Panasonic plasma 42 inch. I got 7 times led blinking problem.
    Master:
  • 388 Answers
Doesn't bode well for your television.
Posted on Dec 03, 2014
jdbouncer
  • 72 Answers
SOURCE: Philips 42PF9630A 42 in. Plasma 42 in. Plasma
Ok 7 red blinking led, remove the back cover of the TV. Looking at the power supply in the upper left of power supply. If everything is working fine you will see a solid green led if there is an error, you will see this light blinking also. Right below this led on the power board you will see a list of numbers 1-13 this will give u the problems that this led flashing problems are. More and likely u will have a problem with VSET or VSCAN. Which is connected to the Y-Main and Y-buffers,( the board that is too the left of the power supply if u look on the small print on this board you will see that it reads. 42HDV4 Ymain and the 2 small boards connected to it are Y buffers. To be sure that this board is bad if the TV keeps going into error protection. unplug the power supply and wait for the led to stop flashing. Disconnect the cable that plugs into Y-Main from the Power Supply. It should stay running. If u remove this board and look underneath u should be able to see where this board is getting hot. Easiest fix is to order a replacement. Y-main assembly.
Posted on May 05, 2008
SOURCE: black line in a 42 inch panasonic plasma tv
I have a 2 black lines. One goes horizontal and one runs vertical. Is this something I can fix?
Posted on Sep 26, 2008
SOURCE: my panasonic plasma tv has some error! the red led
Panasonic sent a repairman out with the correct part after telling them about the seven blinks. The unit was out of warranty. They rock. Call 800-211-7262 or 800-524-1448 1
Posted on Oct 06, 2009
djchillsnyc
  • 152 Answers
SOURCE: panasonic viera tv won't turn on. Power light
hello, you have a either your su, sd or sc boards fualty and it is a driver sos1 thats what the manual reads the best thing to do if your not electronically inclined or able to fix it is to get a service manual and make sure it is for your specific model and size you will find what the 7 blink codes mean, on my side i have a 42 in pana the service manual for this set and your is similar so since it is not the same model i cant tell you exactly what the truoble is but your best bet is to find a service manual find the 7 blink fualt then without getting ripped off you will know what the service man needs to do if you dont know or cant replace the parts yourself that is besides having to download firmware from your computer to a sd card and update your set but you need to solve the blinking code first it may solve the entire issue. the tv should come on when you resolve the blink codes or replace the fualty board or boards
Posted on Oct 14, 2009
  • 418 Answers
SOURCE: panasonic 42
Loss of power from power supply. Usually bad power supply.
Posted on May 02, 2010
TH 42PV8H A MY TV POWER NOT ON RED LED 2 TIME BLINKS
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Mar 16, 2016 | Panasonic TH-42PV8H 42 inch MultiSystem...
Panasonic TC-42px14, 12 blinking LED
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Mar 15, 2016 | Panasonic VIERA X1 series TC-42PX14 42...
PANASONIC PLASMA HD 42 INCH WONT TURN ON JUST BLINKS 10 TIMES
10 blinks of standby light with Panasonic Plasma indicates:
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
For more details visit the site named [Electro-help" The keyword to search is "Electronicshelponline"
Jul 03, 2012 | Panasonic TCP42C2 42 in TV
Have panasonic viera 42inch plasma led blinking 7 times
7 blinks, with plasma 42 in panasonic, this code means you have 3 boards that need to be checked
su , sd, sc boards. theres a issue with these boards, its techinical
but i .. hope this helps.
Oct 26, 2010 | Televison & Video
My panasonic plasma tv has some error! the red led bliks 7 times then pause and then 7 blinks again. what i can do? panasonic th-42pz70e
Sep 12, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
Panasonic TH-42PZ700U Blinking Light Of Death
Panasonic sent a repairman out with the correct part for free, even though the unit was out of warranty. Call 800-524-1448 1 or 800-211-7262
Sep 08, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
After turn ON , blink 7 times and go off
Pamoya,
I ahve found a PDF in realtion to the "Blinking Light of Death",Panasonic has several problems. I have the same Plasma th42pz700u. the LED is blinking 7 times then repeats. The possible problem fron the PDF is this. Its in trouble mode SC floating voltage SOS. with defective boards. the boards are mostlikely one of the following depending on the flow chart. SC, SU,SD,or the P board.
Hope this helps.
Nov 18, 2008 | Panasonic TH-42PZ700U 42 in. Plasma...
3 months ago Led blinks 7 times now Led blinks 6 times
Sorry to hear that. You could fix it with Best Buy or the warranty service repairman recommended by Panasonic.com
I have a client that had used one of the panasonic repairman to fix the same problem that you have about a year ago,the TV is good ever seen.
I am in the A/V installation business, my recommendation(Pioneer Kuro Plasma TV or Sharp LCD.)Very good track records from my clients.
solutiondoct
Nov 03, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
Top Televison & Video Experts
