Question about Health & Beauty
Can I get a replacement bulb for my model 116
Asked a nurse but she had a different model
Hi I need n cover letter for cv .. Auxiliary nurse
need to notify the requester of cover letter as to what the particulars are since their are many reasons for a cover letter and many different types of nurses
Oct 17, 2016 | Baby Care
When the results coming out
would need more information but for exam lists notify the county/state/or company that gave the test
Jul 25, 2016 | Computers & Internet
Kenmore vacuum cleaner model no. 116. 5861279 belt replace
Do you need the belt or the directions for changing the belt? Sears Parts Direct has the manual for the 116.58612790 here: http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Vacuum-Parts/user-manuals/manual-downloads/Model-11658612790/0582/0640500?modelNumber=11658612790&diagramPageId=&documentId= . The direct link to the manual is http://c.searspartsdirect.com/mmh/pd_download/lis_pdf/OWNM/L0802691.pdf . See pages 14-15 of the manual.
To replace the belt, you need to remove the light cover and then the light bulb. Press in the sides of the cover and lift to remove it. the bulb needs to be pushed in and then turned couter-clockwise. Remove the cover screws. Then flip over the Power Mate and use the flat blade screwdriver to release both tabs. Turn the Power Mate back to right side up and press on the handle quick release pedal and lower the swivel. Tilt the cover forward until it snaps free. Carefully, use your screwdriver to pop the brush supports free on both sides to remove the brush. Slide off the old belt. (If needed, slide off the brush supports and washers. Clean the brush before reassembling the unit. Then replace the brush supports and washers.) Push the belt on motor drive and then onto the brush sprocket. Push the brush supports back into place on the base. (Make sure that this isn't assembled upside down.) Then line up the front of the cover with the base and tilt the cover back into place. Press firmly until you hear both sides click into place. Replace the cover screws, light bulb and bulb cover.
The belt is available here: http://www.searspartsdirect.com/Kenmore-Vacuum-Parts/742024/0020/116/Model-11658612790/0582/0640500.html . This is part number 5285; it's the direct replacement for the original 742024 belt.
I hope this helps.
Jun 16, 2016 | Kenmore Vacuums
Change AC Lights bulb
They are tiny LED lights soldered onto a circuit board. Order the whole AC control panel from Mopar Wholesale.com for $116. Trust me, there are no bulbs that are easily replaceable at all. Even if you soldered new ones on correctly, no one knows the proper voltage of each LED, so mine burnt out IMMEDIATELY after two hours of delicately fixing the thing.
Nov 21, 2012 | 2005 Jeep Grand Cherokee
I have a 1999 corolla that for no GOOD reason (lol) the directionals and hazards stopped working last night. they dont even light up, or like when a bulb blows, its steady- not here. went to replace fuse-...
sounds like the flasher burned out, it's on the fuse box , part # is Autozone
Hazard Warning Flasher
For your 1999 Toyota Corolla 1.8L EFI DOHC 4cyl Part Number:
LF12
$6.00
Aug 24, 2010 | Toyota Corolla Cars & Trucks
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
Hi, my power head is not working on model 116 5416083 and I cannot open it up. I think there is a gasket that needs replacing.
If you press on either side of the raised top light cover it will come off. Then you will be able to see the light bulb and two screw heads. Remove the two screws and the top cover of the power brush will lift off from the base and you will be able to access the belt. Here is a link to the belt you need:
1165416083 Replacement Belt
Dec 03, 2009 | Vacuums
How to replace the auto rewind button on Hoover canister vacuum.
116-...... usually indicates a Sears/ Kenmore model vac Please clarify
Sep 17, 2009 | Hoover Vacuums
Kenmore vacum wand power cord
http://www.vacsew.com/vacuum-cleaners/kenmore-vacuum-parts.html/
Try here
Jul 16, 2008 | Vacuums
Health & Beauty Logo
83 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
