Question about Dryers
How do i remove a tooth brush in my dryer vent?
Took the vent apart couldnt get the tooth brush out.
    Scholar:
    New Friend:
  • 123 Answers
Try to pull out from lint filter door. If not try to access from back vent tube. Remove the house vent line and then look into machine inside vent line. It is a 4" diamter hole.
If no luck then you have to access the blower wheel compartment. It depends on your model how to access the blower wheel compartment
Posted on Dec 06, 2014
3 Suggested Answers
  • 132 Answers
SOURCE: loud noise from dryer
Good Afternoon,
If a toothbrush went into the dryer it would have to remain in the drum. There are no outlets large enough for a toothbrush to fit through. Can you tell where the noise is coming from? Also, check the drum good, the toothbrush could be hiding behind one of the ears in the drum and you probably can't see it. Try running your hand behind the ears inside the drum, it just might be there! I hope this will help you and thank you for using FixYa!
Posted on Mar 27, 2009
  • 3097 Answers
SOURCE: Kenmore 110.66902690 electric dryer does not dry completely
Dear Barry,
Try 2 things.
One, be certain the clothes are very dry coming out of the washing machine.
If the washer leaves the clothes wet ( like the belt might be slipping), it can take the dryer forever to finish drying the clothes.
You can tell by hand-wringing them.
You should not be able to get any water out of them by hand-wringing after they have spun dry in the washer.
Two, try running a load with the vent hose unhooked off the back of the dryer.
If this fixes the problem, you are having a "clogged vent" issue somehow.
Be blessed.
Posted on Apr 17, 2013
I have an AF code on my Maytag Bravos dryer. However, the exhaust tubing is totally clear all the way out to the outside vent and there is excellent airflow coming out of the outside vent. Also the li
I would do a Puddle test on the Lint Screen. A Puddle Test is pour a handful of water onto the Lint Screen. If it Puddles Wash it out with Dish Soap and rinse with Hot Water, See we use Fabric Softener Sheets the Oils from the Sheets clog the little tiny holes an it's hard for the air to flow thru it, This should be done every 6 Months just maybe it's giving it a False reading, also maybe check the Door Gasket
Nov 15, 2014 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
How to clean a whirlpool dryer vent?
First Remove drier vent hoze and confirm it is clear and open. Get a long flexible brush. Brush out link for discharger as far as brush will reach.
Go to lent catch screen and remove it . Brush as far as one can for there.
Alternately, but messy, use compressed air, in reverse.
Jul 27, 2014 | Whirlpool Dryers
How to clean lint out of a kenmore elite gas dryer?
Professionally Dryer need to be taken apart some.
by removing front of dryer and removing inner tub
.having a good shop vacuum. and a paint brush .We have a service and charge $65 come out and clean dryer and venting.
heavy lint build up in dryer normally means improper venting.
all domestic dryer venting should never go over 8 ft vertical venting the less turns the better and if vent go's up you need induced venting another fan to help dryer push air Sears website will have brake down on your dryer not a hard job if your good with tools
Jul 05, 2014 | Kenmore Elite HE3 Steam 8674 Dryer
My mom's Kenmore HE3 Elite electric dryer vibrates rapidly while operating. She was cleaning out the lint catcher area with a toothbrush and dropped it inside, then decided to run it after several failed...
yes u have to now replace the blower fan housing u may be able to take apart and remove broken piece byt may not run properly or circulate heat and air as it suppose to
Mar 22, 2017 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a roper dryer. I took it apart today
Remove all duct work connected to this dryer. Clean thoroughly. You will find amass of lint inside of it causing your problem. If not the moister sensor is not working properly and needs to be replaced.
I do hope you will find a clogged vent tube for it is easier to clean the tube than to replace the sensor. The sensor is a fail safe part. It keeps the dryer from catching on fire when the lint tube is clogged up
Apr 27, 2010 | Roper REX4634KQ Electric Dryer
Moldy smell in dryer
remove the front and top covers and remove drum belt then drum and vacuum and wash out all lint that couldnt get out during your vent being plugged then leave it apart and fan dry it out thoroughly and put it together
Oct 04, 2009 | Dryers
My hotpoint washing machine is leaking water from the drawer during the rinse and spin cycles. I cleaned out the drawer, took it apart. Checked for any blockages but could not find any. The top of the...
Get hold of a flexi brush , you know the kind of thing you use to dust down the back of radiators
Take out the soap drawer and insert the brush down the feed tubes one at a time
The brush should have a clear passage into the drum
If you hit an obstruction which the brush cannot dislodge then the top has to come off the washer and the hoses will need to be removed for cleaning
Jul 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Black carbon/soot on the door and lint filter of my dryer
Soot would mean lint is circulating around in your machine, and getting to the combustion area. Take the machine all apart and clean it thoroughly, including taking the cover off the fan and cleaning it too. A dirty fan will slow down the whole works. Check with your hardware store for a chimney-sweep's brush. I once bought one that could be tied to ropes and pulled up and down a flue. If they have a brush the right size, you could do that and really clean your dryer vent.
May 12, 2009 | Crosley CDG6000 Gas Dryer
TOO LONG TO DRY
If your dryer is heating up when first started then your problem is a obstructed dryer vent ether between the dryer and wall or where ever the exterior vent is. On the inside make sure the vent have no kinks in it. Go outside and check the flap in the vent make sure it's clear from obstruction you should feel a very good force of air in that vent when the dryer is running. And final check your lint screen and make sure it has no lint impact on it and run it under water it should not pool up if it does use a tooth brush to clean it. Hope this helps you
Jan 09, 2009 | Whirlpool GGQ8831L Gas Dryer
Dryers Logo
49 people viewed this question
Top Dryers Experts
