1999 Jeep Cherokee Logo
Posted on Jul 06, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to remove door panel on 1999 grand cheeroke, window is off regulator
Anonymous
Level 2:
Sniper:
  • Expert 83 Answers
  • Posted on Jul 06, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
83
Questions
0
Helped
89841
Points
379
Not that difficult of a task, it would be wise to get a service manual with step by step instructions and pictures. Factory ones are here for $20 bucks http://www.promanuals.net/dodgejeep.html
Trim
(1) Remove trim plug from mirror flag bezel.
(2) Remove screws attaching trim panel to door
(3) Using trim remover detach trim panel perimeter push-in fasteners from
door inner panel.
(4) Lift trim panel upward and separate from door.
(5) If equipped, disconnect harness connectors for
power accessories.
(6) Disconnect latch rods from inside handle actuator.
(7) Separate trim panel from vehicle.
Window Regulator
(1) Remove front door glass, (you may be able to access the regulator if the window is up)
(2) Loosen bolts attaching regulator to inner door
panel
(3) Remove bolt attaching regulator to inner door
panel
(4) Lift regulator upward to disengage bolts from
door inner panel.
(5) Disengage power window regulator harness
connector, if equipped.
(6) Remove regulator through access hole in door.
How to install power window cable
cable? (electric>?)
here is the page on motor;reg.
  1. Disconnect and isolate the battery negative cable.
  2. Remove the window regulator from the door.
    • Remove door trim panel.
    • Remove isolator.
    • Remove front door glass.
    • Loosen bolts attaching regulator to inner door panel.
    • Remove bolt attaching regulator to inner door panel.
      • Lift regulator upward to disengage bolts from door inner panel.
      • Disengage power window regulator harness connector, if equipped.
      • Remove regulator through access hole in door
    • Place the window regulator on a suitable work surface and remove the screws that secure the power window motor to the window regulator.
    • Remove the power window motor from the window regulator.
1helpful
Cable system on passenger door power window, 1999 dodge Caravan, has slipped off track. Need exploded diagram to restore to original.
REMOVAL
1. Remove the watershield. (Refer to 23 - BODY/DOOR - FRONT/WATERSHIELD - REMOVAL)
2. Remove door glass retaining clips and secure the window in the up position using masking tape or equivalent(FRONT DOOR GLASS CLIPS).
3. Disconnect wire connector from power window motor, if equipped.
4. Loosen screws attaching front and rear window guide rails to inner door panel (FRONT DOOR MANUAL WINDOW REGULATOR - TYPICAL).
5. Remove screw heads on guide rails from key hole slots in inner door panel.
6. Loosen screws attaching regulator to inner door panel.
7. Remove regulator from inner door panel.
8. Extract rear guide rail through inner door panel rear access hole (FRONT DOOR POWER WINDOW - TYPICAL).
9. Extract front guide rail through front access hole.
INSTALLATION
1. Insert front guide rail through front access hole.
2. Insert rear guide rail through rear access hole.
3. Place window regulator in position on inner door panel.
4. Place screw heads on guide rails in position through key hole slots in inner door panel.
5. Tighten screws to attach front and rear guide rails to inner door panel.
6. Connect wire connector into power window motor, if equipped.
7. Install door glass.
8. Verify door glass alignment and operation.
9. Install sound shield and door trim panel
DIAGRAMS CAN BE FOUND ON JUSTANSWER,COM
4helpful
3answers
1997 mercury grand Marquis driverside rear window motor works but window won't go up. Inner door panel off. Metal cable with a black foam cover and pink plastic clip off. Can't figure what it fits to.
usually this means you need a new window regulator.
Section 01-11: Glass, Frames and Mechanisms 1997 Crown Victoria, Grand Marquis Workshop Manual
REMOVAL AND INSTALLATION Window Regulator, Power Front Door
Removal
  1. If front door window glass (21410) is in the down position and is inoperable, the following steps must be taken; if front door window glass is operational, go to Step 2.
    1. Remove front door trim panel (23942) and front door trim shield (237A04). Refer to Section 01-05 .
    2. Disconnect battery ground cable (14301). Refer to Section 14-01 .
    3. Disconnect window regulator electric drive harness connector.
    4. sva~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Be careful not to strike or scratch front door window glass because it can break.
      Remove window regulator electric drive retaining screws through holes.
    5. Remove window regulator electric drive (23394) from front door power window regulator.
    6. Raise front door window glass to full up position by hand and secure with tape.
    7. Go to Step 5.
  2. Remove front door trim panel and front door trim shield. Refer to Section 01-05 .
  3. Remove front door window glass as described.
  4. Disconnect window regulator electric drive harness connector.
  5. NOTE: Use care not to enlarge sheet metal holes in the door inner panel.
    Remove two 1/4-inch rivets retaining lower bracket of front door power window regulator to inner panel. Use drift punch to knock out center pins for each rivet. Using a 1/4-inch diameter drill, drill out remainder of rivet.
  6. Remove three window regulator electric drive retaining screws from inside door to remove window regulator electric drive from front door power window regulator.
  7. Remove two window regulator retaining nuts.
  8. Remove front door power window regulator from front door (20124).
Installation
  1. Lubricate regulator mechanism with Teflon® Lubricant E7FZ-19590-A or equivalent meeting Ford specification ESB-M1C111-A.
  1. Install front door power window regulator minus motor (23208) into access hole in inner panel.
  1. Position front door power window regulator using upper studs and tabs on window regulator electric drive mounting bracket.
  1. Install rivets retaining front door power window regulator to door inner panel (1/4-20 x 1/2 inch screw and 1/4-20 nut and washer assemblies or equivalent metric fasteners may be used).
  1. Install two upper front door power window regulator retaining nuts.
  1. Install window regulator electric drive with three screws. Do not overtighten screws.
  1. Connect the window regulator electric drive harness connector.
  1. Install front door window glass.
  1. Adjust front door window glass as described.
  1. Install front door trim shield and front door trim panel. Refer to Section 01-05 snorkelbobby_38.gif
2answers
1helpful
How to remove the door panel of a 2004 alero
Check out this video it's a pretty good description of how to fix it.
http://pontiacremembered.com/blog/1aauto-com-fix-power-window-regulator-pontiac-grand-am-olds-alero-1999-06/
How to replace window regulator on 1999 jeep grand cherokee passenger side front
sorry I don't have much on this one. But, once the door panel is removed, you need to disconnect the glass from the regulator. I can't remember... but I think it is held on with U clips. They are just pushed in on the back side of the trolly. Too release them just push to one side. (see pic)
2218041.jpg *****NOTE: this is from another vehicle but the pin is the same...in the pic. the pin is being pushed back into place.
push the glass all the way to the top of the door and tape it there. Unplug the motor, unbolt the regulator and remove.
4803164.jpg (Im pretty sure that year had 2 pins to hold in the door glass, if I'm wrong you will clearly see 2 X 10mm bolts holding the glass to the regulator)
hope this helps.
7helpful
I need a left front door/window schematic on line for a 99 Dodge Durango. I need to see how to put it together.
Front Door
  1. Remove the door trim panel.
  2. Remove the water dam.
  3. Remove the inner and outer door belt weatherstrips.
  4. Lower the window to the full down position and align the glass regulator arm with the access holes in the inner door panel.
  5. Remove the front glass run channel.
  6. Remove the nuts attaching the glass channel to regulator arm.
  7. Separate the glass and lift it up and out.
  8. Disengage the power window motor wire connector from the door harness, if equipped.
  9. Loosen the bolts in slotted holes attaching regulator to door inner panel.
  10. Remove the bolts attaching window regulator to inner door panel.
  11. Remove the regulator through the access hole in the inner door panel.
  12. Installation is the reverse of removal. Tighten the nuts attaching the glass to the lift plate to 7 ft. lbs. (9 Nm).
Power window regulator mounting—Dakota, Durango
Window regulator removal—Dakota, Durango
Posting more on next post for door panel removal and installation.
1helpful
2answers
Need to replace a broken window on rear passenger 1999 jeep chero
This information can help you to fix it:
- Section-08s-Power-Window-Systems-Ewj8s
- Section-23-Body-ewj23S (Rear Door, page 41 and next).
Good luck (remember rated this help).
1helpful
Replace front passenger power window motor
not hard at all remove the door panel and you will see 5 bolts with a slot so you do not have to remove the bolts just loosen them. There is 2 clips that hold this to the window remove them. The hole thing will come out. Look on E Bay buy a new window regulator $40.
Top Jeep Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jeep Expert? Answer questions, earn points and help others
