The display on my Ampam by Honeywell programmable thermostat displays all 8s. Is it time to get a new thermostat?
Last night, December 2nd, 2014, we had a power outage. Since the power came back on the display has read all 8's. Is this fixable or should I get a new one?
  • 3,289 Answers
"Funky" displays often indicate a problem with a control or processor. The simplest fix is removing power for a minute or two and trying again.
Doing this will likely erase any time / temperature program in the t-stat, so you should make note of it before attempting.
I'm not familiar with the t-stat you have, but if it is like most - it has a battery or two inside to maintain the program during power outages (and allows programming while in your easy chair). You should remove the battery(s) and remove it from the wall (most will simply pull away when unclipped / disconnected) to completely power down. Wait a moment and reinstall the battery(s) and reinstall to base on the wall.
Posted on Dec 03, 2014
My Honeywell programmable thermostat's display is blank and I do not have any heat?
The thermostat, depending on the model, normally does not get powered by batteries, they are for backup power. You might be losing 24 volt from the furnace, causing the thermostat to run on batteries.
Apr 09, 2014 | Honeywell Programmable Thermostat Heater
Honeywell thermostat blank screen on cool
I wonder if they shorted a wire a during install. That is where I would begin.
May 14, 2013 | Honeywell Rth2310b 5-2 Day Programmable...
Honeywell thermostat won't turn the furnace on after power outage.
probably tripped a limit switch or a low voltage fuse would kill your display on the tstat, you should have battery power on your stat though.unless you have knowlege of electrical you better call a technician
Dec 09, 2012 | Honeywell Programmable Thermostat Heater
I have Honeywell T8011R programmable Thermostat. Turn AC on last night for first time...working fine...came back late morning to find display and fan off. Check circuit breaker...on. I took it off and...
Hello, first you must verify if you are getting 24 volts to the tstat at the secondary side of the transformer, if not you have a bad transformer. If you are getting 24 volts then check the batteries in the thermostat.
Apr 12, 2011 | Honeywell Programmable Thermostat Heater
My Honeywell Programmable Thermostat RTH2410 operates intermittently, the entire unit , display and all, turns on and off at various times throughout the day.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You need to reset the t-stat and totally reprogram it...
Look in your manual how to do that or...
Here is a tip that tells you how to get a manual for most any Honeywell product online...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Sep 13, 2010 | Honeywell Focus 6300B 5-2 Days...
My honeywell theromstat keeps displaying repl bat
Have you checked to make sure the batteries are, in fact, good and that they are facing the right way? If so, it's time for a new thermostat.
Oct 03, 2009 | Honeywell Programmable Thermostat Heater
EEE display code error on CT3600 Honeywell
I am a honeywell dealer and this stat is obsolete and no longer supported. I am not able to pull any info on this. It might be time for a new one.
Oct 01, 2009 | Honeywell Electronic Programmable...
Honeywell Programmable Thermostat Display issues
there are currently 60 honeywell thermostats made i have no idea witch one you have , but a lot of the new ones run on batterys you might be seeing a low battery signal . look for a door where batterys might be and replace them
Jan 14, 2009 | Honeywell Programmable Thermostat Heater
Honeywell T8011R
Check for either an in-line fuse in the heating unit or a fuse on the control board also in the heating unit.
Nov 06, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
125 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
