Question about Car Audio & Video
"I just got a pioneer deh x8600bh and everything works but while in settings and on hd tuner the things works for a bit on station then just starts scrolling threw stations and I pull face plate out and put it back in and works good for awhile then just starts scrolling again
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
It sounds to me like you may have a bad seek up switch. If you have a multimeter you can check the switch for resistance. Also, you can check the switch to see if it has a solid feel to it when you are pressing it.
Posted on Dec 08, 2014
mixmaster
  • 626 Answers
SOURCE: pioneer deh p9800bt
There is a yellow wire that needs to be connected to a constant +12 volt supply. This wire retains all of the pre-sets, settings, etc.
It sounds like it is not.
Check the connections with a volt meter with the vehicle off to verify it has constant +12 volts.
Best of Luck.
Posted on Nov 13, 2007
  • 41 Answers
SOURCE: setting up fav stations
seek to the station you want and hold down the preset button you want that specific station set to.
for ex: seek to 101.3fm and hold down the number 1 preset button for about 5 sec.
Posted on Mar 29, 2009
  • 323 Answers
SOURCE: face plate went out on my pioneer deh 6800mp
There is a fine strip that runs from the face to the circuit board. It is possible that face has gotten dirty just needs a can of compressed air or the circuit board has failed inside the face. The face plate is very easy to take apart and put back together, just make sure you don't lose any pieces ;) Good luck!
Posted on Jun 11, 2009
  • 4 Answers
SOURCE: Pioneer DEH-1100MP stereo no working
Is it older then a year? warranty or call18004211404. If your fuse is good check these. check you harness for a GOOD ground, check for power with a meter reader. For some reason on these units if your constant 12v and ignition 12v are both not hooked up it wont even do a thing. make sure both are connected. no loose connects?
Posted on Aug 16, 2009
  • 733 Answers
SOURCE: how to set time and preset radio stations on
Here you go.
http://www.pioneerelectronics.com/StaticFiles/PUSA/Files/DEHP4000UBOperationManual1019.pdf
Posted on Feb 08, 2010
I need an owners manual for a 2010 pioneer super tuner III D stereo
http://www.pioneerelectronics.com/PUSA/Car/CD-Receivers/DEH-P2900MP
there's some links on the web page above to the installation and owners manual
Jan 21, 2012 | Pioneer Car Audio & Video
DEH-P7900 BT US model. Isthere any way I could change the tuner frequency to european one. Thanks.
The DEH-P7900BT is almost identical to the DEH-P85BT sold in Europe.
This is a US model and will tune most AM/FM stations in the UK/Europe. The FM broadcast band is 87.8 to 108.0 MHz. so it will not pick up any FM stations outside this range. Also, the tuning is in odd increments (such as 96.1, 96.3, 96.5, etc.) so some stations with even frequencies will be slightly distorted, depending on the power of the signal the station generates.
I found this bit of info for you but ill keep looking and let you know what i find out.
Also have you tried it in europe to see if it does work or not let me know ok
Mar 30, 2008 | Audio Players & Recorders
Installed my Pioneer DEH-1100MP When radio is turned on display /tuner/aux comes up Can set stations etc but no sound With light tester to speaker wires there is power etc
Does your car have a Factory amp if so u need to find the blue wire ( on most cars) and either ground it out or and power to it, it should turn the speakers on for you to play
Sep 10, 2010 | Pioneer DEH-1100 CD Player
Pioneer DEH P6000 screen reads "tuner er"
try disconecting your battery while its on then reconnect
Jan 01, 2009 | Pioneer DEH-P7000BT Car CD/ MP3 Player
Help please
to set the clock turn off the unit and then hold the multi control thing down and the clock thing will come up.
Sep 02, 2008 | Pioneer DEH-P4000UB CD Player
Setting radio station to a channel on a Pioneer DEH-525R cd player
Scroll to the station then press and hold the preset button you want it to goto.
May 23, 2008 | Pioneer DEH-P2000 CD Player
DEH-P580MP
If you are referring to the presets tuner station settings being deleted when powered off and or the clock resetting its time, then you have to verify that the Pioneer DEH-P580MP is wired as follows:
Black - chassis/body ground/GND
Yellow - always on/constant B+12 such as the + terminal of the battery;
Red - switched on B+12 such as the ACC of the IGN switch.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 28, 2008 | Pioneer Premier DEH-P580MP CD Player
DEH 245 Lights
Try Turning the Power off holding down the clock button till the clock display flashes then use the volume and tuner keys to set the time.
Dec 17, 2007 | Pioneer DEH-245 CD Changer
Pioneer DEH-P690UB FM tuning problem
Pioneer have factory set your DEH-P690UB to 0.2Mhz steps to match the American FM frequency allocations. The fix is not casual as it requires complete disassembly of the head unit and repositioning of two surface mount resistors. This will void any warrantee and unless you're good at microscopic soldering could also ruin the set. I did however void my 2 year warrantee yesterday partly out of frustration and because I have the right SMT tools at work. Now my tuner CPU thinks it's in the Austrailian/Asian model DEH-P7950UB and is also compatible with UK stations. A previously hidden menu is also available where I can set either 0.1 or 0.05Mhz stepping for FM and 9 or 10KHz for AM BSM scanning. The rotary control now steps in 0.05's instead of odd 0.2's on FM Hope this helps.
Aug 23, 2007 | Pioneer DEH-P690UB CD Player
Car Audio & Video Logo
49 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
