Question about HP Photosmart 7520 All-in-One Color Inkjet Printer - Black
My HP 7520 printer isn't printing right. The black comes out looking like a negative. I have all new ink cartridges-what's going on?
Nothing-I've been trying to print pictures from my sd card from my Sony Cybershot camera and started having the above problems. What can be done?
    Director Badge:
    Uploaded 100 video answers.
  • HP Master
  • 685 Answers
This video shows how to troubleshoot printed image quality.
Posted on Dec 04, 2014
  • 30 Answers
SOURCE: Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Posted on Aug 19, 2008
  • 5 Answers
SOURCE: Blank Ink not pumping to print head
Turn off the device after removing the printhead After removing the printhead, turn off the device, wait about 20 seconds, and turn it on again without the printhead installed. After it has restarted, reinsert the printhead.
it will go through this long routine of perhaps 20 min or so. after its compleate it should print great.
Posted on Nov 28, 2008
rulds2008
  • 3866 Answers
SOURCE: Printer won't print in black ink.
Plunger needs to be cleaned, print head also would need to be looked at on this one.
Posted on May 21, 2009
  • 19 Answers
SOURCE: hp psc 750 won't print with new color ink cartridge
To solve the printing problem..
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
Posted on Aug 24, 2009
  • 5 Answers
SOURCE: installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Posted on Jan 22, 2010
I put in a black ink cartridge and my hp photosmart 7520 printed a few copies and then I couldn't print after the first few copies - what should i do to check my hp 7520 ?
Is that a compatible cartridge!
Pay attention! if the printer won't print change the cartridge, don't try to print pages with a finished cartridge or you'll burn your printhead!
If the cartridge is HP genuine do a cleaning cycle, if it helps, great, if it won't give the cartridge back for "defective", HP Cartridges always have a warranty
Hope you found it useful!
Dec 17, 2015 | HP PhotoSmart Office Equipment & Supplies
Unable to clear missing/damaged cartridge msg even after cleaning.
why does my printer say ink cartridge missing or damaged ...
h30434.www3.hp.com > Printers & All-In-Ones > Print Issues
Aug 8, 2012 - 10 posts I recently changed my ink cartridges ( colors and black) and now it says that the ... why does my printer say ink cartridge missing or damaged? ... cartridge from Office max and it still has the message and I am unable to print. ... Remove the cartridge and take a close look at the tiny circuit card on the section ...
Nov 30, 2015 | HP Photosmart 7520 All-in-One Color Inkjet...
My printer states "paper jam" although I don't see any paper. I bought new ink cartridges & it doesn't print the multi-color, only the black.
Paper jam means just that. Look for paper or a piece of paper jammed into a gear or stuck between a roller or even in your ink cartridge . When you put in your new ink did you take off the protective seal and run the HP software to check if it is reading the Cartridge ,You might want to read the instruction on how to install an ink cartridge. It might also help you ?
Nov 03, 2014 | HP Deskjet 3052A
Does startup ink cartridge have to be replaced after it is empty
Yes if you want the printer to print. Many printer makers are using startup carts now so you will buy the new ones soon. I would wait until you can no longer put up with the warning message or it runs out of ink to replace the cartridge.
Oct 15, 2014 | HP Photosmart 7520 All-in-One Color Inkjet...
How to make the HP Deskjet 3054 Print in only black
Select 'Print' from your software package and then 'Preferences'. Select the 'Color' tab, click on the 'Print in Greyscale' box and select the 'Black Cartridge' box..
Jul 13, 2011 | HP Officejet 5610 All-In-One InkJet...
I've got a HP C4780 printer which I have had for around a year but only used about 5 or 6 times! Despite the ink cartridges having ink in them, the black cartridge is not printing at all. Not even a...
The ink solidifies right behind the micro printing nozzles. The only way to attempt to rectify this is to dip the print face into some warm (not hot) water for a minute or two, and dry after wards. If the cartridge recovers, Yippee, if it doesn't, replace.
Common problem. Be thankful it isn't a Canon or Epson, which entails replacing a seriously expensive 'print head'.
Jun 08, 2011 | HP PS C4780 All in One InkJet Printer
Hp photosmart 8050 won`t print black even though it says it full
Hi there! If you haven`t used the printer in 2-3 months the black ink cartridge has gona dry.Wich means the printer is seeing full ink but the ink isn`t actually coming out from the ink head.Take a peace of clean cloth or cotton and clear the bottom part of the ink head(be verry carfully while cleaning it cuz you may dmg the head.If that doesn`t help just go and buy a new ink cartridge and it will solve your problem.
Nov 10, 2010 | HP Photosmart 8050 InkJet Printer
Hp psc 750 won't print with new color ink cartridge
Aug 24, 2009 | HP PSC 750 All-In-One InkJet Printer
HP Photosmart 7520 All-in-One Color Inkjet Printer - Black Logo
102 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
