Question about Tomtom VIA 1605TM - GPS receiver
Via 1605, won't charge, even after replacing battery
GPS would no longer accept a charge, either through car adapter nor through 120V charger. Replaced battery with new one from newpower99.com, but the problem is still the same. Will not charge.
  • Bad Maxx Dec 03, 2014
    Hi Karl Jaquet, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Does the GPS work when it is plugged in?
How do I change the battery in a nuvi 780?
Replace Nuvi 780 Battery - NewPower99.com‎
Adwww.newpower99.com/Nuvi/780/Battery‎ Garmin Nuvi 780 Replacement Battery Tools and Instructions Included.
Full 1 Yr. Warranty · How-to Video Included
Types: GPS, Auto GPS, Bike GPS, Camping GPS, Cycling GPS, Hiking GPS, Motorcycle GPS, Watch GPS, Golf GPS
Search Results
How To Replace Your Garmin Nuvi 780 Battery - YouTube
? 3:55
https://www.youtube.com/watch?v=Xd3vcThmXUI
Feb 8, 2010 - Uploaded by NewPower99DotCom
Part of the Complete Installation Kit from NewPower99.com, available at http://www.newpower99.com ...
Garmin Nuvi 780 Battery Replacement - YouTube
? 4:00
https://www.youtube.com/watch?v=A2pKE1S3tXo
Jan 14, 2012 - Uploaded by NewLife2OldStuff
Amazon.com: Battery Replacement Kit for Garmin Nuvi 780 with ...
https://www.amazon.com/Replacement-Garmin-Nuvi-780-Installation/.../B003VFY7A... Rating: 3.8 - ‎28 reviews
Replace your Garmin Nuvi 780 Battery or Keep an Extra Battery on hand as a backup. This is a High Capacity 1250 mAh, Lithium-Ion Battery that offers even more up time than your original. Works in your Garmin Nuvi 780 GPS. Simple, Easy and Inexpensive! You get a New Battery, FREE Special Tools (necessary for ...
Peel open a nuvi 780 to replace the battery? ' POI Factory
www.poi-factory.com > Garmin talk Feb 2, 2009 - 27 posts - ‎16 authors
I've got a DOA nuvi 780 that I bought on eBay. It works fine while plugged into car or computer but the internal battery only holds a charge for about 15 minutes. So I guess it's not really DOA but it needs a heart transplant. Or maybe the correct analogy is a FAT transplant since the body uses fat to store ... Rejuvenate a Nuvi Battery?
30 Sep 2011
owner rplacement of nuvii batteries
10 Jun 2009
More results from www.poi-factory.com
Garmin Nuvi 780 GPS Batteries at Batteries Plus Bulbs
https://www.batteriesplus.com > Batteries > GPS > Garmin Whether you're traveling across the country or just to an unfamiliar part of town, you rely on your GPS to get you where you're going. Unfortunately, a dead GPS battery isn't going to get you anywhere. If you're Garmin Nuvi 780 GPS needs a new battery or you just want an extra on hand just in case, Batteries Plus Bulbs can ...
Feb 12, 2018 | Garmin nuvi 780 GPS
Tip
Problem charging MAGELLAN GPS.
I found there are select 120v AC adapters that will work on Magellan GPS. When a working 120v or 12v adapter to mini USB adapter is plugged into the unit, the battery bars will be 'scrolling' and therefore charging.
When your adapter, or even USB cable from your computer, is plugged into the GPS unit, and the battery goes to FULL, it is NOT CHARGING. The battery bars must be SCROLLING for the unit to charge. In this case, get a different adapter until it works.
This was tested on a Magellan 1412, and may apply to other Magellan GPS.
on Dec 28, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Garmin will not come on. Hasn't been plugged in for a month.
Given that you've tried other chragers, it seems likely the problem is battery related - especially if you've already tried steve's suggestion. How old is your nuvi? It is not uncommon for GPS batteries to go down after a year or two as they are subjected to temperature extremes and repeated charges and discharges. If the battery is the problem, it makes more sense to replace it for $30 than to spend another $300 on a new GPS. This can be done easily enough:
The company that produced the video sells a kit which includes the battery and tools necessary to do this yourself if you'd like. See: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+205W&Show=ExtInfo
I hope this helps. Happy travels!
Best,
Rob
Jul 07, 2010 | Garmin nuvi 205W GPS Receiver
Battery not charging
If you have checked out your charger and it is not a charger problem, then you need a new battery. NewPower99.com has a nice battery kit
May 14, 2010 | GPS
I turn it on, logo comes on, and it turns off. I've tried holding the on button 8 sec, no luck.
With the limited information provided, a simple first step is to make sure the internal battery is either fully charged or is in a condition to accept a charge. When the internal battery's charge is allowed to below a certain level, it will no longer be capable of accepting a charge via the car charger.
The battery can be conditioned to accept a charge easily, however. This is done by connecting the GPS to the computer via USB port, NOT the car charger. Some Garmin GPS units come with a 120 volt charger that connects to the USB port of the GPS - this method is also an acceptable charge / condition method. Leave the GPS connected for 8 hours or longer (over night) and try to power up again.
I hope this helps!
Oct 24, 2009 | Garmin nuvi 205W GPS Receiver
How to charge Garmin 755t
I had the same problem with mine & it was only 6 months old. The battery needs to be replaced. This is a good site that shows you how to change the battery & you can order the new battery from them as well. http://www.newpower99.com/
Jul 15, 2009 | Garmin n?vi 775T Car GPS Receiver
Garmin nuvi 750 battery does not hold a charge
A new battery can be purchased and installed inexpensively. I found a video.
You-Tube video "yxP4PdRB_98" placeholder (do not delete)
http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+750
Jan 26, 2009 | Garmin nuvi 750 GPS Receiver
Magellan Maestro 4000 will not hold a charge longer than 30 min
replacement battery at http://www.xtreamgadgets.com/product.php?productid=132797&cat=10001980&bestseller
must remove external card from slot before removing 4 screws at rear of unit. cover snaps off, unplug speaker wire, unplug battery, new battery plugs in, reassemble.
Dec 27, 2008 | Magellan Maestro 4000 Handheld GPS...
Garmin 1412, wont run on battery power, DC only. Need info on maybe a full reset whether to return as defective
Dec 22, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Battery question
Oct 08, 2008 | Magellan RoadMate 1412 Car GPS Receiver
Tomtom VIA 1605TM - GPS receiver Logo
105 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
