Question about Sony WEGA KE-50XBR900 50 in. HDTV-Ready Plasma Television
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Posted on May 28, 2015
Nov 14, 2015 | Sony Televison & Video
Jul 06, 2014 | Sony KV-27S42 27" TV
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The
Standby/Power light of the TV blinks when there is any internal malfunction in
the TV. The self-diagnostic function of the TV will cause the STANDBY light to
blink or flash when the television detects an issue. The number of times the
STANDBY light flashes corresponds to a specific issue.
Few
examples are given below; some of the issues may be resolved without the need
for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a
power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your
set. The set will need to be serviced to allow a technician to determine the
specific issue that needs to be repaired. If the power light flashes three
times in sequence in a Lamp TV, the lamp cover is not securely attached.
Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power
problem.
6 blinks: - This indicates that there is some kind of audio problem with your
set.
7 blinks: - This indicates that there is a temperature problem with your set.
Please check to make sure that the air vents on the sides and back of the set
are not blocked or clogged and there is adequate ventilation around the
television. We recommend that you check and clean the vents periodically to
make sure the set receives adequate air flow. If the problem continues, the set
will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your
set. If the flash sequence is not listed above or the light continues to flash,
follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If
the television is plugged into a power strip or surge protector, remove it from
the power strip or surge protector and plug it directly into the wall outlet.
If the issue is resolved, the problem is with the power strip or surge
protector and not the television.
If
the issue continues to occur, service may be required.
Thanks
for using Fixya.
Mar 02, 2011 | Sony KDF-E42A10 42 in. LCD Television
Dec 08, 2010 | Sony Televison & Video
Feb 03, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Apr 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Dec 14, 2007 | Samsung SyncMaster 204B 20.1" LCD Monitor
Aug 02, 2007 | Sony KV-35S42 35" TV
Sep 14, 2013 | Sony WEGA KE-50XBR900 50 in. HDTV-Ready...
Sep 18, 2010 | Sony WEGA KE-50XBR900 50 in. HDTV-Ready...
187 people viewed this question
