Question about Craftsman 3/4 HP Chain Drive Garage Door Opener with Keyless Entry
Garage Door Opener Lights
Our light tabs are broken in each light socket of the two lights on our garage door opener. I can wiggle the lights and they work temporarily. The clicking still occurs when they are supposed to come on. Is there any solution to this problem besides buying a new opener? Other options appreciated.
  • tgogles Feb 16, 2015
    They sure were....ordered them from Sears through Amazon.com. Spent a whopping $6.44:) Our kind of fix!!
    Top Expert:
  • Craftsman Master
  • 48,468 Answers
Check with sears mine has replaceable sockets Water Filters Lawn Garden Appliance Parts
Posted on Feb 16, 2015
Testimonial: "They sure were replaceable! Only cost $6.44 for the both of them at Sears through Amazon.com!! Our kind of fix:)Using better appliance bulbs this time. I think this will help."
4 Suggested Answers
  • 217 Answers
SOURCE: Craftsman garage door opener
does the door open and close?
Posted on Mar 10, 2013
  • 217 Answers
SOURCE: Garage opener message "door moving"
there is a problem with the sensor
  • 217 Answers
SOURCE: craftsman 3/4 hp garage door opener
not sure, but see the users manual here:
http://www.manualslib.com/manual/32293/Craftsman-139-5399.html
When I open my garage door no lights come on. I changed out both lights with new bulbs, still no lights when I open or by manually clicking the Lights on the wall opener
Check the light sockets on either side of the garage door opener and make sure there is no corrosion on the contacts. If you see some corrosion unplug the garage door opener and scrape off the contact. Give that a try and lets see what happens.
Feb 21, 2015 | liftmaster Garage Door 1/2 Hp
I have a liftmaster fromula 1 GDO. The lights do not come on when the dorr opens. The lightbulbs are good. Any help?
There may be a switch up by the lights, it may just not be set to turn on when the door opens. Also I found on mine, the opener attached to the wall in the garage has a button that turns the lights on and off.
Dec 08, 2014 | Sears Craftsman LiftMaster Chamberlain...
How to open genie 1/2 hp garage opener for light bulb
Set a step ladder under the power head of the garage door opener so you can reach the power cord and the lens cover safely.
Climb the ladder and pull the power cord from the outlet in the ceiling. Press the two lens tabs in to disengage the lens from the power head. The lens tabs are below the opener rail on the upper corners of the lens. Pull the lens cover straight off of the power head.
Unscrew the light bulb from the light socket. Use a new 60 watt bulb to replace the defective bulb. Do not use a short neck bulb. Screw the new bulb into the light socket just as you would a regular lamp socket.
Slide the lens cover back over the front of the power head. Push the lens cover in until the locking tabs engage the top corners of the lens cover.
Plug the Genie garage door opener power cord back into the ceiling electrical outlet.
home light
May 28, 2012 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener Model 139.53515SR overhead lights stopped working. Checked bulbs and all connections. All seems O K. What could be the problem? When I tap the unit ,at times the lights will flicker like...
Unplug the openers and remove the bulbs. Using a small screwdriver pull out on the center contact in the light socket. Replace the bulb and plug in the opener.
Nov 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
The lights on my liftmaster garage door opener suddenly stopped working I have already replaced the old light bulbs with ones I know work but the lights are still not working.
Unplug the opener and remove the light bulb. Using a small screwdriver lift up on the center contact of the socket. Replace the bulb and plug the opener in.
Oct 18, 2010 | Sears Craftsman LiftMaster Chamberlain...
Lights do not work on the garage door opener. what could be the problem?
Unplug the opener and remove the light bulb. Pull out on the center contact in the light socket. Replace the bulb and plug in the opener.
Jun 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 3/4 HP Chain Drive Garage Door Opener with Keyless Entry Logo
80 people viewed this question
Top Craftsman Building Materials Experts
richie46
ray gallant
robert
Are you a Craftsman Building Material Expert? Answer questions, earn points and help others
