Question about Car Audio & Video
Sony Bluetooth audio system won't respond to face buttons
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,226 Answers
You may have a bad switch. If you have a switch that is not closing completely it could be sending voltage to the microprocessor stopping it from doing any other functions. The microprocessor can handle only one function at a time.
Posted on Dec 08, 2014
JVC KD-R330 Won't turn off Demo mode - tried instructions. Every time I follow the instructions (Turn on, Hold Menu, push "vol" button, change to Demo off...etc) It doesn't work. In fact, as soon as I...
Do you have a Bluetooth adapter plugged into the KD-R330?
A compatible Bluetooth adapter (like the KS-BTA100) usually plugs into the rear auxiliary port of the receiver. It then needs to be "paired" with your Bluetooth device, for example, a Bluetooth phone headset.
What you're describing sounds like what can when no Bluetooth device has been "paired" yet.
If you don't HAVE a Bluetooth adapter connected to your KD-R330....is it possible you accidentally plugged something into its rear auxiliary jack? Or the front auxiliary? In other words, is it possible your KD-R330 receiver is mistaking some other device for a Bluetooth adapter?
Don't know if that helps at all...if there's no adapter issue, and nothing connected to the AUX jacks, probably your next step should be a call to JVC, or whatever number you were given for tech support.
On the bright side, since the receiver turns on, and responds to some commands, you probably didn't mess up anything major in the wiring. And, there's also the possibility the receiver is defective....certainly if this continues, and JVC can't help you, trying a replacement might be worth a try.
BTW, feel free to post a reply...I'm going to look further to see if there's any other documented issue besides an adapter that might cause the problem you're having.
Oct 29, 2013 | JVC Car Audio & Video
How do you remove the faceplate on a KDC-U7049BT
The face eject button should be on the upper left hand corner of the face.
Dec 17, 2012 | Kenwood Kdc-u7049bt Bluetooth Car Audio Cd...
Buttons on my sony CDX-GT540UI stopped working
Sony car radio cdxgt540ui buttons non responsive - remove four screws on reverse side of faceplate, pry open with fingernails starting at the top right or left corner of the face plate once opened remove board on the reverse side of the LCD there are small brackets holding the LCD use a needle nose to pry each bracket in straight position then remove LCD for ten seconds then place back on to board and been brackets back in place. After these steps the front buttons should work again this process worked for me.
Mar 16, 2012 | Car Audio & Video
I have a Sony Eplod MEX-BT2800, all of a sudden the buttons/functions won't work, I currently have a CD in the player, the buttons to skip songs won't work and I can't even eject it. Also I...
Hi i removed the positive on the battery terminal and tried the stereo still no buttons work although the source button and volume work but thats it any ideas thank you
Jul 06, 2011 | Sony MEXBT2800 AMFMCD Car Stereo Receiver...
Bluetooth connection not working. Tried with a couple of phones to find the player with no success.
Make sure that the mobile phone which you're trying to use is paired with the Car Audio System.
Check if the Blue-tooth icon at the front panel display is lit.
If the pairing is completed, try connecting the device to the head unit. Press and hold the BT button for 3 seconds to connect the mobile phone unit to the Car Audio system.
If the unit is not getting connected, then try to RESET the unit by pressing the Reset button located inside the front panel using a sharp pointed object. Once the unit is reset, try pairing the unit again and then connecting the devices.
You may also check the compatible Bluetooth devices with the Car Audio System.
Thanks for using FixYa.
Feb 15, 2011 | Sony MEXBT3800U Xplod Bluetooth for Car or...
I tried to connect my emerson 227 bluetooth to my ps3. it tells me to press the start button and enter button on the device at the same time and wait until the screen changes.. well it never changes.. what...
Pairing the Headset with a Sony Playstation3 Entertainment System:
To pair your [EM-227] Bluetooth Headset with the Sony Playstation3 (PS3), go to the PS3 main menu, scroll to "Settings" and select.
Scroll to "Accessory Settings" and select.
Scroll to "Manage Bluetooth Devices" and select.
The menu will ask: "The Bluetooth device has not been registered. Do you want to register it?"
Select YES.
Put your [EM-227] Bluetooth Headset into discover mode (see X.XX of this manual for instructions on how to get the headset into discover mode).
Select "Start Scanning" from the PS3 menu.
Once the PS3 has discovered the [EM-227] Headset the screen will read "Select the Bluetooth device to register".
Select [EM-227].
The PS3 will ask for a passkey. Enter [0000] then press "OK".
Now press O (the PS3 circle button) to get back to the previous menu.
Scroll to "Audio Device Settings".
Change the "Input Device" to [EM-227].
Note: "Input Device" is the microphone, how others will hear you speak.
By default, the "Output Device" will now switch to [EM-227].
Note: "Output Device" is the audio, how you will hear the PS3 audio and others speaking.
If you would like to hear the PS3 audio and others speaking through your TV or Audio System, scroll to "Output Device" and switch to "System Default Device". If you would like to hear sound through the [EM-227] headset, then leave the "Output Device" setting on [EM-227].
To test your connection, speak into the headset and you will see the bars above the "Microphone Level" moving. If not, repeat the pairing process.
Press "OK" to confirm the new settings. You are now ready to use the [EM-227] Bluetooth Headset with your PS3 Entertainment System.
For further assistance with Bluetooth settings on your PS3 please refer to your PS3 instruction manual.
Oct 06, 2010 | Samsung WEP200 Headset
How to make Bluetooth discoverable
I have this radio also, and it took me a minute to get it to work. If I remember correctly, there is a button on the top left of the face that says BT. Press and hold this for about 5 seconds, and it should activate the internal Bluetooth. Not sure if I am right or remember all the steps, so here is the manual as well:
http://www.docs.sony.com/release/MEXBT2500_EN_ES_FR.pdf
Sep 27, 2009 | Sony MEX-BT2500 CD Player
CMT-BX5BT SONY spkrs aren't pulling in music (via BT) from laptop
I had the same problem. Here's the fix:
Control panel- Hardware & Sounds- Manage Audio Devices (under Sound)- Select Bluetooth Stereo Audio as default (right click- default) and Enjoy!
Dec 31, 2008 | Sony CMT-BX5BT Shelf System
Sony CDX-M8800 face plate is non responsive
There is a ribbon cable that tells the face what to do. You will have to take it in to get serviced as it is very hard to change. There are alot of pieces / parts inside.
hope this helps
May 30, 2008 | Sony CDX-M8800 CD Player
Car Audio & Video Logo
41 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
