Question about Cell Phones
How do I disable the safe mode on My Boost Mobile Sharp
How do i turn safe mode off
Safe not now is not so necessary, you can use this applock and make safe only the stuff you want, like hiding some photos or locking some apps, it can also provide anti-thief, private browser and boost function.
LEO Privacy Applock Boost Hide Android Apps on Google Play
Feb 15, 2014 | Sylvania Tablets & eReaders
Smart car keeps cutting out whilst driving
If all power is lost in the car, it could indicate a bad battery connection, bad wiring, or loose main wire harness, etc.
If a warning light comes on - it may be going in to Safe Mode.
Safe mode is the set of parameters that the car will use if it believes there
is a fault with the engine that could cause irrepairable or long term damage.
Generally it is an excess in expected boost pressure entering the engine.
This excess boost from the turbo tends to happen for 4 reasons.
The boost pressure sensor (MAP sensor) is faulty.
The wastegate is seized shut or slightly open.
The wastegate actuator is faulty.
The air line to the wastegate actuator is damaged or off.
Obviously, if the sensor is faulty, it will tell the ECU lies about the boost pressure.
If the wastegate assembly fails in any way it will fail to open to bypass the turbo.
The turbo will continue to spin up, increasing the boost pressure, causing the fault.
Initially I would suggest disconnecting the battery for 5 minutes (make sure you know your
radio code before doing this), this will turn safe mode off and your car should run normally
again. Drive home with a bit of care, you may find the car might never do it again. If it does
go into safe mode again, you know you have a real problem and not just a glitch.
Best to contact your dealer and have it checked out.
Nov 03, 2011 | Smart fortwo Cars & Trucks
How to flash to boost mobile
You can Flash the Mobile from the Network lock using the Unlock code...Software Leads to Data Lose....But Unlock code is safe and secure none...You can use the Unlock code at reliable cost at here
http://www.onlinegsmunlock.com/htc-evo-4g/rs7wp9/ and Unlock the HTC EVO 4G...then You cannot use the Boost Mobile..You can use Only GSM Network Sim Card like T-Mobile,AT&T network....Boost is CDMA Network so you cannot use....
Jan 10, 2011 | HTC EVO 4G Smartphone
Hi my smart roadster has recently and suddenly developed a lack of power and the turbo boost guage moves ver little -does this mean it needs a new turbo?
This could also be Safe mode, the below text may help you.
What Is Safe Mode?
How Can I Tell If It Is Safe Mode?
If your car suddenly lost power but before that you didn't notice any problems.
If there isn't vast plumes of smoke coming from the exhaust.
If the oil level is OK. If you had all 3 of those, it is almost certainly safe mode.
What Causes Safe Mode?
How Can I Fix It?
Wait for the car to cool down and see if the wastegate arm moves freely.
Use the search function of the site for "wastegate service" to see how
you can possibly free up the wastegate assembly which could be seized.
Check the pipe work to and from everything to rule out leaks.
Try and borrow a MAP sensor to test.
As a last resort, book in with a smart specialist who will diagnose the problem
Dec 31, 2009 | 2008 Smart fortwo
My htc tattoo lags, somtimes it stops for 10 sek, freezes up.. what can I do?
delete some data from phone and change your memory option to memory card..........
Dec 05, 2009 | HTC Tattoo Cell Phone
The safe mode is on how do I remove it
Using the safe mode feature on your T-Mobile G1 will allow you to easily pin point an issue you are experiencing with the device. Follow these steps to enable and disable the safe mode feature.
  1. HOW TO TAKE YOUR T-MOBILE G1 OUT OF SAFE MODE
    If you have found yourself in safe mode and don't know how to turn it off, or if you are finished troubleshooting, turn your device off as you usually would. When you restart the T-Mobile G1 should not be in safe mode anymore.
  2. If the T-Mobile G1 is still in safe mode when you restart, there is something else wrong with your device. At this point you will need to contact technical support to assist in diagnosing the issue.
Nov 14, 2009 | HTC G1
1 Solution for "unlock code for sidekick lx to use with boost mobile"
i dont think u can use Boost on an unlocked cell phone other than Nextel, bcuz Boost and Nextel are the only phone companies with walkie-talkie and in order 2 use an unlocked phone with Boost the phone is going 2 need a direct connect button
May 26, 2009 | Sharp Sidekick LX Smartphone
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
