Question about Mitsubishi Televison & Video
How can I set to factory defaults my mitsubishi dvd Model DD-6030?
I cant find any owners manual which might help and have looked for a reset button on the remote and unit but cannot find one.
SOURCE: toshiba dvd setting
1. You would press and hold stop on the front of the unit for 5 seconds then let go and press it again normally, you can try this with both the power of the unit on and off.
Posted on Sep 24, 2007
SOURCE: Cannot play any dvds - re "rating"
Eureca!
power on, open disc tray.
On the machine, press and hold the record button and add another finger to hold the Play (x1.3) for 5-10 seconds. The door should stay open. The rating will change to 8.
Posted on Jun 13, 2008
SOURCE: Remote control via RI terminal on Onkyo Receiver
Not sure I can solve, but maybe help. I am having a similiar problem. However, make sure you Analog Audio (RCA type) cable are connected even if using Digital connection between the two. They use those cable to send the Commands (Mentioned in the documentation).
If you did get yours to work, please give me a hint... I upgraded mine from a 603 to a 701 and haven't been able to get it to work since.
Posted on Feb 14, 2009
benbailey50
  • 6 Answers
SOURCE: i cant get my remote reverted back 2 factory settings because it wont work at all because its the player is set in dvd 3 and the remote is not ....so how do i reset it if it wont work at all
If your unit is displaying DVD2 on the front panel, you will need to set the command on the remote to match the display on the unit.
Point the remote to the unit and press 2 on the remote. Them press system menu on the remote, you should be ok.
Posted on Jun 15, 2009
SOURCE: locked out of the menue ,Need to reset command mode
Indeed, I did the same thing.... I did find the answer in the manual!
Here's a copy of it (pg 23):
Set the command mode for the remote so it matches
the command mode for the recorder you set above.
1 Hold down ENTER
2 While holding down ENTER, enter the
command mode code number using the
number buttons.
Command Mode Code number
DVD1 number button 1
DVD2 number button 2
DVD3 number button 3
3 Hold down both the number buttons and
ENTER at the same time for more than 3
seconds.
4 Let up, press RETURN, all done!
Posted on Oct 01, 2009
Is my mitsubishi dd 6030 a multi region player
Mitsubishi DD-6030 DVD Player Multi region hack ... - Fixya
www.fixya.com > ... > Mitsubishi > Mitsubishi DD-6030 DVD Player
Mitsubishi DD-6030 DVD Player, multi region hack related issues. Get free help ...Can you help? I need the multi region code for my Toshiba DVD SD370E. Ad.
Mitsubishi DD-6030 DVD Player Multi region hack code ...
Mitsubishi DD-6030 DVD Player, multi region hack code related issues. Get free help ... I need the multi region code for my Toshiba DVD SD370E. Ad. Question ...
Mitsubishi DD-6030 DVD Player Real free - Questions -Q&A
www.dqrkc.com/search/p153978-mitsubishi_dd_6030...player/real_free
I use them on all my disk players and they work real well. If you have any comments please feel free to leave them here. Hope this helps and thank you for using ...
Planet DVD Discussion Forum - planetdvd.net
www.planetdvd.net/discussion/wwwboard2.htm
Jan 20, 2016 | Mitsubishi DD-6030 DVD Player
How to reset mintek dtv-265-d telivision after replacing power supply
MINTEK DTV-373-D OWNER'S MANUAL Pdf Download.
www.manualslib.com > ... > TV DVD Combo > DTV-373-D
View and Download Mintek DTV-373-D owner's manual online. Mintek DTV-373-D OWNER'S MANUAL 37''. DTV-373-D TV DVD Combo pdf manual download.
Mintek DTV-265-D 26 in. LCD TV Factory reset - Questions ...
www.fixya.com > ... > Mintek > Mintek DTV-265-D 26 in. LCD TV
...factory reset to this TV. It will make all to factory settings. There are two types ofreset to TVs. The first is simple to do; a Hard Reset. The other is somewhat ...
Mintek reset button location Combination Televisions ... - Fixya
Dec 07, 2015 | Mintek DTV-263 26 in. LCD Television
Does the wd62628 have a factory reset button?
should be in the manual. Or you can look on line for Mitsubishi model wd62627 owners manual download.
Sep 09, 2014 | Mitsubishi 915p026010 Wd-62627/Wd-62628...
Dvd plays, music plays, talking at a whisper
My
dd-6030, music plays, talking at a whisper. Any suggestions?
Mar 04, 2014 | Mitsubishi DD-6030 DVD Player
Unlocking mitsubishi dd 6030
follow the next step:God bless you
Purchase or borrow an imported DVD. The only real reason to make your DVD player region-free is if you plan on watching imported DVDs.
  • 2 Locate your DVD player's brand name and model number. These can usually be found on the box the DVD player came in, or on a sticker close to the video inputs or on the bottom of the DVD player
  • 3 Have your remote handy. You will need your remote to enter the input codes into your DVD player.
  • 4 Locate a Web site that can help you with the codes you need for your particular DVD player, since all DVD players have different codes. Try DVD Exploder or Video Help (see Resources below). Both have an extensive list of codes for almost every kind of DVD player manufactured.
  • 5 Enter your brand name and model number when prompted to do so on the Web site. If your particular model number is not available, try searching under the brand name. Sometimes you will be able to find a model number that is close to your DVD player's model number.
  • 6 Enter the codes into your DVD player with your remote. Be sure the DVD player's door is open-almost all codes require the door to be open.
  • 7 Test your imported DVD to see if it works, once you have entered your code into the DVD player.
  • Jul 20, 2012 | Mitsubishi DD-6030 DVD Player
    Rca drc8295n reset parental codes I bought this unit at a yard sale for five bucks... It plays cd, vhs tapes, but when I put a dvd in it wont play and I see a pad lock on the little display. I am assuming...
    Page 55 of the user manual shows a way you may be able to 'reset' the player back to factory defaults and/or if a parental lock has been set and the password is unknown/forgotten:
    * Press the STOP button on the front of the unit while you press the STOP button on the remote control-keep pressing both buttons for approximately 3 seconds (until the 'padlock' icon disappears from the front panel display). Release both buttons (the player should be unlocked). If that doesn't work, try resetting the DVD/VCR (instructions are listed below).
    * Reset the DVD/VCR: on the front of the unit, press and hold the STANDBY/ON button while you press and hold the STOP button-wait at least 3 seconds before you release both of the buttons.
    You'll need to set up your menu preferences because this Reset Procedure returns the DVD/VCR's menus to the factory default settings and also erases the disc library.
    ( sourced from: http://www.retrevo.com/support/RCA-DRC8295N-DVD-Players-manual/id/402bh648/t/2/ )
    You can always go to the above site and download the free pdf of the owner's manual for this model if necessary (follow the prompts).
    Give the suggestions a try before considering downloading the documentation.
    Apr 26, 2011 | RCA DRC8295N DVD Recorder/VCR
    DVd audio sounds slow
    Check you owners manual for the audio settings. Check these pages and note that the underline setting are the factory settings.Pages 37-41.These are the setting most likely changed. You can always reset the player to factory settings. This will most likely restore everything to normal. This procedure can be found on page 47. The reset function is call default. This is a factory reset function.The function is found in the settings menu under the preferences.If you do not have a copy of the owners manual handy, you can use this link and find a pdf copy on the philips website.http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=DVD_HOME_THEATER_CA&sct=DVD_PLAYERS_SU&session=200906 If you still cannot get the player working correctly, you can call the Phillips customer support at this telephone number 1-888-744-5477. Give them the model number of your dvd player and the problem you are having with the sound slowing down. They will be able to help you solve this problem. I hope this information help you solve your problem.
    Mar 10, 2009 | Philips DVP5990 DVD Player
    Reset to factory defau;ts
    Small print in the manual says to hold down the 100/P.Scan button on the remote to toggle between progressive and interlaced. This was after I blindly tried to follow the setup screens in the manual and found that the manual doesn't match the exact screens (must be a firmware difference?) in the manual.
    Also found that the factory default instructions in the manual do not include a yes/no confirmation screen.
    May 26, 2008 | GoVideo DV2150 DVD VCR
    Curtis DVD 2100 DVD Player
    page 1 in the set up menu will allow u to reset to the factory settings.
    Oct 11, 2007 | Curtis DVD1045 DVD Player
    Dvd player will not open
    remove the 5 screws that hold on black cover. inside there is a white gear that will retract mechanism. Two gold screws on plate that covers dvd need to be removed. lift off cover and remove dvd.
    Jun 30, 2007 | Mitsubishi DD-6030 DVD Player
    Televison & Video Logo
    35 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
