Question about Radio Communications
I need software for my hareto h 5118 two radio
Why vivitar 5118 memory full message no photos or videos detected
It is likely that your card has failed. Take it out of the camera, put it in a reader and plug that into your computer. See if you can view there and remove the pictures to your computer hard disk. If you can not see them there but the computer recognizes the card you will need to use recover software to get your pictures back. Once you have everything throw away the card and get a new one. Unfortunately cards to eventually fail. :(
Apr 25, 2014 | Vivitar ViviCam 5118 Digital Camera Blue...
When i press key to call i heard do do do
If it is three beeps, this is could be a sign of a bad or poorly charged battery. The first thing to fail is generally transmit. It takes more energy from the battery to transmit than to simply receive or be on standby.
Swap your battery pack with a known good battery pack from another unit and see if the problem is solved. IClean your battery contacts with a pencil eraser, and replace batteries as needed.
Best regards.
Nov 25, 2013 | Motorola Walkie Talkie 2-Way Radio
My vivitar camera 5118 wont charge
It's because the 5118 is a camera, not a battery charger. It uses disposable alkalines or rechargeable NiMHs, but if you choose to use rechargeables then you much charge them outside the camera using a separate battery charger.
Apr 12, 2013 | Vivitar Cameras
Why my vivitar camera 5118 wont charge
This is because the 5118 is a camera, not a battery charger. It uses disposable alkalines or rechargeable NiMHs, but if you choose to use rechargeables then you much charge them outside the camera using a separate battery charger.
Apr 12, 2013 | Cameras
I need software for my laptop for a vivicam 5118
You don't need any software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Sep 19, 2012 | Vivitar ViviCam 5118 Digital Camera Blue...
HI folks! Can you help me?Serial:1330-1923-1158-4802-3942-9183 Activationnr. 2013-5118-3112-3588-4998-1222-4895 Activation Type: Normal: 194:8 Please send the authorization code! thanks!...
You will need to get in touch with Adobe or an authorized reseller directly in order to get a genuine authorization code.
This will also prevent issues with authorization with future updates.
Jul 09, 2012 | Adobe Computers & Internet
How long does it take for a vivitar Vivicam 5118 to charge fully?
Since the ViviCam 5118 isn't a battery charger, it will take a very, very long time.
The 5118 uses standard AA batteries. If you want to use rechargeable batteries then you much charge them outside the camera using a separate battery charger. Connecting it to a computer through the USB port will drain the batteries even faster, since the camera has to expend power communicating with the camera (even if only to say it has nothing to say).
May 08, 2012 | Vivitar ViviCam 5118 Digital Camera Blue...
How do I turn on the sound for my vivitar vivicam 5118. Can't capture audio while recording video.
The 5118 is designed primarily as a still camera, with some video capabilities grafted on. It records images, not sound. You can add a soundtrack using video editing software on a computer, but you cannot record one on the camera.
Sorry if that wasn't the answer you wanted to see, but there it is.
Jun 10, 2011 | Cameras
1045-1084-3377-5725-2191-9202
i need an authorization code ^^
my serial num : 1045 - 1084 - 3377 - 5725 - 2191 - 9202
my activation num : 5429 - 4600 - 5046 - 2672 - 5733 - 5118 - 0615
please... thank you :)
Aug 31, 2010 | Adobe Photoshop CS for PC
Radio Communications Logo
157 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
