Question about Samsung SELECT HLS6767WX/XAA Rear Projection Television Replacement Lamp RPTV
I have a 2006 Samsung DLP TV and the color fluctuates slightly dim to normal at about 70 times per minute
I replaced the lamp with BP96-01472A and the color wheel with BP 96-01579A (assembly color wheel OEM from Amazon) and dmd/formatter board BP94-02269A (from Samsung parts). I had also previously reinstalled the old lamp and could still notice the brightness/color fluctuations just the same. Color wheel replacement made no difference (old wheel had a slightly scratchy sound only noted after removal). DMD/Formatter board replacement made no difference. I can upload a short video of the problem if needed. Please help!
  • Donald Alderman
    Donald Alderman Dec 03, 2014
    I also noticed during power on warmup, the fluctuations are not there until full brightness. As the screen comes to life and is dim, there are no fluctuations until full brightness.
Luvlee
  • 59 Answers
SOURCE: SAMSUNG HL-P4663W 46" DLP COLOR WHEEL PROBLEM
Hi...No need for a different jumper or different color wheel. It's an easy fix. Make sure your TV is turned off and remove the jumper with a pair of needle nose pliers. Just keep it in case you may need it in the future. I will post a picture to show you where the jumper is located.
Posted on Apr 10, 2008
circuitcity
  • 137 Answers
SOURCE: Checking the color wheel on my DLP
Hello brandon b,
have you change the color wheel? what have you changed so far? Pleasenlet me know asap.
Best regards
circuitcity
Posted on Jun 24, 2008
SOURCE: DMD Board failure on Samsung DLP
Try here:
http://www.partstore.com/GetModel.aspx?MfgName=Samsung&BrandName=Samsung&ModelNumber=HLN5065WX&PartCategoryName=&Keywords=board&Page=1&SortBy=price&SortDirection=asc#PartsearchSKUList
Posted on Feb 02, 2009
  • 453 Answers
SOURCE: I have a Samsung HRL6167WX/XAP
yes , u need to remove this jumper , and the whine would go away , the bulletin is unique for each color wheel , the jumper is very small so just take u time to look for it , is located at the dmd board
Posted on May 08, 2009
  • 2318 Answers
SOURCE: NEED THE DMD PART NUMBER FOR A SAMSUNG DLP MODEL
Here's the DMD part number: BP94-00478A
Posted on Dec 14, 2009
DLP powers down after 1 minute; no sound or audio
REPLACE LAMP IF PERSISTENT REPLACE THE LIGHT ENGINE COS THE COLOR WHEEL IS WORN OUT
Jul 07, 2013 | Televison & Video
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
TV won't stay on
Hello Fonzell!
Regarding the tv turning, my question is, do you hear a clicking sound? if so, it's most probable tio be your ballast, that might not have enough voltage to keep on with your lamp, and that's why it shuts off.
You could try replacing it and seeing if it resolves your issue, I believe they're running around 70 dlls..
have a great one ! :)
Apr 21, 2009 | Samsung DLP HL-P5663W 56" TV
I have a Samsung HLR6168W DLP that intermittently shuts itself down,the sound stops, the picture disappears, the screen goes dark but not completely off. A few moments later the picture returns, but no...
its the problem of inner lamp that is near to end of its life and it needs replacement.and what the thing is happening is the indication of faulty lamp.
how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
how to replace the ballast with diagram and procedure
http://www.consumermeet.com/entry/samsung-dlp-ballast.html
Mar 11, 2009 | Samsung HL-R6168W 61" HDTV
My rca tv not working
the lamp which you rteplaced is not seated properly.and also it can be the problem of colour wheel or the ballast.to check out all three just check out this links 1 by 1 for colour wheel with diagram and procedure
for lamp in 5 minutes with diagram and procedure
for ballast with diagram and procedure
Feb 09, 2009 | Toshiba 32AF41 32" TV
Fan failure
chances are it's the one large fan in the rear of the unit. That's the most common to fail. Easy to do yourself. A $30 part and 20 minutes total to do, unscrewing with a Philips screwdriver, replacing the fan, and putting it back together...
Part is:
Motor dc sff21c/c-np
Aug 17, 2008 | Sony KDS-R50XBR1 50" HDTV
Samsung SELECT HLS6767WX/XAA Rear Projection Television Replacement Lamp RPTV Logo
61 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
