Archos 10 10.2-Inch Netbook Cube Carrying Case - Red (894581545674) Logo
E
Ella Posted on Dec 03, 2014
How do I switch off the scroll Lock on my Archos 10 Netbook ??
It keeps coming up at the bottom, saying scroll lock!!
aamir shahzad
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 25 Answers
  • Posted on Sep 05, 2015
aamir shahzad
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
25
Questions
0
Helped
7800
Points
79
Scroll lock + ?
Try scroll lock plus the number of the switch you want to move to, for example scroll lock + 1, etc.
Kwikset Smartcode electronic lever, # 911LL Auto Lock feature keeps relocking every 30 seconds! How do we fix?
Here's a link to the Quick Installation Guide for your lock:
http://s7d5.scene7.com/is/content/BDHHI/smartcode-lever
When you scroll to the bottom of this page, it illustrates the four-switch slide switch internal to the lock. Switch 2 controls the 30-second auto-lock feature, so slide the second switch to the other position.
Pages and e-mails scroll down when I hit the space bar. How do I keep this from happening.
You have the scroll lock switched on. On the top right of your keyboard there is a scroll lock button. Usually next to the print screen button. hit the scroll lock button once. That should cure it.
Forgot my Archos 5 device lock code. How do I reset?
Call the number on your warranty information sheet. If you don't have it's 1877 300 8879. The weird number that it gives you when you say you forgot your password is your product key. If you want to contact online that's very important for registration.
2helpful
My archos is showing recovery code 101
It is indicating that there is a hard drive fault. Here is another users suggested method to clear the fault.
Following some extensive use I switched it on one day to find that it hung on the Archos home screen and kept going in a loop. Luckily I could see the red HDD light flickering so knew that the Archos was trying to do something and that the HDD was recoverable. When I entered into the recovery mode I found that I had an recovery code (101) which indicates a HDD fault.
I used the following steps to recover the HDD:-
1. Connect the archos to the PC using the USB cable (the unit will start but will need to be shut down again by pressing the power button)
2. Press the power button and the 'lock' button together for a few seconds and you should get a basic recovery screen
3. Scroll down to repair disk and select
4. Click on done and wait for a few seconds and you will see the archos as a drive in 'My Computer' (Note that this does take a few minutes)
5. You now need to back up your data, movies, music, widgets etc as the next step is to format the Archos HDD which will wipe it all.
6. Disconnect the Archos, turn it off and then turn it back on again by pressing the power and 'lock' buttons together.
7. Scroll down to format disk and select. The Archos will now delete all files on the HDD and you will get a message asking to connect to a PC and install the update file. This is the firmware file that can be obtained from the Archos website. You'll also notice that the recovery code has changed from 101 to 108
8. Connect the Archos to the PC, wait for a few seconds and you will see the archos as a drive in 'My Computer' again.
9. Drag the firmware update file from your PC where you've downloaded it to directly on to the root drive
10. Click 'done' on the Archos and it will begin to update the operating system.
11. Once this is complete then there should be an update successful message, select done and the archos should restart giving you the nice bubble screen and asking if you want to enable USB.
12. Note that the Archos is now in a 'factory built' condition so you'll need to adjust settings etc according to your preferences.
13. You can now start the long process of transferring your files back to the Archos.
2answers
Driver
you don't need a driver. to switch pc, use keystrokes below.
' Scroll Lock / Scroll Lock / 1 or 2'
'1 or 2' being the pc location on the switch.
hope this helps.
1helpful
6answers
Two port kvm belkin
Switch to the First PC [Scroll Lock] [Scroll Lock] [1]
Switch to the Second PC [Scroll Lock] [Scroll Lock] [2]
Previous Active Port [Scroll Lock] [Scroll Lock] [Up Arrow]
Next Active Port [Scroll Lock] [Scroll Lock] [Down Arrow]
Switch Audio to the First PC [Scroll Lock] [Scroll Lock] [F1]
Switch Audio to the Second PC [Scroll Lock] [Scroll Lock] [F2]
AutoScan Mode [Scroll Lock] [Scroll Lock] [0]
Change All to the First PC [Scroll Lock] [Scroll Lock] [A] [1]
Change All to the Second PC [Scroll Lock] [Scroll Lock] [A] [2]
Other information:
In AutoScan mode, the switch remains on one port for 10 seconds before switching to the next. This time interval cannot be changed. To exit autoscan mode press [Spacebar].
When in AutoScan mode, no mouse or keyboard controls. If the user moves the mouse or uses the keyboard while switching the connection between computer and the switch might be interrupted and cause erratic mouse movement and errant display when using the keyboard.
Maximum resolution supported is 2048 x 1536 @ 75Hz.
If mouse movement is erratic:
make sure you do not have more than one mosue driver installed. Make sure that the driver is either for a standar PS/2 mouse or a Microsoft compatible PS/2 mouse. Make sure you do not have any mouse drivers loaded in your CONFIG.SYS or AUTOEXEC.BAT files. Avoid moving the mouse or pressing the mouse button when switching ports on the switch. You can reset the mouse and resume porper mouse movement simply by unplugging the mouse from the switch and allowing 2-3 seconds before plugging it back in.
Company information:
www.kaiweitech.com
Top Archos Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
