Question about Lavazza Coffee Makers & Espresso Machines
Lavazza LB 2210 error 82/84 - Lavazza Coffee Makers & Espresso Machines
2 Suggested Answers
dawndordine
  • 3 Answers
SOURCE: need service on lavazza blue LB 2210
For more company or product information please call us at 800-524-2343 or email us at info@betson.com
Posted on Jun 05, 2012
Error code 11 lavazza blue
Aug 20, 2013 | Lavazza 2210
Whats the lava a10 security default code
Dear Sir, This is to inform you that the default password of A10 is "4321"
Jul 21, 2011 | Lavazza 2210
What is the handset code for lava arc 02
Dear Sir, This is to inform you that the handset code for ARC02 is "4321"
Jul 20, 2011 | Lavazza 2210
My Lavazza Blue coffee machine does not press enough to punch the holes. The coffee comes out water. What should I do.
After 1700 shots it is recommended that both upper and lower punchers as well as all seals in the brew unit be replaced. These punchers are only plastic so they do get worn down after much use. You may also be experiencing more water in your drawer as water is leaking from around the capsule seal. This is also an indication that the seals and punchers should be replaced. Given where you go to have this fixed, the parts may cost less than $15.00.
Jul 08, 2011 | Lavazza 2210
The screen says "empty dregdrawer".
  1. Remove the drip tray (it just lifts off)
  2. Pull on the bottom section, this is a drawer which contains the spent capsules.
  3. Empty the drawer.
  4. Replace the drawer and the drip tray.
This video shows how it's done around 6:55: http://www.youtube.com/watch?v=QnJwgnbfmoQ
Feb 28, 2011 | Lavazza 2210
I am considering buying a Lavazza LB2210 Espresso Machine. Owner says the screen says "fill with water" after she descaled the machine. What kind of cost am I looking at to get this fixed?
There is a floating plastic block in the water chamber that sits next to a sensor in the machine, that tells the machine whether the water reservoir is full or not. if its stuck, that could be the simplest fix ever. It could also be the sensor at fault, but it should be easy to test the float first
Sep 24, 2010 | Lavazza 2210
Just need instructions to descale my Lavazza Blue coffee machine
Using a proper coffee machine descaler, create the mix in the water container
Go into the service menu by pressing the 'Stop' button when you turn it on. Scroll throuigh the menu until you reach 4. Descale. Press enter, then scroll to 4.3 Do it now. Press enter and toggle to yes, press enter
It will then run through the descaling cycle which may take some time. After its complete, thouroghly clean the tank and pump lots of water through the system before you brew any coffee, Replace the filter also
Sep 05, 2010 | Lavazza 2210
Machine is plugged in...but when the switch is flipped, the machine refuses to turn on (yes there is power to the outlet).
Could be a defective power switch or open line cord/plug. You will need a voltmeter to determine which is at fault.
Mar 06, 2010 | Lavazza 2210
Machine is spewing grounds into the cup
This is usually an overfill of grounds or the water distribution nozzle is not distributing the water correctly. First, put no coffee in the unit. Just fill a cup w/hot water. If it still is putting out grounds, the upper basket has coffee grounds stuck in the nozzle. If you get no grounds, try reducing the amount of coffee used.
Nov 09, 2009 | Lavazza 2210
Need service on lavazza blue LB 2210
Jan 04, 2009 | Lavazza 2210
Coffee Makers & Espresso Machines Logo
55 people viewed this question
Top Lavazza Coffee Makers & Espresso Machines Experts
ray gallant
nikolay nikolov
Tom Chichester
Are you a Lavazza Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
