How do I fix the no sound on my tv from hmdi input
Tried turning up volume but no sound at all and remote does not work properly
    Scholar:
  • 174 Answers
Do you receive any kind of sound , for example try connecting other than using the hdmi , if there's no sound , the sound card has blown, if their is, then the device you're connecting to the HDMI is faulty .
Posted on Dec 03, 2014
My th-42px80u Panasonic plasma tv has no picture or sound red light stays on
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 17, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
Plasma screen is blue it has been taken off wall think something may have been touched/flicked
Blue screen means no input. First make sure the HMDI cable and the device you get your golf results from is properly sending the signal. After that, you can then make sure that the TV screen itself works right by using the remote to change volume and ensure that it the screen shows the volume up graphic display. Once you know that is in working order, make sure you are on the right input channel by looking at where you input is plugged in to and setting the TV to that input via the remote. You can repeatedly hit the input button to cycle through the inputs if you want to be sure. (there are 8 of them) The last thing you can try is assume that the input you are using is bad and switch to another. (Go from HMDI 1 to HMDI 3)
Jun 14, 2014 | Panasonic Viera TH-42PZ80U Plasma TV
Samsung tv ct21m17mj
follow this steps and fix it. GOD BLESS YOU
  1. Make sure all power cords are connected.
  2. Try pressing the enter/play key.
  3. Make sure the TV is turned on and the input is set properly.
  4. Make sure the TV source is set properly on the TV (This is probably done on the screen; Check your TV manual).
No sound:
  1. Check if the TV and Amplifier (if connected) is turned on and set correctly.
  2. Check if the TV, DVD player and Amplifier are connected properly.
  3. Make sure the TV, DVD player and Amplifier volume are not set to Mute.
  4. There will be no sound output during Reverse Play / Pause / Step / Slow / Search.
  5. If the DTS soundtrack is enabled in the DVD Disc Menu, but you are using Stereo Analog audio, the sound will not work. Try switching the soundtrack to Dolby 5.1 or PCM mode in the Disc Menu.
Jul 17, 2013 | Televison & Video
Wont change input
sounds like the volume up button is stuck on the tv , try fiddeling with it on and off , because it is locked down the other controls will not function
Feb 07, 2012 | SNK Skyworth SLC1963A 19 in. LCD TV/DVD...
When I turn on the TV with my remote the voice on the TV is not being heard. I press the volume all the way and no sound is heard. Could it be that I need a new remote
Well there are many problems I can see here.
First we need to see if it's the TV, Remote, or and Input problem
Do this:
1. Go to the TV and turn the volume up manually. Most TV's should show the volume bar going up and down. (If this fixes your problem then your remote either needs new batteries or the volume buttons are broke and you need a new remote)
2. If you hear nothing from step one then : Replace the batteries in the remote (This most likely is not the problem if the TV will still turn on with the remote)
3. Make sure your TV is not muted. You can usually do this with the remote. (After replacing the batteries) Seldom is there a physical mute button on the TV.
4. If you do all this and still have no sound then you need to check your inputs. First switch over to some other thing. Example: If your watching satellite switch over to a DVD player or a video game system. See if the sound works when you try to use those items. (If this fixes the problem you need to look at the back of your TV and determine if some wires have came loose.
This is all for now. There is a lot more I could go on with, and if the problem persists feel free to comment and I will try to get back with you.
Nov 30, 2010 | Computers & Internet
Have no sound from VCR, cable hooked up properly, picture is great. TV is brand new.
Connect RCA cables yellow, white and red from VCR to TV. White and red are sound. Select TV input where VCR cables are connected using TV remote. Try different tapes. Turn up volume on TV.
Aug 12, 2010 | Toshiba M755 VCR
Sound issues
make sure your audio out jacks are pluged into auidio in on bose and make sure it is pluged in under tv audio on the back of bose
Apr 14, 2010 | Bose 3 2 1 GSX System
Hooked up ps3 using hmdi cable worked not working now using the
mpc heesman1 might be right...
However. I´m inclined to think that you did change the input on your TV. So your problem is another, this is what you have to to to reset:
1. Unplug the HDMI cable from both the TV and PS3.
2. Plug in the AV MULTI OUT cable (the red, white, yellow one provided along with the system) to both your PS3 and TV.
3. Set the TV input to the correct one and turn it on.
4. turn on the PS3 with the front button but DON´T release it, keep your finger on it, until you hear a second beep, thats when you release the button, the PS3 will start to identify what it´s connected to and will display it on your TV.
Hope it helps.
Jan 12, 2010 | Sony Playstation 3 (PS3) Console
Mintex 37 inch wide screen. remote is working however cannot change channel, input source or volum. only turns tv off. The buttone on tv doesnot work connot change input source or volume
Check if the remote is in TV position, that is, because most of the remote controllers have the feature that you can program them for use with another devices. Make shure that one button that says "TV" in pressed and released once before you try to change any function on the TV.
Jun 27, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
