Question about Frigidaire Dishwashers
The rinse aid error warning comes on and cycle stops. Filling rinse aid dispenser does not fix problem. What is wrong?
It is model # bghd2433kf1
  • Official Brand Answer
  • 2,267 Answers
I appreciate your post, jake!
Based off the information you have provided it sounds like a potential problem with your rinse aid dispenser or control panel within your Frigidaire dishwasher. I would recommend performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for ten minutes. If you continue to have issues with the dispenser I would recommend contacting a professional technician for proper diagnosis and repair. Hopefully this is helpful. -Matt
Posted on Dec 06, 2014
  • 27 Answers
SOURCE: Rinse agent dispenser
The only "fast" way is to remove the dispenser completely and rinse with warm water until clean! (by removing front panel and then disconnecting jumpers and clips...can be tricky to do alone, as you need 3 hands to pry clips from dispenser to remove from door!) Oshie.
Posted on Jun 26, 2007
Kazong
  • 152 Answers
SOURCE: Filling the rinse aid compartment
1. Open the container by turning the lid anticlockwise.
2. Add the rinse aid until the container is completely full.
The indicator will be completely dark
3. Top up the rinse aid when the indicator becomes
clear.
(Only for models with rinse aid indicator light)
Top up with rinse aid when the rinse aid indicator light on
the control panel illuminates.
Ensure that the lid is closed after every refill.
**** THIS IS THE LINK BELOW FOR THE USER MANUAL******
http://www.usersmanualguide.com/electrolux/dishwasher/esl4114
just copy and paste into your browser select the last pdf file when the page opens
Thanks for useing FixYa.
Posted on Feb 05, 2008
SOURCE: Rinse Aid does not dispense
http://www.partselect.com/ModelFrames.aspx?ModelID=149370&ModelNum=PDB2600AWX&mfgModelNum=&ManufactureID=1&Selected=54869&Position=1&mfg=Maytag&Type=&Mark=3
From diagram RINSE AID & SOAP DISPENSER, replace 138912t.jpg PS138912
Wax Motor for Detergent Cup Actuation.
Posted on Apr 27, 2008
SOURCE: put rinse liquid detergent in dishwasher rinse aid compartment.
I did the same thing with my Maytag dishwasher, several times actually, before realizing I was putting blue dish soap in the rinse aid compartment which then wouldn't empty. Then my Maytag started making ominous noises during the rinse cycle (appliance guy said it was "cavitation" noise).
Appliance guy wanted to replace the whole detergent/rinse aid compartment but since he told me the noise was probably caused by the dish soap stuck in the rinse aid compartment, I decided to try to get rid of it first. Here is the method that worked for me; it took most of a day but saved me parts & labor:
1. Get some white vinegar--I used nearly a quart.
2. Fill the rinse aid compartment to brim with the vinegar (overfill) but don't put cap on
3. Raise the dishwasher door slowly until the vinegar drains into the lower part of the chamber (at least this is how my Maytag worked)
4. Agitate the contents as best you can by rapidly shaking the dishwasher door up & down.
5. I also used a small plastic medicine dropper jammed into small openings on each side of the rinse aid compartment to agitate the vinegar by squeezing air into them.
6. Drain the compartment by closing the dishwasher door (move it to full vertical)--vinegar will drain into the bottom of the dishwasher.
7. Repeat above steps a couple times, then fill again w/vinegar, put the cap on and let it stand for awhile. Then drain and repeat the whole routine several times.
8. Blue-colored vinegar will come out which is a good sign (or whatever color your dish soap was).
9. After awhile, I started pouring generous amts of very hot tap water thru the rinse aid compartment, alternating with white vinegar. (No reason you can't use hot vinegar also.)
10. Eventually, all the blue stuff came out & the see-thru levels of the rinse aid compartment were completely clear/empty.
11. Run the dishwasher (I decided to not put any rinse aid in). I got some overfoaming (from the washed out soap) the first time I ran it which I probably could have remedied by adding more vinegar & possibly salt, but the noises were gone!
I just ran the cleaned out dishwasher a 2nd time & it was back to its quiet self with no overfoaming.
Takes some patience but hey, beats a big repair bill!!
Posted on Apr 30, 2009
SOURCE: Bauknecht GSX4756 dishwasher
I have this problem frequetly - it's an easy one to fix! Just press the programme button which changes the programme setting you want (on my built-in GSX4756 it's the last button on the right) and keep it pressed in until the beeping stops. Then start it again (will probably be on the rinse programme if it's like mine).
Posted on May 12, 2009
Dishwasher suds up and leaks during wash
Suds in a dishwasher usually come from using too much soap or the wrong kind. Soap can build up over times causing problems. First start a cycle.Do not add detergent or any dishes.When it starts washing, pour a cup of vegetable oil directly into the tub. This will cut the existing soap suds. You may need to try this a couple time before the dishwasher will drain. After all suds have been removed, load you dishwasher and start a cycle filling the detergent cup up half way. If it goes through the cycle with no problems, you should be all set. Still have the problem? A rinse aid dispenser that dispenses too much rinse aid will also cause the dishwasher to suds up. You can remove the dispenser from the door, flush it out and reinstall. Make sure you turn the circuit breaker off before taking the door apart. After rinsing it out, do not add rinse aid. Try the dishwasher and see if the problem goes away. I've seen people accidentally put liquid dish detergent in dispensers too. A dishwasher that has suds is apt to leak. Fix your suds issue and you most likely will fix you leak
Dec 27, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
There is still soap running down from the dispenser after each cycle.
Hello creativee798 - If you put regular dish soap in the dispenser, then you could encounter oversudsing and leaking through the door. Here are some tips for minimizing and maybe even eliminating the sudsing problem:
If you have a turkey flavor injector, you may be able to use this item to **** the detergent out of the rinse aid dispenser. Open the dishwasher door and fill the dispenser with water and then **** the liquid out with the injector. You may also be able to use a syringe without a needle that is used to dispense liquid medicine for a child or baby. If you alternate filling the dispenser with water and then removing the liquid, you will eventually dilute or eliminate the detergent that was in the rinse aid dispenser. Once you dilute or eliminate the detergent, fill the dispenser with water. Set the dispenser on the highest setting and run a cycle to see if you see excessive suds during the final rinse cycle. If you don't see a suds problem at the end of the washer cycle, then I recommend taking as much of the water out of the rinse aid dispenser as possible and filling it up with rinse aid and then returning the dispenser to the normal setting that is appropriate for your water hardness. If you are seeing excessive sudsing, then you may need to try to flush the dispenser with the fill and drain routine again. You may need to change the setting to the minimum and see if you detect a suds problem. If not, then allow the dispenser to empty at the minimum setting and then fill it with rinse aid after it is empty. I don't recommend using the heated dry until this problem is completely resolved. This could cause residue to dry on the dishes. If you detect residue on the dishes after the cycle is finished, you may need to wipe the dishes off as you remove them. Excessive suds and possibly residue on dishes would be the only consequence of this mistake. The excessive suds could cause leaking out of the front of the dishwasher door if it is severe enough. The dishwasher may not drain properly if excessive suds are present. The above tips should help you minimize or eliminate these consequences, if any proves to be ineffective contact a professional to move forward accurately.
Dec 02, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
The dishwasher doesnot dry anything.
  • Check the rinse aid indicator beside the rinse aid dispenser cap. If the indicator window is clear, refill the dispenser. The dishwasher will retain moisture and the heat dry option will not perform properly without rinse aid. Turn the dispenser cap clockwise and lift it up to remove it. Pour rinse aid into the dispenser until the indicator appears full. Place the dispenser cap over the dispenser and turn it counterclockwise to tighten it.
  • Load the dishes properly so that all dishes can drain after the rinse cycle. Do not overload the dishwasher. Towel-dry plastic dishes because they will not dry completely during the dry cycle.
  • Select the heated dry option on the dishwasher. The air-dry and energy-saving dry options will not perform as well as the heated dry.
  • Oct 10, 2010 | Whirlpool Dishwashers
    My dishwasher is leaking huge amounts of foam to the floor. This is what happened before I ran the cycle: I had mistakenly poured detergent into the "Rinse Aid" slot in the inner side of the dishwasher...
    OK.... The rinse aid dispenser holds enough rinse aid for a lot of washes and dispenses very little each time. So you may nedd to have the dispenser emptied by a technician. If you take the door liner off you can see the back of the dispenser and maybe you can work out how to empty it. Holding the actuator in manually could allow the rinse aid dispenser to run out. Then wipe the tank dry with a towel. Putting high fat milk in the machine while it is rinsing will neutralise the foam. Just one cup will do. Good Luck.....T.
    Aug 01, 2010 | Dishwashers
    I have a Maytag Jetclean and it doesn't rinse well
    Probably unlikely that it's clogged, but rather defective.
    Feb 25, 2010 | Dishwashers
    "clean" light is blinking
    Check the following:
    1. Is the overfill protection float able to move up and down
    freely? Press down to release.
    2. Be sure the water supply is turned on to the dishwasher.
    3. Check for suds in the dishwasher. If foam or suds are
    detected by the dishwasher sensing system, the
    dishwasher may not operate properly or may not fill with
    water.
    Suds can come from:
    1. Using the incorrect type of detergent, such as
    laundry detergent, hand soap, or dish detergent for
    hand washing dishes.
    2. Forgetting to replace the rinse aid dispenser cap
    after filling (or refilling) the rinse aid, or spilling rinse aid into the tub (rinse aid causes suds to occur).
    3. Using an excessive amount of dishwasher detergent.
    Mar 16, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
    Rinse solution stays on the glasses
    First chech the machine is warming the rinse water and not rinsing in cold water then have your chemical guy come and check that the soap/rinse ad dispenser is not dispensing too much rinse aid and naturally make sure the machine is in fact ricing with water I have had it where a glass washer takes more rinse aid then i should and does not actually rinse with clean watr it was simply spraying the rinse aid wich sounded as if it was rinsing soulution was new pc board it was not changeing programs properly if you have and older machine it proberly has a timer this too can be a cuase of the problm if it is not clicking over to allow a full rinse cycle.Hope this helps let us know.
    Jan 17, 2009 | Hobart 29 in. AM15-1 Free-Standing...
    Kenmore dishwasher model 665
    rinse aid generally dispenses automatically in cycle, very small amount every time. why do you think its not dispensing?
    Feb 22, 2008 | Dishwashers
    Dishwashers Logo
    174 people viewed this question
    Top Frigidaire Dishwashers Experts
    Mike
    Charles T Nevin
    Charles T Nevin
    Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
