I have a Kenmore model 110 top loader. Will not drain or spin on any setting. I have checked and bypassed lid switch, I am able to lower drain tube to manually drain washer. Any suggestions?
    Problem Solver:
  • 6 Answers
Two listed causes for this problem are bad or broken drive belt (I would suspect warn if it still agitates, but does not spin).
Next one is bad drum motor and that calls for a replacement of the part.
I would myself look at a possible third.
You have a pump located at the outlet tubes connecting point beneath the drum. I would check that to see if it makes a clicking sound first to see if power is reaching so that it is getting power. If it is, then I would check the wiring to see which leads power the pumps motor and bench test it (after removing it) to see if it is frozen.
If it is not then check to see if the impeller itself is turning.
If frozen ir still working but impeller isn't turning you need to replace that.
I actually would bet 5 bucks that there is your problem.
Good luck.
I have a Kenmore model 110 top loader.  Will not - 25305858-tbcnxa0kixjbbgogapnbn1pd-3-1.jpg
Posted on Dec 03, 2014
24032 \ 24036 Top Load Washer my kenmore model 110-24422300 will not start wash cycle. Will fill tub to set level and stop.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024422300/0582/0153200?searchedModel=24422300&blt=06
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Nov 06, 2010 | Washing Machines
My kenmore ultra fabric care heavy duty 80 series model 110 will not drain. The problem occured after a heavy load knocked the lid switch off during the spin cycle. How do i fix this/replace the lid...
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Nov 05, 2010 | Kenmore 24032\24036 Top Load Washer
I have a kenmore 70 series top loader washer, model # 110 20712 991. It stops during the rinse cycle and does not spin or drain???
Sep 15, 2010 | Kenmore 22422 Top Load Washer
Kenmore 90 series Model 110 20902 990 does not drain or spin. The lid appears to be fine. I have tried depressing the switch with screw driver but it does not work.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20902990&pathTaken=partSearch
If it works, the Lid Switch is a relatively inexpensive part (about $37) and only requires you to access the console and remove the cabinet.
May 26, 2010 | Kenmore 24032\24036 Top Load Washer
No Spin Cycle in Kenmore 80 Series Top Loading Washer
First, see the Sears parts site for your washer: Following is the Sears site for Whirlpool (110.) models with your model number.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.23812100
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
If it works, the Lid Switch is a relatively inexpensive part.
Jan 18, 2010 | Kenmore 22422 Top Load Washer
The water in my washing machine does not drain once it goes to the spin cycle. How do i get the water out and what do you think the problem is?
Can you provide the exact Make, Model and Kenmore model number?
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.
Assuming that it does spin, the problem points to the drain pump and/or clogged hoses.
See the following on how to remove the cabinet and pump.
Remove the hoses carefully and drain the water into a bucket or tub.
Check the hoses and look inside the pump (try to turn it by hand) to look for obstructions.
If it won't spin or drain, the first thing to check is the Lid Switch.
See the following on how to bypass the switch.
Nov 02, 2009 | Kenmore 22422 Top Load Washer
Doesnt spin or drain
Sounds like its a pump problem if pump dosent work the rest of the cycle wont either maybe pump belt has come off or has broken hope this helps
Sep 06, 2009 | Kenmore Washing Machines
No Spin No Drain
Lid switch is most likely the problem, if lid switch is visible under lid on right side then this is older design and common problem switch.
if you have console frame covers on front sides, snap off from top, a screw is at bottom front corners of console, remove and pull console forward and fold back. If lid swich is hidden then you will see it at left on top of cabinet with console folded back. a 5/16 screw holds a green ground wire to cab. remove and switch will unclip with lid up. If lid switch was visible under lid then you need to remove 2 brass clips holding cabinet on top of base to back, pry with screwdriver to unclip. undo harness connection on cabinet top, this is your lid switch connection. sw body is held by 2 phillips screws, harness tube held by clips on underside of cabinet top. ground wire with 5/16 screw present at sw body. New versions of this switch have metel shield attached.
Apr 25, 2009 | Kenmore 22642 Top Load Washer
Won't drain or spin
your lid switch is bad,you need to get under the cabinet to cut the 2 lid switch wire and wire nut them together to bypass the lid switch and your done ,make sure you unplug it first,let me know how you do-mike
Oct 21, 2008 | Washing Machines
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
