Question about Ovens
How do I replace the metal strip on bottom of oven door? It is rusted.
Evidently, we cleaned the face of the oven door and cleaner runs down in between the door and the little metal strip at bottom of door where it has now rusted.
  • 163 Answers
SOURCE: Cleaning the inside of the glass on the oven door
dont try you will broke something and then gonna think that was better to have a little dirt in there, a tech could do but whats if it comes again....good luck if you insist post back
Posted on Aug 08, 2006
SOURCE: How can I remove oven door so that I can replace the broken glass
I just took my oven door off and took it apart to clean the glass inside. I don't have a maytag but they probably all work alike. Just open the door like you are going to broil something and just lift it up. It should slide right off. Shouldn't have to unscrew anything. Hope this helps. Arlene
Posted on Nov 15, 2008
  • 41 Answers
SOURCE: Oven Door Locked
the oven door does lock during self clean, otherwise it will not work. however, the door is supposed to unlock after the oven has cooled. if it is still locked, turn the oven to self clean and wait about a minute and then hit cancel and see if the door unlocks. if not, there may be a probelm with the door lock mechanism. Joe
Posted on Nov 18, 2008
heatman101
  • 43501 Answers
SOURCE: Cleaned bottom oven. Top oven door won't open
Cycling the power off and then on again will sometimes reset it...often you will have to call the customer service number to get the steps to take to unlock that...
Also check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Posted on Apr 26, 2010
allbrands
  • 600 Answers
SOURCE: I purchase the Whirlpool electric
Hello, Thank You for using FixYa. I will be helping you today.I would recommend paying for a service call to have a tech take the door apart for you. There are four pieces of glass in the door and lots of screws. It really is a pain to take doors apart we as techs get this call all the time. Believe me you will thank me you paid someone to do it. If it were easy i would tell you. Most people take them apart then end up paying because they cant put it back together.
Thank You and please rate my answer if it was helpful..
Posted on Jun 10, 2011
What replacement parts should I order to keep my Kenmore oven door from just dropping down when it is opened?
If the hinge is not broken "Check the Springs".
They sometimes come off at one end or can be broken.
There are 2 one on each hinge. They are strong so be VERY careful.
As I remember they have a color code according to how strong that are according to the weight of the oven door.
The surest way is to get the MODEL NUMBER from the tag on your oven. The parts store will be able to look up the proper replacement.
I may be able to tell you more with a model number for Identification, the oven is likely a Whirlpool Product made for Kenmore. Let me know if you are in New York City area.
Hope this helps.
May 19, 2015 | Kenmore 47783 Electric Single Oven
Where can I locate the details of the oven eg. Make Model etc?
gee on a tag/sticker on the back possibly on a metal plate in the oven or bottom drawer my maytag is along the left side of the range bottom drawer outer frame
Mar 17, 2015 | Ovens
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
I hope this information helps to some degree.
May 24, 2013 | Frigidaire 27 in. Electric Double...
My oven door is locked. It is not cleaning. I have tried turning off the breaker. help i have a turkey to put in the oven. Is there a sequence of buttons I can push to unlock it?
Here are some solution on how to unlock the door of your oven ans do self cleaning below.
IF you can locate the model number tag (bottom left of door opening) you can look up the manual at www.geappliances.com
The only button on your stove that should make the door lock would be the clean button (self clean model) if that is pressed simply hit the clear/off or cancel key and wait for the door to unlock. IF the self clean option ran for an hour or so, you will have to wait for the oven to cool down before the lock can unlock (safety feature).
hope this helps you out please rate this solution it helps get better results for our customers like you
Here are solution on how to clean up your oven below.
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thank you.
    Oct 09, 2010 | Frigidaire 27 in. Electric Double...
    How to clean between doors of a wall oven a
    2smart4u did not answer the question - how to clean between the glass on the oven door. I too have streaks inside the glass - looks bad - no way to clean it?
    Dec 04, 2009 | Ovens
    If I DO NOT want to use the self cleaning feature is there any other safe way, including using soap and water, to clean the oven without ruining it? (I don't want to use the self cleaning feature)
    1. Oven door : Wash the door and window with soap and water and rinse with clear water. Use glass cleaner only if sprayed on a cloth first. Do not use abrasive pads, powdered cleaners, or steel wool on glass and enamel, or the surfaces will be scratched.
    2. surface burner : To absorb a spill when it is hot, pour salt on it and wipe it up when the oven has cooled. A mildly abrasive baking soda and water paste can be used in the oven, too.
    3. Racks:Remove oven racks and clean them in warm, soapy water. Stubborn messes can be cleaned by using mild abrasive cleansers or a soap filled scouring pad. Rinse and dry the racks before returning them to the oven.
    4. Metal trim:Metal trim can be cleaned with glass cleaners or mild cleansers, soap and water. Abrasives or cleaners made for oven interiors should not be used.
    Thanks
    Smith.
    Sep 05, 2009 | GE Profile JTP18 Electric Single Oven
    Need to buy oven seal strips, vinyl slipped over metal
    Hi, Look for the model # around the door, pan drawer, or lift the top and see if there is a tag there.
    Jul 22, 2009 | Ovens
    Smeg se336ss 5 some so and so has broken the outer glass door!
    We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
    Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
    1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
    2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
    3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
    4. Lay the outer sheet of glass in position in this metal strip
    5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
    6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
    7. Screw the metal strip back into position with the 3 screws
    8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
    Jan 17, 2009 | Smeg DO81CSS Electric Double Oven
    Whirlpool oven door
    The metal bars go under the top door handle part, put them under the part you need to screw back in.
    Sep 15, 2008 | Whirlpool RBS245PDS Electric Single Oven
    Oven door lock
    I have a problem with the door lock mechanism. The error code suggests replacing the mechanism. My serviceman ordered the mechanism and called me when it arrived. The cost of the part is $239 which with the labor involved is neaing the price that I paid for the oven. Evidently this is a common problem with this particular oven.
    Dec 18, 2007 | Whirlpool RBS305PDS Electric Single Oven
    Ovens Logo
    61 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
