How can I tune my tv so I can get all channels as I can only watch certain channels with a good signal. I have tried auto tuning but its and associated channels has very low signal
    Habit-Forming:
  • 166 Answers
Use the 'skip' function to remove the bad channels from your active channel list.
Posted on Dec 03, 2014
I m having a problem with lg led le5300 26'' it is not catching any signal it has stopped playing any channel i have tried auto tuning so many times but no channel found.
Make sure your cable/antennae connection is OK and you're getting signal from over there by connecting another (working) tv set to it.
Mar 28, 2015 | LG 26LE5300 26 in. LCD HDTV
Trying to tune tv to channel 3,but it doesnt want to stop on 3. goes all around the dial will stop on 2or4 but not on3.
Did you try to manual tune/search the channel? If you are using the autosearch/tune feature and the signal is not strong it will simply skip the channel. Find channel 3 with manual search and then save it. Good luck!
Dec 14, 2007 | Televison & Video
I have an older model Durabrand t.v. I'm trying to connect my satellite to it but the channel got changed. How do I get the t.v. to the correct input to use the satellite without a remote?
Connect and put on both TV & Sat Receiver, then on UHF channels, auto or manual tune the Receiver's output signal, try to fine tune if auto or manual does not tune well.
Nov 13, 2014 | Televison & Video
I lost a few digital channels on an old LG LCD, tried to auto tune but could not retrieve. Followed a tip online that said to auto tune with the antenna cable which will wipe all saved channels, once...
hi your signal could be to strong, on the aerial cable the thin brad rap 4 strands around the center solid pin then retune in auto, if this does not work you may to manual tune it in, or get someone to check your aerial and you could try a firmware update on your tv hope it helps
regards
shaun
Jun 29, 2014 | Televison & Video
Whilst watching digital channel, tv suddenly said channel not tuned. Same problem with all channels. Now comes up channels not stored, and when trying auto start up, says no channeels found.
Ur tv,u are using and getting a over the AIR free broadcating tv channels signal wright?Ur antenna are using,have problems might not work anymore in ur area.Tries manual channels scanning ur tv should get it back or buy a better antenna deign like a Digital antenna design for a hook it up for a better signal prob and longer signal ranges tries scanning for Free over the AIR channels again should solved this problems.
Aug 27, 2011 | Sony BRAVIA KDL-46V3000 Television
Gooman ld2667d tv is not recieving any digital channels, using the same ariel port as before. unplugged the tv to put onto a new stand and getting no digital tv channels. Signal is 0 % too. Before i...
The range and the airial antena have trouble recieving the new location air signal.Try buy a new digital antena and install it.Auto tuning it again.Should work fine.
Aug 12, 2011 | Goodmans 289NS 14" TV
New LG 32LD350 - Allowed TV to auto-program channels, and for some reason, it skipped past channel 4 during the tuning process. When I select channel 4 in the tuning options, it comes up as no signal. On...
When you are auto tuning the system will not store a channel which is week by its standard ( at least 60% signal strength ) This done to avoid grainy picture and hissy sound.
You can go into manual tuning and store it.
Mar 11, 2011 | LG 32LD350 32 in. LCD TV
Hello .i have a lg tv which i purchased in 2008 and only watched videos,i now want to watch tv i have tried auto tune and it only finds 3 vhf channels and none digital.it has preview built in but i can not...
if it has freeview built in its usually programmes itself try turning it on and go into the menu and there should be an auto tune function hit that and it should tune up but remember it needs to be connected to an aerial if it still says no signal try moving the aerial, getting a booster for the aerial they usually plug into the mains then into the back of your tv and you plug your aerial into that to boost the frequencey if that doesn't work then you might need to think about getting a new aerial but you can get 1 for under £30
Feb 02, 2011 | LG Televison & Video
My DTV stopped working giving a blank screen
It may just need to be Re-tuned.
What I would suggest you do is make sure that you are on a DTV channel on your Tv. then with your Pioneer remote press the menu button and then set it away on a Auto tune.
You must have it on a DTV channel first before try to tune as if you mistakenly have it on TV (terrestrail channel) It will only Auto tune that and not your freeview.
Hope you get it sorted.
Cheers Little Dish Fitter
Oct 06, 2009 | Televison & Video
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
