Question about LG Televison & Video
How do I repair an LG 32LK330-Ub Auto channel tuning does not work.
I have a 3 yr old TV that worked fine. Autotuner no longer works. (Cable connection is fine-works on other TV
    Habit-Forming:
  • 166 Answers
If you have a cable box and your cable is attached with coax to the antenna or cable input you're probably receiving everything on Ch 3 or 4. If you don't have a cable box, then make sure the input / source is set to cable and not antenna.
Posted on Dec 03, 2014
How do i install the stand on a LG 32LK330-UB.CUSYLH
You are missing the stand header which in between the stand & the TV stand slot.
Apr 10, 2017 | LG 32lk330u 32-inch Widescreen Hd Ready...
Soundbar connection from Phillips TV to a Samsung HD 550 soundbar
The sound bar only needs sound input from the tv so optical cable connection will work fine. HDMI cable will also work fine. Use the one that you have available.
Mar 18, 2017 | Samsung Televison & Video
14 yr. old Land Rover. 8 yr. old GPS/stereo suddenly blowing fuses. Circuitry for radio memory, clock, internal lights & locks now no longer work. Head unit & AV controller unhooked & not the problem.
Disconnect all of the peripherals on the offending circuit. Then connect each, one by one, till the fuse blows. Voila - the source of your problem.
Dec 09, 2015 | GPS
I m having a problem with lg led le5300 26'' it is not catching any signal it has stopped playing any channel i have tried auto tuning so many times but no channel found.
Make sure your cable/antennae connection is OK and you're getting signal from over there by connecting another (working) tv set to it.
Mar 28, 2015 | LG 26LE5300 26 in. LCD HDTV
How do I reconfigure an LG 32LY560H from Commercial setup to auto tune for use in personal residence?
possible that you need to have cable to do this, you might only have 6 digital channels, without cable
Mar 01, 2015 | LG Televison & Video
Auto retune has wiped everything. Help
There is the digital tuner (DTV) and the analogue tuner (TV). Make sure you are tuning the digital side as there are no longer any analogue TV broadcasts in the UK.
Sep 04, 2014 | LG 26LH2000 26 in. HDTV LED TV
I lost a few digital channels on an old LG LCD, tried to auto tune but could not retrieve. Followed a tip online that said to auto tune with the antenna cable which will wipe all saved channels, once...
hi your signal could be to strong, on the aerial cable the thin brad rap 4 strands around the center solid pin then retune in auto, if this does not work you may to manual tune it in, or get someone to check your aerial and you could try a firmware update on your tv hope it helps
regards
shaun
Jun 29, 2014 | Televison & Video
What is the service code of LG32LK330
mine is on back of tv 32lk330-UB.CUSDLH
Oct 27, 2012 | LG 32LK330 TV
LG 42LK450 flat screen.I tried auto tuning but didn't pickup channel 31. I tried manual tuning with no result. The old style TV I had prior to this could pick up channel 31 so it isn't a reception...
If your trying to receive over the air make sure the TV is not set to a Cable mode, if your on Cable your new TV is most likely a ATSC tuner (digital) and the cable company can map channels any way they want. If your old TV had the older style cable tuner, the lineup will be different.
HDTV has level thresholds, if the signal is weak you wont see anything, but the old TV would.
Without knowing much about where or what sort of TV your using, these are my best ideas.
Oct 26, 2011 | LG 42 42LK450 42 LCD TV
My 17 yr old sony triniton goes on after about 5 or so min. the picture is great then the screen goes black (audio fine) for about 4 seconds then the pic is back for about five min then the same thing...
U have a soldering iron,a roll of solder and can do a basic soldering work too?Yes,take the tv aparts.Tv have a cold sodering video board,that the board where it is connected to the CRT-(tv tube).Resoldering the sock pins of the video board that connected to the tv CRT-(tv tube).The tv picture,will be stable and work again as soldering work it is done and the tv have to a good connections between the tv video board and connected to the CRT-(tv tube) again.
May 24, 2011 | Sony Televison & Video
Televison & Video Logo
155 people viewed this question
Computer Repairing
Computer Repairing
