Question about Kenmore Washing Machines
I have a Kenmore 90 Series washer made by Whirlpool, model 110.26902690. I'm trying to remove the cabinet and can't get the control panel off. I found two screws in the very top corner
Removed screws and tried to move control panel/ Tried to find hidden clips, etc.
  • 1 more comment
  • Lanny Cotton Dec 03, 2014
    Where is the rest of my question?
  • Lanny Cotton Dec 04, 2014
    Maybe the top will slide forward? I can't make it slide forward. The back panel goes the entire height of the machine in one piece. It has several things attached to it and obviously not meant to come off. Either the control panel slides forward or the top of the cabinet slides forward. I have the screws out of the control panel and I can't make anything move.
  • Lanny Cotton Dec 05, 2014
    I found the problem. This washer has plastic end caps on each end of the control panel. The screws I needed to remove are under these end caps. To remove the end cap you grasp the top of them and pull forward, only the front of the end cap comes off. The screws are then visible on the FRONT of the control panel. Remove these screws and you can left control panel.
  • 682 Answers
Remove screws then slide top backwards .now you should gain access the the front panel usually held on by 4 Torx screws.
Posted on Dec 03, 2014
Testimonial: "I included in my question that the control panel will NOT slide backwards! Unfortunately, all of my question doesn't show up."
I have a series 90 Kenmore top loading washer model number 110.26912691. At the end of the wash cyle it began to make a loud buzzing noise. I've tried to reset, the water will fill, but the washer...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11026912691/0582/0153200?pathTaken=
and you'll see a list of major sub-components with diagrams and parts.
Initial suggestion is a Lid Switch:
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Dec 14, 2010 | Kenmore 15864/15862 Top Load Washer
I have Kenmore 90 series washer its lid switch is not working I want to replace my self how I can fix it model # 110 20922991
remove the top control panel,there are 2 brass colored clips that hold the cabinet on,remove these clips and tilt the cabinet forward to remove it,then you can replace the lid switch
Oct 14, 2010 | Kenmore Washing Machines
Kenmore 90 Series - Heavy Duty Super Capacity Washer - Washes fine but it's getting stuck at the point when it's supposed to drain & spin before the rinse cycle.
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Aug 26, 2010 | Kenmore Washing Machines
Kenmore washer 90 series will go through the cycle, rinse, but will not enter spin cycle, or drain the water from the basin. What could be wrong?
Aug 24, 2010 | Kenmore Washing Machines
I have a Kenmore 90 Series Washing machine that will not spin or
Jun 26, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 90 series Model 110 20902 990 does not drain or spin. The lid appears to be fine. I have tried depressing the switch with screw driver but it does not work.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20902990&pathTaken=partSearch
If it works, the Lid Switch is a relatively inexpensive part (about $37) and only requires you to access the console and remove the cabinet.
May 26, 2010 | Kenmore 24032\24036 Top Load Washer
Water-level switch shorting out
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
It has a section on testing components including the water level switch:
See the following for how to release the console and cabinet.
Apr 23, 2010 | Kenmore 24032\24036 Top Load Washer
Our Kenmore 90 Series, model 11022912100 will fill with water & agitate but will not spin or empty water
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=11022912100
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If it works, the Lid Switch is a relatively inexpensive part.
Jan 28, 2010 | Kenmore Washing Machines
Kenmore model 11024932200 series 90 wont drain
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.24932200
I'd look at the Top and Cabinet section for the Lid Switch.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Following is a description of how to remove the cabinet.
If the problem is the Lid Switch, it's a relatively easy part to replace.
Oct 03, 2009 | Kenmore Washing Machines
Hello, my Kenmore 90 series washer is shaking badly on spin cycle and we discovered the tub inside seems to be rather loose, does this mean something may have come unhinged?
This assumes that you have a basic Kenmore2.gif / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
Also see the Whirlpool2.gif / Kenmore installation and maintenance manual.
Thefirst thing that I'd do is pull the cabinet and check the levelingsprings and plate pads. These are designed to keep the tub frombouncing against the cabinet during the spin cycle.
The Sears diagram shows where the springs and pads are located.
The top load Whirlpool / Kenmore washer has a tub that is designed to somewhat "free-float" The springs and pads keep it from getting too out of control. If one or more of the springs or pads is loose or damaged, the tub can contact the cabinet making a very loud sound.
Oct 01, 2009 | Kenmore Washing Machines
Washing Machines Logo
56 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
