Put #1 plug on tdc put dist in want start.where is pre-drilled hole in distributor driven gear to align with painted mark
To reset the dist. you need to put #1 cylinder on top dead center and turn the oil pump shaft so the dist shaft will seat in the oil pump shaft, when you do this be sure the rotor is pointing to #1 spark plug in the dist. cap. Then replace the hold down bolt to the dist. and just snug it down.
When you put #1 cylinder on top dead center you should be able to look at the timing mark and it should be on zero. Once you get the truck started then you can recheck the timing and tighten down the dist. bolt. Hope this helps.
