Question about Sewing Machines
I can't get the bobbin back in after taking out to clean. I have a DC40 machine
I took the bobbin cartridge out of the machine to clean but I can not seem to get it back in...how do you suggest? I have no book to show me
  • Sewing Machines Master
  • 1,860 Answers
Try checking with youtube for a video, also check with the mfg of the machine for a manual
Posted on Dec 03, 2014
The bobbin isn't catching on my Viking Husqvarna 190
Your machine is out of time. You'll need to take it in to a professional to get it timed correctly
Nov 24, 2012 | Sewing Machines
Two threads coming from bobbin?
try adjusting the top thread tension-one number or letter less, then
sew on a piece of the scrap fabric if you have any. to see if that helps
try changing the needle
make sure the bobbin is turned the right way in the bobbin case, I
know this may sound crazy but it can hinder the sewing, I was sewing
a skirt the other night & I turned the bobbin the wrong way & inserted
the bobbin into the bobbin case & it didn't work good,, I took the bobbin
out of the bobbin case & had multiple threads. so I had to clean the mess up & turn the bobbin the opposite way & the machine worked
just fine
Oct 03, 2012 | Singer 3116 Simple
Brother Sewing Embroidery Machine
I agree with sylviaivie about find another repairman, they are suppose
to guarantee the work they do.
when the upper shaft is replaced & then the machine is retimed
the machine should work just fine.
but just don't take it back to that man to be repaired
here is a tip if it happens again,,
always try to cut the top thread first,
& turn the machine up on it's back to access the bottom cover
take the cover off the bottom to get access to the bobbin thread
where you can cut the bobbin thread
then you should be able to get the needle out without breaking it &
damaging the upper shaft, replace the needle & make sure
that the thread is good quality & not knotty, clean out the bobbin area of lint or thread
always change the needle on the embroidery machine every project
make sure the bobbin area is kept clean of lint or thread
clean under the needle plate at least once a week for lint if you
embroidery everyday or just often
Aug 01, 2012 | Brother Sewing Machines
The stitches are not taking in my janome j3 24
have you tried a new needle? flat side to the back of the machine
rethread the machine top & bobbin
May 05, 2012 | Janome Sewing Machines
Janome mini heavy duty sewing machine
when you sew keep a eye on the thread take up lever & see if the thread comes off while your sewing, I've had this happen to me & I've been sewing for over 30 years. if this does happen, take a pair of pliers & very gently close the take up lever just alittle but not enough to damage it.
also check the needle to see if it's damaged--if your not sure change the needle--flat side goes to the back of the machine
always make sure the fabric & needle & thread are compatable--the thread must be able to pull thru the needle with out any problem
also check to make sure there are not any burrs on the needle plate or bobbin or bobbin case
Feb 26, 2012 | Janome SEW MINI Mechanical Sewing Machine
Singer Athena 2009 needle hitting plastic in bobbin case
here's something to check
is the needle inserted all the way in to the needle holder?
is the needle clamp screw tight or loose?
if the needle is correctly in the needle holder & the needle clamp screw is tight --then the needle bar is out of time & need to be serviced
IF YOU DO HAVE TO TAKE IT TO BE SERVICED AFTER YOU GET IT HOME STOP RIGHT THEN & SEW ON THE MACHINE TO MAKE SURE THEY FIXED THE MACHINE & IT SEWS LIKE IT SUPPOSE TO, I HAD ONE CUSTOMER THAT TOOK THEIR MACHINE TO A SHOP & THEY CLEANED IT AGAIN & DIDN'T FIX IT BUT CHARGED THEM FOR IT & THEY BROUGHT IT TO ME TO FIX & IT HAD TO BE RETIME
did you get a instruction manual for the machine if not check at singer
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number---2009
Click search--if you don't see a manual--contact singer customer service
Feb 11, 2012 | Singer Sewing Machines
Brother xl-2600 As I am sewing ( not thick material) the thread keeps breaking, also over seams it is not sewing through. Then, when my bobbin ran out, went to change it and when pulling the needle down...
try changing the top thread tension to 3 or 4
also rethread the machine just in case the thread is hung up somewhere
take the bobbin out & put the bobbin in reverse of what you did before
you said you changed the needle, check to make sure it in correctly,, the flat side goes to the back of the machine, push it all the way up before tightening the screw
Aug 06, 2011 | Brother XL-5340 Mechanical Sewing Machine
Singer 8280 (prelude) I had 2 threads coming out from my bobbin area, so I decided to open it up and take a look. I accidentally took out the whole bobbin shuttle. The manual doesn't tell me how to...
Ok, hang on! This can get tricky! Remove the bobbin. Remove the presser foot and the needle. Remove the throat plate. This gives you plenty of room to monkey with your bobbin case. NOW, lay the bobbin case in its correct area and gently rotate it until it falls into place. It may take several tries. Once you're satisfied that it's secure, snap the holding clips into place and it should all fit nicely. THEN place your bobbin in the case correctly...check the diagram in the manual. Depending on the machine, some bobbins have the threads coming off counterclockwise and others have them coming off clockwise, but your manual should show. Sometimes, there's even a diagram on the throat plate or the bobbin case as well.
Good luck. Hope this works. If this solves your problem, please come back and rate my answer!
Jun 07, 2011 | Singer 8280 Mechanical Sewing Machine
Bobbin problems!
MAKE SURE you are using the correct SIZE bobbin. Some of the older plastic bobbins don't swap around in the newer machines & just because they LOOK the same doesn't mean they are. If you are absolutely POSITIVE you are using the right size bobbin (mark it w/ a permanent marker if you have to, to keep track of it), check & double check you are putting the bobbin in the case in the right direction & make sure there aren't any loose threads anywhere in the area where the bobbin sits... be sure all little dust bunnies are removed. I know it sounds redundant but get your book out & be POSITIVE you are threading thru all the thread paths in the right direction. My Babylock is supremely **** when it comes to putting the shuttle back in after I've cleaned the bobbin area & if I don't get it back exactly where it supposed to go, it won't sew right. I always have to get my book back & check it out again step by step. I have it do crazy stuff just because there was a little tail hanging out where the bobbin started to wind that I didn't cut off close enough.
Jan 31, 2009 | Baby Lock Esante
Kenmore sewing machine # 385.17626 feed dogs not advancing fabric. Appear to move up and down, but not forward to back.
I had the same problem and had recently posted my own message, with no replies. Took it to a repair person and he fixed it at no cost - it was stuck in reverse because the mechanism(s) were all gunked up. Take off the accessory box on the machine and the bottom plate. move the mechanism so they move freely and take out any gunk you see. The feeder dogs should now move back & forth in addition to up & down, feeding the material properly
Jun 21, 2008 | Kenmore Drop-In Bobbin 505S-21BH...
Sewing Machines Logo
22 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
