How do I remove an air connditioning unit - Heating & Cooling
  • 44 Answers
If its a central split system Call a professional. If its a package unit or window/ wall shaker and you cant figure it out you shouldnt be messing with it in the first place.
Posted on Dec 04, 2014
Air connditioning
  1. Ann, could you be a little more vague? It will be necessary to know some details before anyone can help you. Make, model, etc. does the fan blow air of any temp out the vents? Does the compressor turn? Check that the compressor drive belt is not broken. On a modern car there will be only one drive belt for the power steering, air conditioning, alternator and water pump. With the engine running if you do not see a belt turning I advise not driving the car until you can have it replaced as the engine could over heat and cause serious damage to the engine. If you are not familiar with underhood workings I have linked a youtube video that may help you find the belt. Start at 2:33 on the video. Good luck.
How to Fix Squeaky Belt figure out where the squeak is coming from
Aug 26, 2016 | Cars & Trucks
Tip
How to change a heater control unit/heater control ford puma
Ford Puma
What you will need:-
1.Phillips Screw Driver
2.Depending on what stereo system you have, stereo removal keys.
REMOVAL AND INSTALLATION
Climate Control Assembly/heater control unit/
Removal
1. Standard preparatory measures
Make a note of the radio keycode.
Make a note of the preset radio stations.
CAUTION:
Disconnect the battery negative lead.
2. Remove the radio.
3. Note:The control unit for the heating/air conditioning system, all operating knobs and the air distribution operating switch make up one assembly.
Remove the bezel/control unit.
1 Remove the screws on the top of the unit
2 Unclip the clips either side of the unit
Pull the bezel/unit forwards.
Disconnect the plug.
4. Unclip the air distribution shaft.
5. Remove the heater/air conditioning module and the fan operating switch.
Installation
1. Refit the components in the reverse order.
2. Install the radio.
3. Connect the battery ground lead.
Enter the radio keycode.
Reprogramme the preset radio stations.
Reset the clock.
Carry out a road test to enable the PCM to collect data.
4. Check that the heater/air conditioning operates properly.
on Jan 31, 2010 | Ford Focus Cars & Trucks
Carrier Air conditioners
change filter and clean outside unit with water. pull the outside fuze before cleaning.
Jul 29, 2012 | Heating & Cooling
I get a message to clean filter. I removed back but could not find filter. Cleaned all visible dust and reinstalled back. Worked great for 2 months and got message again. Next day worked ok again. ...
hi,
To clan the air filter you have to remove the projection unit.You can see the projection unit behind the lamp blast board.There are three air filters in this unit. You have to clean these air filters. I have added the picture which showa the location of air filters. If you can give your email address the i will sent the service manual. Which will help you to remove and clean these Air filters. Remember one thing remove lamp first then only remove the projection unit from the rear side.
OK
Apr 20, 2011 | Panasonic PT-52LCX65 44" HDTV
Heater core. where is it located and how do you replace it?
Heater Core REMOVAL & INSTALLATION For the removal of the heater core, which is located inside the heater-A/C unit assembly, first remove the heater-A/C unit assembly from the vehicle as described later in this section. Once the unit has been removed, use the following procedure to extract the heater core:
  1. Place the heater-A/C unit on a suitable work surface.
  2. Locate and remove one retaining nut from the blend-air door pivot shaft.
  3. To remove the top cover from the heater-A/C case, the crank arm must be removed.
  4. Disconnect the vacuum lines from the defroster and panel mode vacuum actuators and position them out of the way.
  5. Remove the 3 heater-A/C unit cover attaching screws, fastened upward at the defroster outlet chamber.
  6. Remove the 2 heater-A/C unit cover attaching screws, fastened upward at the air inlet plenum.
  7. Remove the 11 heater-A/C unit cover attaching screws, fastened downward into the housing. Then lift the cover from the heater-A/C unit.
  8. Remove the old heater core from the case. To install:
  9. Install the new heater core into the heater-A/C unit case in the same position as the old one.
  10. Place the cover onto the case and secure in place with the 11 retaining screws.
  11. Install the 2 heater-A/C unit cover attaching screws in the air inlet plenum.
  12. Install the 3 heater-A/C unit cover attaching screws in the defroster outlet chamber.
  13. Attach the vacuum lines from the defroster and panel mode vacuum actuators to the heater-A/C unit case.
  14. Install the crank arm and the retaining nut on the blend-air door pivot shaft.
  15. Install the heater-A/C unit assembly into the vehicle.
Oct 13, 2010 | 1990 Chrysler New Yorker
How to remove the air cell
  1. Turn off unit and unplug it
  2. Along the front edge there should be a thumbscrew, loosen until it is free
  3. Lift front cover from left edge
  4. Pull cell from unit
  5. remove screen from cell, it slides out from the top of the cell
  6. remove odor/ozone absorber, it is clipped into the back edge of the cell
You do not need to be afraid to set the unit on it's back or side, just make certain not to drop it.
May 23, 2010 | Oreck XL Professional Air Purifier
Unit releases xcessive amounts of water when
Part of an air conditioners job is to remove humidity from the air. The more humid it is, the moisture it will remove from the air. Some thru-the-wall/window air conditioners have fresh air vents. Ensure the fresh air vents are closed and make sure there is no air leakage around the unit & wall.
Keep your air filter and coils clean. If your unit has multiple blower speeds, use high speed during the more humid conditions.
I hope you find this information helpful moving forward. :-)
Apr 02, 2010 | Frigidaire FAC126P1 wall/window Air...
What is "Press Power Protect"?
Hi Lois,
Stereo sytems have a protection circuit that alerts you by displaying "protect" when there is a electrical short circuit detected in the system, the most common short happens in a speaker, try disconnectig the speaker wires of both speakers(all speakers) at the back of the system, then play the CD or cassette player(although you will not hear anything with the speakers disconnected) and see if the unit goes into "protect" mode if the problem is still present then you have an internal short circuit and the system will need to be sent in for service or replaced(depending on age,repair costs). I would not recommend investing more than $80 into repairs. Now, if the unit does not go into "protect mode" then one of the speakers or speaker wires is shorted,be sure you check the conndition of the speaker wires before you replace the speakers, then you can replace the speakers(in a pair) and you should be back up and listening! Good luck and Merry Christmas !
Dec 03, 2009 | Sony MHC-NX1 Shelf System
Sansa m240 not working, just only on and off conndition
You probably put files into the Mass Storage view (on my computer) rather than in the MEDIA subdirectory of the Portable Media Device view (called 'Sansa M240') -- I use Windows XP Media Edition and have no problems, but my plain old XP doesn't see the device correctly. You should load Windows Media Player 10 to have it seen as a portable media device with DATA and MEDIA directories. All MP3 files belong ONLY in the MEDIA directory.
Sep 17, 2007 | SanDisk Sansa m240 MP3 Player
Sound setting
There are several complaints in FIXYA and they are all about this same fault conndition....the volume is too high when turned on...
Because of the high number of complaints about this same fault I would suggest that its a manufacturer fault.
So the manufacturer should be contacted about it to ask for your money back..
Cheers From YUBEUT..
Sep 06, 2007 | GPX HM3817DT Shelf System
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
