Question about JVC Televison & Video
I have an 8 year old jvc hd61z456 tv. The picture is dark even after replacing he lamp with 2 new ones. Each time the picture is dark. Is it a bad ballast?
Installed 2 new lamps. Both lamps produce a really dark picture and night scenes on screen can harldy be seen
  • Larry Rubinoff
    Larry Rubinoff Dec 03, 2014
    How do I do that? And do I rule out a bad ballast? Sorry for previous comments if they came thru.
    Master:
  • 373 Answers
Test the voltage to the bulbs and see if it meets specs. May be a power supply problem.
Posted on Dec 03, 2014
  • Larry Rubinoff
    how do I do that? Do I now rule out a bad ballast?
Tv won't come on
Unless the arc tube is bulged--or cloudy--you cannot really tell by looking. This does sound like a bad lamp, probably # CL-110.
Apr 03, 2014 | JVC Televison & Video
JVC HD-56FN97 when turned on blue light is solid,red ligt blinks a few times and goes out. My picture is very dark despite adjustments I make in the menu, any help or feed back apreciated.
The set does use a lamp for a light source and average life is 2 years or 2000 hours---many lamps before they actually fail get to be darker.
Dec 04, 2012 | JVC HD-56FN97 56" Television
JVC HD-52G886 HDTV Television screen is dark
usually it is the lamp this set uses, has it been replaced or is over 2 years old?
Oct 29, 2012 | JVC HD-52G886 52" Rear Projection HDTV
Turn set on picture is dark.. if I leave the TV on.. in several hours it's viewable.
I have seen several Samsung's including 3 that were only a few months old at the time where it was the lamp---one was so dim it was very hard to even see the picture or that the screen was lit.
Two suggestions here: One of course would be to buy and gamble and replace the lamp.
What I found in two of the three cases was when I removed the lamp the glass pillar inside it was "bent" at a angle from heat or a natural defect--in both those cases a new lamp cured this dim picture issue.
Set will monitor the lamp and if too dim may shut set off or even blink for a prolonged period of time.
If the lamp is over 2 years or age (average life) or was replaced with a non-Samsung lamp you are going to have to take the gamble to try another one.
Inspect the lamp---that pillar supports the filament and if bent the lamp is suspect at best.
May 20, 2012 | Televison & Video
Have a jvc projection tv picture is to dark how can i correct this
How long is ur tv projection lamp been inside this tv.If the tv projection lamp been inside the tv like 1 1/2 or 2 years and watches tv everyday like 4 or 5 hours daily.The tv projection lamp life are ending.Replacement of the tv projection lamp,will solved this problems.
Dec 28, 2010 | JVC HD-61Z786 61" Rear Projection HDTV
Picture is very dark
its probably the lamp going bad. dark picture is a pre-cursor to failure. these lamps are supposed to last 2-4 years but for some reason the mitsubishi ones never do. you can replace the lamp yourself, and if it is going bad, you can cool it down, pull it out, and you will see it will look kind of bulged or white in the bulb part. instructions are in your user manual. if it is under a year old, mitsubishi should still cover it. if its just over a year, you can try to call them and complain and maybe they'll back it up. let me know if you need further assistance.
Jun 06, 2010 | Mitsubishi WD-65735 Television
I Have JVC Nodel HD52G887 and no picture after I heared a pop sound while watching. Can someone come and fix it and how much?
You will have too replace the lamp, I have the same tv. The lamp costs around $200- they forgot to tell me the lamp runs on a timer and then when the time is up it goes and will need to be replaced. My tv is 3 years old and I am about to order my third lamp. Just remember after you replace the lamp that you go to the menu and "reset" the timer or it will not work even with a new lamp- all a money game
Sep 24, 2009 | JVC TS-CL110UAA Projector Lamp
Picture is still dark after new bulb
when you fitted the new lamp did you reset the lamp burn time??
if not the tv still thinks it has the old lamp fitted!!! clever these tv's
Jul 08, 2009 | JVC HD-61Z456 Television
Dark picture on 62" lcd
how old is the lamp , if is about a year old need a newone
May 12, 2009 | JVC HD-61Z575 61" Rear Projection...
I have a JVC tv only 1 year old and the picture is getting dark.
Sorry to tell you but JVC is a well-known un-reliable brand and if it's cheap, probably even worse. U may have screen burn from leaving a games console on while plugged into the tv, even if its not showing the game, it will burn it onto the screen. :(
Mar 24, 2009 | JVC AV27F476 27" TV
Televison & Video Logo
259 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
