Question about Kenmore Washing Machines
My kenmore elite calypso will not do final spin.flashes LD. I replace the pump as was suggested,still did not fix froblem
Replace pump and clean all hoses.
  • Kenmore Master
  • 744 Answers
Hello Alex;
My name is Peter. I am a retired field service appliance technician.
After review of your washer components, there is a strong possibility that you have a bad electronic control board. You have two control boards, one is for the motor and one for the other functions.
my kenmore elite calypso will not do final spin.fl - 25306051-b3edjqs4ufvbcqfi2v1m52kl-2-0.jpg
Washer electronic control board for Kenmore Elite Washer model #11021062001 Electronic control board 8571359 is the circuit board that manages the washer's functions, such as filling, washing, draining and spinning. It sends voltage to the drive motor and other electro-mechanical component.
Cost: $218.00
If you elect to replace the board make sure you ground yourself by rubbing your hands on something that is bare steel. Static electricity will knock a board out.
All appliances with electric control boards should have a surge protector. You can purchase a wall socket surge protector for $20-25.00. It is a good investment considering how expensive control boards are.
Rule of thumb; "If the unit is either 7 years old or the cost of repair is 1/3 or more of the original price, purchase a new unit.
Consider it purchasing a new unit, stripping your existing unit for parts to sell on e-bay. You will make a little money and save others expensive parts cost.
Posted on Dec 04, 2014
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Ld error code on my kenmore elite calypso washer
Please recheck on your replacement and see if the harness was connected to the right socket.
Click this link: Pump
Jan 25, 2013 | Kenmore Washing Machines
Ld Long Drain Ld flashes
ld indicates a LONG DRAIN. yo ucan remove the lower panel and clean the filter housing, this will impede the draining abiltiy
Feb 09, 2010 | Kenmore Elite 45986 Front Load Washer
Washer stops when Ld comes up on display before final spin, but washer drains fine.
ld flashes if it takes longer than 5 min to pump out water to the point where the operating pressure switch resets.check the drain line for kinks,check drain for blockage,check pump operation.
Jan 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
I have a kenmore elite top load calypso wash motion at the end of wash cycle it does not spin and flashes a LD on display I have to turn off and just do a spin cycle to to spin dry.
LD (long drain). possible blockage at pump..check to see if pump spline is stripped. also if the drain hose is plumbed in airtight then this may be slowing the draining process.
Jun 13, 2009 | Kenmore Washing Machines
My kenmore elite calypso washer
"Ld" indicates Long Drain: Ld flashes when the water level does not change after the drain pump is on.
depends on the following factors:
1-> the drain pipe could be longer than 8 feet
2-> the drain hose could clogged or kinked
3-> the pressure hose connection from the tub to the machine motor control could be pinched or plugged?
4-> and finally the pump might not be running well.
If you need any sort of help with the disassembling of machine tell me the exact model number and i can provide with some internal diagrams.Good luck with the machine.Please do rate my solution, also do post comments in case of further doubts.
Jan 24, 2009 | Kenmore 20172 Top Load Washer
Our Kenmore Elite Calypso was running great. Put in a load to wash and turn it on as usual. Upon returning the basin was full of water and soap. Tried to get it to spin and it did nothing. We have removed...
remove as much water as possible lean washer back against wall remove bottom cover if pump has screws in bottom remove them and try cleaning pump HAVE TOWELS HANDY..if no screws probably older version they were bad for having stripped drive splines only fix was to replace pump
Sep 09, 2008 | Washing Machines
Kenmore Elite Washing Machine with Calypso Wash Motion Model # 110.22066102
have you removed bottom panel and cleaned pump..old style pump was held om with clips but the splined shaft in the pump would strip out and never pump properly only solution was replace pump/motor assembly..new style pump had 4 screws in bottom and could be removed and cleaned
Aug 21, 2008 | Washing Machines
Washing Machines Logo
55 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
