Question about Samsung CoolTech Plus / Basic Bottom Mount Refrigerator SR-L676EV
I know that my fridge freezer is get old but it is still good except of the notice it make is now very load could it be the compressor. And if it is can it be sorted
Switching it off
  • 44 Answers
There are a couple of reasons it could be. If the freezer has a fan unit the fan may need tightening or the bearing is shot, or the compressor is low on gas and making the unit to work harder, hence the seemingly louder noise.
Posted on Dec 03, 2014
Here we go, I have a GE side by side about 6 years old... Started with the icemaker not dispensing ice consistently... then the ice stopped all together (even though the bin was full and not froze solid)....
The clicking you are hearing is the relay unit. Now it is for sure that the compressor is not working as the relay keep s tripping off.
So first of all to clear this doubt, let us checck the relay unit which is clicking. remove and check. most of the time the relays need to be replaced as a poor contact will not deliver good voltage to the compressor and it will shut off. So check this out.
One the compressor works and you notice there is cooling the sytem seems ok except that you must check if the thermostat, the auto defrost cut off timer works.
If after the compressor works the cooling is not good then you can decide on a replacement than to spend for expensive repairs
Sep 12, 2010 | Microwave Ovens
Fridge running hot!
One you can to try and extend the life of the fridge is to vacuum off the compressor and coils. They can be located either behind the toe grill on the bottom front or through an opening on the back of the fridge. It is natural for a fridge to blow warm air.
Aug 30, 2009 | Maytag MSD2454G Side by Side Refrigerator
Just got back from vacation opened fridge door and wow, was greeted with god awful smell everything hot, i noticed the freezer temp was on zero, possible due to my four yr old but know cant get the...
if the freezer is at o then the compressor is working and frost buildup in freezer back panel check to make sure the cooling fan is working on the compressor area
Aug 19, 2009 | GE Refrigerators
Fridge freezer shorting out electrics
The cause of this situation could simply be an overloaded circuit. Homes are built with dedicated circuit for fridge only now because of this. If you notice power outage in other rooms or other appliances in kitchen then the circuit affected,I.E. other outlets affected need the load lightened. If it is a dedicated circuit then could be faulty breaker or possibly altered wiring could be cause.These have to be ruled out before you will know for sure. If it isn,t dedicated outlet for fridge only, just plugging in a light could overload loaded circuit.
Apr 21, 2009 | Refrigerators
Freezer quit then noticed fridge side not cooling
the relay on your compressor is bad go behind you refrigerator and take off the the bottom panel the relay is on the left side of your compressor usually
Dec 29, 2008 | Whirlpool GD5SHAX Side by Side...
Fridge & Freezer not cooling
i think you have a bad compressor pull it out and take off the back panel and feel the compressor if it is hot and making a bad sound it might be an over load relay
Dec 11, 2008 | Frigidaire PHS67EHS Side by Side...
Whirlpool ET1FTKXK Fridge not working
The reason you had water dripping from the top is the frig goes into a defrost cycle every 12 hours or so and melts the ice build up. Now your drain line for the water to go down to bottom of frig is plugged more then likely with ice. Take the cover off back of freezer and get some salt table salt be good. And put it in the drain hole located roughly in the center of freezer cabinet. That will take care of the drain quick. Now notice to see if the fan on the inside of freezer is on. My hunch is that it is not turning. You can replace the little fan motor make sure you don't damage the fan blades you will re-use them. Be sure compressor is on cause the fan only works when compressor is on. Let me know what you find out.
Nov 25, 2008 | Whirlpool ET1FTKXK Top Freezer...
Power on but fridge/freezer not working (only lights)
Yes, boards may need replacing, but not at the expense of the door, apparantly your "engineer" would rather work on older models that may require a hammer. Best advice would be given knowing the make and model number of your unit. A professional should be able to diagnose the board processes as well as the compressor in a short amount of time. Check the defrost heater (after pwr is restored to unit) for the freezer side (placement depending upon model) for continuity (basically a heating element for the evaporator coils - which will freeze without defrost). Proper defrost will help lessen the load on the compressor. Check the overload relay on the compressor itself for failure and replacement of relay. Have the unit defrosted, svc defrost htr, thermostats/thermolinks , compressor, before checking computer board operations.
Oct 25, 2008 | Freezers
Fridge not cooling compressor works intermitently
Is the brand name of the compressor Tecumseh?? How old is this fridge??
Jan 10, 2008 | Frigidaire FRS26RLECS Side by Side...
Freezer problems
remove back panel of freezer. check if there is excessive ice build-up preventing air flow. if there is, then defrost carefully with a hairdryer (with appliance switched off) if no ice or frosting on pipework, check if compressor is running. if it is or hot to the touch or clicking, then you have a compressor fault and replacement is not diy. if compressor not running, then probably module fault
Apr 15, 2007 | Smeg FAB32 Bottom Freezer Refrigerator
Refrigerators Logo
62 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
