I need help finding a part to fix my JVC JL A40 turntable, but can't find it anywhere! Maybe one of y'all can help, it's the cueing assembly, part E34240-002. Thanks!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
I'm sorry. The assembly would be long discontinued. You'll have to repair what you have there. If you require more assistance, or would like to inquire about repairing your JVC, please visit my website at audioserviceclinic.com. Thank you.
Posted on Dec 11, 2014
I have a jvc jl-a20 auto return turntable and the arm briefly returns then proceeds to travel across the album. What do I have to do to get it to stay at home after it returns? Thank you
It's probably some kind of mechanical problem. Perhaps something bent out of place.
I have found a photo which is the underside of the model. You can compare it with yours and see if it looks the same. If it doesn't (assuming it is the same model) then you have found the problem.
http://www.vinylengine.com/turntable_forum/gallery/image.php?mode=large&image_id=30141
Oct 12, 2015 | JVC Audio Players & Recorders
Tone arm cueing problem on technics sl 1210
The turntable may not be level and consequently beyond the ability of the balance and antiskate adjustments to correct
Jun 26, 2013 | Panasonic Technics SL-1210MK2 Turntable
I have an older QL-45 turntable that needs tone arm adjustment- I don`t know how to set the weight so it doesn`t lower down to album so hard or heavily
I can't find the specific turntable. Who makes it?
This should work with some modifications for your specific controls...
Make a note of the tracking force setting.
Make sure the turntable is level.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Stylus Pressure/Tracking setting to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force on the Stylus Pressure/Tracking control. Play records.
Apr 11, 2011 | JVC Audio Players & Recorders
Pioneer cdj 800 mk2 needs new cue button needs to be local to bradford or leeds how much ? & where please :~)
PART NUMBER IS DAC2059 This also includes the play button.you can order from pioneer parts on line
Apr 16, 2010 | Pioneer CDJ-800MK2 Turntable
Cant cue up cd, it just starts playing when inserted
Hey,
no need to worry, there may be problem with micro switch.
Micro switch is that when u press cue there is a another micro switch just bottom of the cue button. I think micro switch needs to be replace and all done.
thx,
djajay
Feb 18, 2010 | Pioneer CDJ-800 Turntable
Denon DN-HS5500 Cue Slip
Try changing the platter speed from 33rpm to 45 rpm The menu for this should be in the preset section on the player.... Good Luck
Oct 06, 2009 | Denon DN-HS5500 Turntable
Pioneer cd player not working
Sounds like a laser problem and maybe not put your player back together properly if you have already changed your laser.
if you havent had your player repaired then you can contact me @ www.audiovisualservices.info
Hope this helps you.
Thank you.
Jun 22, 2009 | Pioneer CDJ-800 Turntable
JVC Turntable won't turn, motor works, can't remove platter
http://www.vinylengine.com/library/jvc/jl-a20.shtml
Looks like this is a belt drive model.
http://www.turntablebasics.com/belts/jvc.html
This site claims to provide installation instructions with belt purchase. Good Luck.
Jun 20, 2009 | JVC Audio Players & Recorders
Cueing Problems on Technics SL-1300MK2
Usually the damping fluid is to let the tone arm lower slowly, lifting is usually a mechanical link. Read THIS.
Hope that helps...
Geno
Apr 01, 2008 | Audio Players & Recorders
121 people viewed this question
 Grubhead
Grubhead
