Question about Locks & Locksmithing
Electronic lock works the opposite way how do I reverse this
  • 720 Answers
If it's on an airline reverse input/output, if it's electric you might have the polarities the wrong way round.you could try swapping connectors.This is not without risk.you may damage circuitry doing this.
Posted on Dec 03, 2014
Is it possible to recharge butteries that are not rechargeable by they original design
no
the problem is that non rechargeable batteries are alkaline and they produce the power by an interaction of chemicals that will not reverse the action under charge
They will overheat and explode
as against rechargeable batteries that generate the power by differences in electron molecular construction and charging puts the electrons back on the opposite plate in the comstruction
Nov 04, 2017 | Cameras
Cannot get blade off my worx easy cut saw
Try turning the nut the opposite way. It's possible the saw has reverse threads.
Aug 18, 2014 | Saws
The T-turn is reversed
I my mind the actual lock bolt was assembled wrong. You need to gently twist the length adjusting unit /bolt directly out of its housing and then gentle separate the two pieces though fully separating them and then "flip" the actual little toggling metal piece that has the "U shaped and half circle looking hub that the lock shaft slides into, around from it currently position ... ie. reversing its throw. You may need to also adjust the spring metal piece underneath it as it run in a slot as well.
This worked for me ... when t-turn key is horizontal the dead bolt is extended ie. in locked position.
Apr 27, 2013 | Weiser Lock ED1460X3VKD Powerbolt 1000...
We have a garrison keyless entry deadbolt lock with remote entry. when we press the unlock on remote it locks and when we press the loke button it unlocks. If we press the onlock button on keypad it u
If you remove the inside housing from the door, and look inside on the left hand side of the circuit board, you will find a slot marked "L R".
Slide the switch to the opposite of what it is set for. This will solve the problem.
Jan 14, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
Jammed in Auto, but works fine in reverse. How to unjam?
Continue to alternate between auto and reverse a number of times. Try to shred narrower pieces of paper at opposite ends to see if it can trigger the auto trigger wire. All else fails, carefully take the shredding part apart and you may find a hugh paper jam underneath.
Sep 02, 2010 | Aurora Electronics AS662C Shredder
Brought new keyless dead bolt. Put it in a door that opens in with hinges on right side. The problem is that the motor wants to turn the dead bolt the opposite direction, unlock extends deadbolt,...
My lock adjusted itself automatically... You have to hold the lock button in (on the exterior side) while you insert the battery pack - the deadbolt will cycle in and out, then beep a couple times. You'll be holding button for maybe 10 seconds.
I have to say while this step is included in the instructions in a big red box, it says nothing about why or what its doing, so I imagine many people miss this...
Aug 25, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
Somehow the lock thinks that when the door is locked it is open, and when it is open, it thinks that it is closed. Did I somehow put the lock on in some reverse order? Or can I somehow program the lock...
Take the lock back off and flip the back portion of the lock so the locking lever is reversed you have that on backwards. If that doesn't work reset the lock back to factory settings and reprogram the lock!
Aug 11, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
Testing Simrad Autopilot RPU160 Reversible Pump (21118237)
yes, hook it to 12V it runs, reverse wires it runs opposite it will spit oil, watch out! shoulda coulda left it in place and tested with jumper cables or battery if pump is bad 1 find out why your boat eats pumps 2. call me, i have it in stock for less than you paid before (most likely) 3. you can replace the electric motor without disturbing the hydraulics!!!
847-746-0100
Sep 13, 2009 | Simrad Rpu160 Reversible Pump 21118237
Goodman heater will not start have continuous blinking light replaced secondary transformer still no work and continusous blinking verified 120 volts to vent fan but vent fan not running vent fan ohms to...
I cant be sure but usually the constant blink on some boards means reversed polarity. Check your HOT (L1 - Black) comming in to the connector box and the your NUTURAL (L3 - White) should not read any volts to ground (not more than 12 volts on an electronic VOM). If this is opposite remove power and reverse black and white wires and retry.
HOPE THIS HELPS PLEASE GRADE ME ACCORDINGLY and GOOD LUCK!
Mar 03, 2009 | Goodman GMS90703BXA Heater
Photo card
there is a lock on the top corner of the card......slide the lock to the opposite direction and it will work fine.
May 30, 2008 | HP PSC 2210 All-In-One InkJet Printer
Locks & Locksmithing Logo
71 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
