Question about Vizio VW22L 22 in. LCD HDTV
I have a Vizio 22" and sometimes it will not come on, unplug for several days and it will work.
Only to unplug it each time I use it.
    Master:
  • 373 Answers
Many LED TVs and other electronics have bad capacitors on their power supply boards. You can visually inspect them by opening the TV and looking for capacitors with bulging tops. If tou see any, replace them all in the power board section. Check to see if your TV is still under warranty first though.
Posted on Dec 03, 2014
Vizio e420i-a0 picture problem. Vertical lines that progressively get brighter and sometimes the proper image displays but it is split vertically in 2 or 3 sections.
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 09, 2016 | Vizio E420I-A0 42" LED TV 1920x1080, 120...
A possible fix for this Vizio TV?
Sounds like the flash memory has an error for the basic routine on power-up. This could be a faulty program write, error of the bios chip set or a bad memory capacitor if present. I think the cap is there as you have to power the set off for several days so it bleeds off.
Many electronics have a 'house' program for each TV set for the unit to run from start up. Not sure if there is an easy cure as the EEProm may have to be re-flashed. The start up program may have an error and with out a reset button this may have no solution.
I would suggest when it doea power up correctly, power it down and unplug for several days, then restart it.... do this several times and the re-boot may correct the fault.
Apr 28, 2015 | Vizio Televison & Video
Vizio downloads firmware every time it is turned on
Firmware corrupted. A reinstallation is necessary. Contact any service technician.
Mar 04, 2017 | Vizio XVT553SV 55 in. LCD TV
Why do I have to rescan my tv several times a day
The main system memory IC to your TV is faulty. It must be replaced with same type and number. It is a skilled work. Seek assistance of any experienced service technician for help.
Jul 04, 2012 | Vizio VL Televison & Video
Vizio shuts itself off
There may be some components failing in the power supply or one of the circuit boards that are causing too high a current pull.
I realize that this answer is very vague. Without doing proper diagnostics, it is impossible to guess at something like this.
Out of warranty repairs on these sets can be very expensive. I would suggest that if the set is going to be expensive to service, it would be best to replace it with a known brand name that offers an extended warranty with local service. You will pay more, but you will have dependability and better quality.
Jerry G.
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 HDTV 10A - Won't Turn On
Bad capacitors in the power supply. Open it up and look for swollen electrolytics.
Sep 22, 2008 | Vizio L32 32 in. LCD HDTV
Vizio LCD
Pretty good chance the logic board is defective. all remote and manual command go trough the logic board via a micro prosseor. If that is bad the set gets false commands. If the run number is the same on that model they probably all have the same problem.. Get another brand not made in China.
Jun 20, 2008 | Vizio GV42L 42 in. LCD Television
Vizio VW22L 22 in. LCD HDTV Logo
52 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
