Question about Dishwashers
How do I put the door latch in the g e 700 pot scrubber dishwasher? I need pictures to work with.
We have the panel off and need to know how to position the handle so we can put the panels together
  • 74 Answers
SOURCE: door handle loose
they are a vivration attenuator and yes are spacer too, but are a little dificult to mount if the machine are working well ok leaved like that but check every coples of month for a loose screew.....good luck and rate me
Posted on Jan 10, 2008
  • 171 Answers
SOURCE: Whirlpool DU1100XTPS dishwasher leaking from front door panel
Hi karen_kinzer,
I'm Harvey the Master Plumber.
The d/w was a recent purchase?
Then my advise to you is don't worry about it! The unit should be under warranty. It's time to make the call. Let the warranty repairman worry about it. If he can't fix it, he has the authority to condemn it and you'll get a new one. Anyway, this is one problem you should not have to worry about.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 13, 2008
SOURCE: Electrolux ESL6114 built in dishwasher door
Although it is a different model than yours, here is the link to the installation manual for an Electrolux DW and it is likely similar. The custom panel instructions begin on page 22 and show templates and how to remove and reinstall the factory door and a custom installation panel: http://www.electroluxicon.com/Files/International_English/0-999/EDW5505ESS_install_en.pdf
Posted on Oct 26, 2008
SOURCE: Kitchenaid dishwasher - door will not latch
The latch needs to be replaced. Kitchen Aid has made two updates to this latch. I.E. 2-revised latches. I just replacd the latch assembly and the dishwasher works fine now. Do a search for kitchen aid repair parts online and hav them shipped to your home. The repair takes five minutes. Un-screw all torx bit screws on door and the latch is under neath. One electrical dip switch held on by another screw and a two prong tab to undo the old latch. This seriously took me five minutes to repair and the parts were $40.00 online shipped.
Hope his helps.
Posted on Jan 16, 2009
  • 246 Answers
SOURCE: KITCHENAID DISHWASHER DOOR PANEL
www.applianceart.com has many options for you to choose from. They sell many different panels to put on your dishwasher. If you call them (678-727-4747 x32) they can also send you a metal stainless plate that is easily installed. I think the metal ones are around $99.99 and the other options are $39.99
Posted on Aug 21, 2009
How to fix electrolux el 6115 door latch is faulty and doesn't click shut
It happens to skip latch and is no longer possible to close the door and turn on the dishwasher. The latch is in plastic material in which a system of levers provides the mechanical action.
Solution: Remove control panel and put latch back into normal position with the slot forward. Look the picture.
Dado
Jul 09, 2014 | Electrolux Dishwashers
Need door latch diagram Kitchen Aid dishwasher (Part No. 9744033)
I thought the metal bar had to be locked into place somewhere in the black latch. This was not the case. I just put the white plastic latch in place in the slot in the door and closed the panel and the metal bar went into the correct position against the black latch.
Jan 22, 2010 | KitchenAid KUDS24SE Built-in Dishwasher
When i close the door i hear it close but i have to put something up against it to keep it washing if i take it away it stop washing
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Latch The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem. If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
Nov 19, 2009 | Maytag Dishwashers
The door on our GE Pot Scrubber dishwasher - just
You will have to pull the dishwasher out after disconnecting the water pipe and power.
Simply make a new loop on the broken spring or buy new ones from an appliance dealer and reconnect the spring.
Nov 08, 2009 | Dryers
My GE pot scrubber won't fill with water, all kof
you are probably in need of a new water inlet valve part #WD15X10003, should be around $35.00. this valve opens up at the proper time on the timer to let the water into the machine. hope this helps.
Oct 15, 2009 | GE 24 in. GSD2600GBB Built-in Dishwasher
Same thing happened today
with the door open when your dishwasher was working normally Did the lights light up on the keypad? I am wondering because if the answer is the keypad only worked with the door closed .....you possibly have a bad door switch.
or it could be a blown fuse inside the dishwasher. are any lights on at all?
Jun 12, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
How do I replace the door latch on my dishwasher?
Don't try to bend anything! The latch mechanism in the door is probably broken. Open the door and remove the 11 torx screws holding the inner panel on. You will probably find broken plastic bits on the pathetically flimsy latch; mine failed after 4 years and I expect it to happen again.
If you do, see the link given in "I Have 3 problems with my dishwasher, my...",
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5168615&diagram_id=1349844#d1349844 Unlatch the two switches and slide them off the old part and onto the new one, observing all the obvious precautions about not getting shocked and putting the switchess on correctly. Reassemble the door and latch with the screws.
May 23, 2009 | Admiral 24 in. DDB1501AWW Free-Standing...
After my dishwashing cycle is complete there is a residue left on the dishes -- I only fill the soap half way and i use a rinse agent.....
Dishwashers work best when the following "rules" are followed.
1. Rinse food off of the dishes before you place them in the dishwasher.
2. Face plates toward the center and do not over crowd them.
3. Always put glasses on the top shelf and always put plates on the bottom.
4. Run the hot water in the sink until it is as hot as it will get before you start the dishwasher.
5. If your dishwasher has a pot scrubber cycle use it and it will make a difference.
Doing these things should solve your problem. If not, let me know.
Jan 04, 2009 | Tappan 18 in. MDR251RE Built-in Dishwasher
General Electric Pot scrubber Dishwasher
From what you are describing, the fill valve may have failed or become clogged. Start the dishwasher, when the water stops filling, open the door and check the water level. There should be at least an inch to an inch of water in the center of the tub. If not, replace the water inlet valve.
If you need further assistance, let me know with a model number
Regards,
reg501
Jul 21, 2008 | Dishwashers
Dishwashers Logo
50 people viewed this question
Top Dishwashers Experts
Owen Barnes
