Question about Epson Office Equipment & Supplies
Set up Epson XP-710 for non Wi-Fi use
Loaded papers done print test OK PRINTER DOES NOT RESPOND TO PC PRINT COMMAND
  • Epson Master
  • 706 Answers
You need to buy a USB-cable and connect the printer with it to the PC - see picture
- then download a driver at the link below:
http://www.epson.co.uk/gb/en/viewcon/corporatesite/products/mainunits/support/12463
Expression Premium XP 710 set up Epson XP-710 for non Wi-Fi use - set-up-epson-xp-710-non-wi-fi-use-cetraao0zsf5cxvgwz0wg4tf-1-0.jpg
Posted on Dec 05, 2014
How do i print on 4x6 paper
1-create a custom size of paper in printer setting.
2-when printing select scaling custom size
Apr 24, 2015 | Epson Expression Home XP-410 All-in-One...
Had paper jam, clear the paper and now there is a loud crunching sound and the printer will not print at all
sounds like you have paper jammed in the gears , send printer to repair they will probably take it apart and clear the paper , then the gears have to be working OK
Apr 19, 2015 | Epson WorkForce 633 All-in-One Inkjet...
Trying to print a picture from the web on XP-810 epson on regular 8x11paper, printer tells me load paper on cassette 1 but cassette 1 only takes picture size not 8 x11. Cassette 2 is where the 8 x11 i
I Just right click on picture select save as. I now have a copy in my pictures. right click on picture select print, on the drop down window select paper size A 4 is 8X11 if it asks print to paper size click ok.
Oct 02, 2014 | Office Equipment & Supplies
Cannot print from command prompt - Epson U220D Windows 7 32-bit New parallel port with driver New centronix to parallel cable Epson driver APD_455dE (I was using Windows 7 64 bit with a...
The Epson works fairly well with XP. It is to be connected to
a parallel port, usually LPT1
using an IEEE certified parallel printer cable. The computer BIOS
setting is best set for standard parallel port, SPP, bi-directional port
or similar. If possible, do not set it to ECP or EPP or ECP & EPP.
The only native driver for the printer is on the Windows CP CD. Install
using the Add Printer wizard.
The Epson LQ-860 drivers, and a few others, can be used. Using these
drivers, you will discover that the printer actually has some resident
fonts (in printer ROM) that are not accessible from the Stylus
driver. However, with this driver, graphics printing quality is
compromised.
Windows 9x drivers _cannot be used_.
Let us know.
Tom
MSMVP
Windows Shell/User
"the_best_of_fools" <thebestoffools@discussions.microsoft.com> wrote in
message news:E7A27E3E-81E7-46CC-B38E-C63AA474A239@microsoft.com...
:I have an Epson stylus color 600 I can't get to work with Windows XP.
This
: printer worked fine with my old Mac.
: I've tried everything I could and nothing is working. The printer is
: connected to
: the computer via parallel LPT1 port. I've installed the WindowsXP
resident
: drivers
: for this printer model (the Epson drivers are too old and not
verified). The
: computer doesn't detect the new hardware with Plug and Play when
turned ON
: (don't know why) so I had to manually Add Hardware (Printer Port) with
the
: Hardware Wizard. I'm not sure how to recognize if the LPT1 port is
active or
: not and set up properly in the BIOS? I read something about having to
set the
: parallel port to ESP or ECP depending on the printer's requirement
(which I
: don't know) in the BIOS?
: Everytime I send a test page or print from a command prompt or WordPad
: nothing happens for 1-2 minutes and then I get a "Printer Out of
Paper"
: message in the pop-up. Of course, the printer has enough paper (and I
can
: print a sefl-test page from the printer). I also tried with another
parallel
: cable and it still doesn't work. I've tried uninstalling/reinstalling
the
: printer's driver many time and it's still not printing.
May 13, 2014 | Epson TM-U220D Matrix Printer
Epson 4880 incorrect paper source setting
you have to chose sheet paper before sendding the print command.
Apr 02, 2013 | Epson Stylus Pro 9800 InkJet Printer
How to set up wireless printer on windows 7 net book
I have just bought an epson sx435 wireless printer. I have set it up on my xp desktop with usb cable. How do I set it up to be wireless on xp
and how to I set it up on my Acer Aspire one 522 netbook running windows 7.
Home > Printer Wi-Fi Setup Setting up a Printer Wi-Fi Network Using the Control Panel Using the Wi-Fi Setup Wizard with LCD panel WPS setup You can set up a Wi-Fi network for your printer by using the printer's control panel. Using the Wi-Fi Setup Wizard with LCD panel If your printer has an LCD panel, you can use the Wi-Fi Setup Wizard to simplify manual setup. mark_no.gifNote: This setting is not available for all printers or may not be enabled. Make sure that the Wi-Fi is enabled on your computer in advance. Check the SSID and password for your network as these are required during Wi-Fi setup. If you do not know the SSID and password, check with your network administrator. For step by step information on setting up a Wi-Fi connection using the Wi-Fi Setup Wizard, click the following link. This feature is not available for all printers or may not be enabled.
exlink.gif../p_body/panel/wizard/manual_01.htm
Well to start with xp look at the following.
http://support.epson-europe.com/onlineguides/en/sx430sx435w_nwg/html/index.htm
May 30, 2012 | Computers & Internet
71 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
