Question about Haier HLP21E Top Load Washer
Why will Haier HLP21E drain following wash cycle, but not drain following rinse cycle/before spin cycle?
This has happened since the drain pump was repaired. Pump pumps but it seems like the drainage motor (not pump) might not be operating correctly.
  • Haier Master
  • 744 Answers
Hello Michael;
My name is Peter. I am a retired field service appliance technician.
It sounds like your system just needs a good cleaning. Soap film will build up on the draining system components. You need to clean your float and insure it moves freely and makes contact with the float switch which turns on the pump. You may also need to disassemble your pump for cleaning.
There are products available for cleaning clothes washers, but these need to be used on a regular bases. I do not think they can clean enough to solve your current problem. Use after you have cleaned.
Posted on Dec 03, 2014
  • 1 more comment
  • Michael D Dec 04, 2014
    Something got stuck in the drain pump and the propeller broke off its axle. I was able to get it back on and pumping but I did and continue to smell burning. Could the pump be bad even though it seems to pump in one cyle? Also, any idea where the float is on the model?
  • Peter Goodwin
    Peter Goodwin Dec 04, 2014
    Hello Michael; You have already purchased a pump you probably did not need. The burning smell identifies the problem. If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all. The belt part number is 1225416. Cost $7.00.
    THANKS PETER! If this doesn't do the trick, still thanks so much for your attention and help. Hopefully this'll do it.
Why doesn't Washer drain water in spin cycle.
If it drains OK during wash and rinse cycles, then the controller is not turning the pump on for some reason.
Aug 05, 2014 | Haier HLP21E Top Load Washer
Washer tub does not move to spin or wash
You either have a bad solenoid, timer, loose belt, or water level sensor.
Dec 15, 2013 | Haier HLP21E Top Load Washer
Haier HLP21E Top Load washer keeps beeping & blinking after water intake. It will rinse out the water when 'rinse' pressed. However it does not 'spin' but instead all three orange lights start blinking &...
No spin with alarm means the unit is out of balance.
The troubleshooting manual reads:
"The safety switch acts. The
spinning cannot work (The
WASH, RINSE and SPIN
indicator flash and alarm goes
off every 10 seconds). If
trouble cannot be solved after
alarming, it will alarm again
every few minutes."
To solve this the load must be balanced:
Make sure to level the machine on a solid floor. Also you may have to redistribute the clothing in the tub for even weight distribution.
Sep 28, 2013 | Haier HLP21E Top Load Washer
Haier model HLP21E. The wash cycle doesn't seem to do anything but the rinse cycle and spin cycle work well.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Click this link: Inlet valve
Jun 25, 2012 | Haier HLP21E Top Load Washer
It doesn't spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Haier HLP21E Top Load Washer
The water will not pump out and it will not spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 21, 2010 | Haier HLP21E Top Load Washer
Won't spin or rinse... hlp21e
Washing Machine2_bing.gif does not Pump or Spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
heatman101
Jun 11, 2010 | Haier HLP21E Top Load Washer
Spin cycles doesn't work, tub full of water
HLP21E Haier Portable washing machine will not spin and drain water
Jul 08, 2008 | Haier HLP21E Top Load Washer
Haier HLP21E Top Load Washer Logo
142 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
