Question about JVC Audio Players & Recorders
HOW TO ADJUST ROTATION ON DIRECT DRIVE JVC TURNTABLE
  • CAROLE MCCARTHY
    CAROLE MCCARTHY Dec 05, 2014
    THIS IS A DIGITAL TURNTABLE WORKED FINE UNTIL WE MOVED MIGHT HAVE GOTTEN JIGGLED THE RED LIGHT IS BLURRED AND MUSIC IS OUT OF SYNC
    Renaissance:
    An user who is expert in 3 categories / brands.
  • JVC Master
  • 924 Answers
If you're talking about the speed of the platter, there will be a pitch control knob to increase to decrease the speed. If the adjustment still doesn't control the speed correctly, the turntable will require repair. If you require more assistance, or would like to inquire about repairing your JVC, please visit my website at audioserviceclinic.com. Thank you.
Posted on Dec 11, 2014
4 Suggested Answers
digger odell
  • 8 Answers
SOURCE: repairing
Try putting 1 only,drop of sewing machine oil on motor at shaft and let it soak in while manually rotating shaft being careful not to get oil on anything else and see if this helps.
Posted on Jul 30, 2010
dunnbiker
  • 8546 Answers
SOURCE: I have a Technics Quartz SL-10 Direct Drive
Technics Preamps on eBay:
http://shop.ebay.com/i.html?_nkw=preamp+technics&_sacat=0&_odkw=preamp+technics&_osacat=0&_trksid=p3286.c0.m270.l1313&_rdc=1
There are, of course, many non-Technics PHONO preamps out there.
http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
If you already have the central receiver and amplification part nailed down you really only need a Phono Preamp to boost and shape the output of the Phono Cartridge. Otherwise you're paying for source switching, volume and tones controls you don't need.
Posted on Mar 04, 2011
djredskyy
  • 670 Answers
SOURCE: I have JVC L-FX2 fully
if your looking for a needle. any music store should have them for you, even old record shops
Posted on May 08, 2011
I have a Philips 614 record player which does work except the turntable no longer rotates. I know my model does not use a belt. What is the part called that is required to repair it? Thank you.
A direct drive turntable which has no platter rotation could be caused by any number of faults on it. Only a trained technician would be able to sort out the cause after they have looked at it and carried out tests.
Aug 17, 2017 | Philips Audio Players & Recorders
Turntable running slow
Most of the 'direct drive' turntables have a "pitch control" dial - you turn this dial until the black bars 'stop dancing' and hold still. There should be a little window with an orange neon light where you can see these black lines and adjust the speed. You may have to adjust it everytime you switch from 45's to 33's.
Aug 23, 2014 | Audio Players & Recorders
Adjust pitch not working on PS T1 Sony
Try looking underneath the turntable. There might be two speed presets one for 45 and one for 33. They could be covered up by stickers.
Jun 04, 2014 | Sony Audio Players & Recorders
Auto adjust
You could have got the Belt in the wrong position. If correct try looking underneath the turntable for small presets. They might be hidden or covered up. If you can't see them you will have to take off the bottom and look on the PC board for them.
Apr 27, 2013 | JVC Audio Players & Recorders
I have JVC L-FX2 fully automatic direct drive turntable.I need a needle.It was broken...how can i find it?please help...
May 08, 2011 | JVC Audio Players & Recorders
My LPDock turntable is surging (speed up/slow down) after recording 40+ albums to files. Is this a mechanical problem or something I could adjust?
There are two possible causes, depending on if the deck is belt driven or direct driven. Sorry I don't know which with yours.
If it's a belt drive then the belt has come lose and should be replaced. Or the motor or power supply to the motor is faulty. Make a note of how the belt fits before you replace it.
With a direct drive it's either the motor or power supply to it that's got the fault.
Mar 06, 2011 | ION Audio Vinyl Recording Turntable
Repairing
Jul 01, 2009 | Pioneer PL-990 Turntable
JVC - problem. The turntable does not move,
Most modern day turntables are semi-automatic. You move the tonearm from the rest post
over to the record and the platter will start turning. There is a small microswitch inside
either below the arm base or near. There should be a flat bar connected to the base of the arm
and this will actuate the microswitch. The switch is wired in series to the rotation motor.
Solution: 1. Obviously verify the belt is on. Take off the rubber mat and rotate the platter.
The rotation motor is on the left and it has a small brass spindle. The belt should
be visable through the holes in the platter. If not pull the platter gently up, there will
be some resistance. The belt wraps around a smaller inner ring on the underside
of the platter and the rotation motor spindle. If it is degraded it will be stuck to the
platter or fall apart. Generally there 3 common sizes. ( 21.4 / 23.6 / 25 inch) they
readily available on E-Bay, search term "turntable belt".
2. Obviously check power.
3. Check the microswitch, it should "click", verify with ohm meter.
4. Some turntables have a "cut" or stop function. The arm must return first to rest before
starting again, again the microswitch is the trigger.
Apr 07, 2009 | JVC AL A158BK Turntable
151 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
