dave braun
guymark
Level 1 Expert
Are you a Thule Wine and Spirit Expert? Answer questions, earn points and help others
