Question about Ovens
Hi I have kenwood eurokera cooker ck780. the main oven does not heat over 175 do u know what could be causing this problem.
  • 156 Answers
Temperature sensor too close to the heating element.
Posted on Dec 03, 2014
When i using my oven, suddenly off i don't know how to fix
If there are no lights showing or electric fan or heat
Check the cooker trip / fuse on the main Fuseboard.
Should be 32 amp rating.
If Light works / or / and Fan but no heat then likely to be Cooker element. If its a double element or oven with grill you may still have reduced capacity to heat / cook food.
May 25, 2016 | Ovens
Hi i have a belling oven model number XOU252 and for the past year and half the oven element keeps blowing. It will first start my tripping my mains electric switch which can go on for weeks then the...
ISOLATE THE MAINS BEFORE OPENING ANY PANEL
Remove the rear panel, there is a component with two terminals screwed to the chassis, read whats on it, take a note of the letters and numbers, get a replacement, from a local electrical store, or www.whitegoods.co.uk you will need the model and serial number, this component stops the cooker from over heating, the elements have to be controlled, the second cause is fan running too slow, if the fan does not cause enogh pressure the element will over heat.
Hope this has been helpful
John
May 19, 2011 | Ovens
Main Oven Thermostat :- No control of Heat
Hi
If you cannot regulate the heat in your oven it is most likely that your oven thermostat has failed.
You will need to have a new one fitted. This link will show you whats involved and where to get the parts. ; www.wonderhowto.com/how-to-replace-cooker-thermostat-oven-250012/
Dec 16, 2010 | Ovens
Main oven not heating up but fan is working on kenwood ck405 oven
Kenwood Oven not heating? How to replace a Kenwood fan oven element
This video will show you how to replace fan oven element in your
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 13, 2010 | Ovens
Bought new cooker however no user guide its a kenwood ck404 duel fuel double oven 5 ring burner. need to know what symbols on switches are and what they do.
I have a problem with my Kenwood CK404. When I put either oven on (it's a double oven), once it gets hot it starts to make an awful noise. At first I thought it was the fan in the main oven. But it makes the same noise in the small oven, which doesn't have one. Does anyone have any suggestions of what the problem could be? Kind Regards
Trotwood
Aug 21, 2010 | Ovens
Neff cooker not heating up
Hi, it feels like your oven element has gone.
switch it off from the mains, open the door and remove the screws fixing the back panel. You will find a round two turn element. Unscrew the element fixings and check the element for burnt marks, corrosion. If you have a multi meter, turn it to buzzer and use the meter leads to test the element connections. If it doesn't buzz, it's dead. Just needs replacing.
Cheers
Feb 15, 2009 | Neff U1721 Double circotherm Electric Oven
GE JKS06 won't heat up past 200
Hi.
Could be that main oven stat is faulty, and also there is a possibility that the thermal overheat stat is coming in sometimes caused by poor ventilation.
Also there is sometimes a secondary element fitted to cookers which is not always obvious.
More investigation is needed.
Nov 19, 2008 | GE JKS06BFBB Electric Single Oven
Cooker
HI THERE SKI IS THE GLASS DOOR PANEL THE INSIDE DOOR GLASS OR THE OUTER DOOR GLASS PANEL AND IS IT THE MAIN OR TOP OVEN.
THE GLASS PANELS INTERNALLY ARE HEAT BONDED IN THE FACTORY AND CANNOT BE REPAIRED YOU WILL NEED A NEW DOOR GLASS.
IF INTERNAL ONE COME AWAY THEN U WILL HAVE TO HAVE A COMPLETE INNER PANEL.
Feb 13, 2008 | Ovens
Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Sep 18, 2007 | Ovens
Ovens Logo
98 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
