Why is my Phillips tv screen flickering and going in and out?Very bad video on model# 32hfl5561v/27.
Tried any and all cables for bad connection.
    Problem Solver:
  • 6 Answers
CRT base or picture tube itself!
Posted on Dec 15, 2014
SOURCE: JVC Tv Constant Blue screen
if you have the remote control number RM-C203 with your tv than try noise muting in your menu settings mine did the same thing i just put noise muting off and it worked for me
Posted on Nov 01, 2007
  • 55 Answers
SOURCE: screen is black
on that tv you have to check just for circuit of high voltage - check
transistor near flyback transformer - delfo
Posted on Mar 22, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Posted on Jun 28, 2008
  • 41 Answers
SOURCE: tv code search
I can give you these. You should try them until one works hopefully. 0506, 0311, 0612, 0002, 0428, 0802, 0412, 0619. Sometime the universal remotes will not operate everything so be sure to try the power on/off and the volume and try changing channels before assuming the code is wrong. One of these should work...
Posted on Aug 04, 2009
  • 8457 Answers
SOURCE: channel tuning 1994 Magnavox 27'' TV
U the remote to turn to the channel 3.
Posted on Nov 18, 2009
Flickering screen
Try an external monitor to the laptop and see if it flickers. If it does, more than likely your video card is going bad. If it does not flicker on the external monitor you probably have a loose video cable or lcd inverter cable. Go back inside and remove the 2 cables that go into the LCD Inverter that sits at the bottom of the LCD Screen, then plug them back in. Then unplug the video cable at the top behind the lcd screen, plug it back in and secure it with a piece of tape right where the two connections meet.
Mar 28, 2012 | ASUS U52F-BBL9 Laptop
Why can't I get reception on my TruTech tv model DW19TT even after plugging in a Phillips digital indoor tv antenna
If the antenna is working and you are not receiving a signal, then you could have a bad tuner, use a tuner from a VCR , connect the ant to the VCR and go from the VCR with Video cables and go to the Video input on the TV and put your TV in Video mode. That will work.
Nov 26, 2011 | Televison & Video
Samsung tx-p2734 TV Issues: Wavy lines on SIDE of tube...
For the buzzing noise try tipping tv jently forward and jently placing back.
May 07, 2009 | Samsung TXP2734 27" TV
White horizontal lines in my 27 in Phillips Magnnavox tv
I have seen this on mine. Check the cable going into your TV and make sure it is good. The ground portion of the cable could not be making a good connection.
Jan 17, 2009 | Philips Magnavox 27MS343S 27" TV
Flickering multi-colored line in the middle of the screen.
You have a failure in the vertical deflection circuit. This could be either a bad vertical chip, the power supply that runs the chip or a bad capacitor in that circuit. This is usually a repair best left to a professional. There is a small possibility that it could be bad solder connections. If genlty tapping the unit temporarily solves the issue you can try and resolder the pins on the vertical chip LA7841 is the part number. There is also a resistor 1 ohm 1 watt. If that resistor is open you can assume the IC is bad
Oct 26, 2008 | Sanyo DS27800 27" TV
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
TV seems to be "stuck" in VCR mode after power surge
your tv is playing dvd means your video &sound section is ok. as it is not playing cable means that there a problem in tuner section only. if cable connection &its socket is ok.
Sep 25, 2007 | Philips TS2768C 27" TV
Tv flickers when people walk in the room
Check for lose connections at the cable in thw rear of the television. Or look for a damaged wire.
Jan 05, 2007 | Panasonic CT-27E13 27" TV
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
