Question about DISH Network Hopper Whole-Home HD DVR
Where do i enter device ncode - DISH Network Hopper Whole-Home HD DVR
Pairing codes for bluetooth
When you are pairing two devices (your phone with another phone, or your phone with a computer for instance) with bluetooth, you may be asked to enter a code. This ensures that someone random can't connect with your phone without your knowing about it or giving permission. Depending on the two devices, one device may automatically provide a random code, which you then enter into the other device. Other systems ask you to enter a code. Just make one up, any code will do. Just be sure you enter the same one on both devices! Best of luck!
Aug 11, 2014 | Kyocera Cell Phones
Hi iforgot my ipad pasword help now urgent
From the Apple Support website:
iOS: Forgotten passcode or device disabled after entering wrong passcode
If you enter the wrong passcode six or more times, you'll see a message that says iPad is disabled.
If you have previously synced your device with iTunes, you may be able to reset the passcode by restoring the device:
Connect the device to the computer with which you normally sync and open iTunes.
Note: If iTunes asks you to enter the passcode, try another computer that you have synced with. Otherwise, go to "If you have never synced your device with iTunes, or you do not have access to a computer" section below.
  • If the device is still disabled, or if iTunes does not automatically sync your device, sync the device with iTunes.
  • When the backup and sync is complete, restore your device.
  • When iOS Setup Assistant asks to set up your device, choose "Restore from iTunes backup".
  • Select your device in iTunes and choose the most recent backup of your device.
If you see one of following alerts, you need to erase the device:
  • "iTunes could not connect to the [device] because it is locked with a passcode. You must enter your passcode on the [device] before it can be used with iTunes."
  • "You haven't chosen to have [device] trust this computer"
iOS Forgotten passcode or device disabled after entering wrong passcode
Jan 30, 2014 | Apple Ipad 3 16gb Wi-fi Only Md328ll/a...
I have a 97 toyota camry 2.2, will not shift into overdrive.\r\ncode for the problem is PO755 B, where is this solenoid located. Transmission is A140E
solenoids on this vehicle transmission is located inside the transmission. You must drain the transmission oil, then remove the transmission oil pan to access it.
May 23, 2011 | 1997 Toyota Camry
How to enter codes on remote control
For the direct code entry, turn on the device that you want the remote to control. Find the codes for that brand of device. Then press and hold the appropriate device button (TV, for example). The on-off button will light up and remain lit. While holding the device button, enter the first four digit number for that make of device. The on-off button will turn off while you press the digits in the code and then come back on. Release the device button and check if the light for the on-off button turns off or blinks 4 times. If it flashes, the code was not properly entered or isn't a valid code. If the light turns off, check if the remote controls all of the functions of the device.
If you didn't enter a correct code or the remote doesn't control all of the features of the device, repeat the steps above. (Either correct the original code that you entered or enter another code for the manufacturer/device.)
Please note that universal remotes have code lists that are limited to those for devices released 6 months or more before the remote was programmed. If your device is newer, then you may need a new remote.
The documentation for the remote is here: http://voxrightnow.custhelp.com/app/answers/detail/a_id/11073/~/programming-the-rca-rcr311b-remote-control .
I hope this helps.
May 12, 2011 | RCA RCR311B Remote Control
I have forgot my ipods 4 didgit ncode and inne to fing a way to unlock it
You will have to put the iPod into DFU mode - Then plug into iTunes and click the restore button.
To access DFU mode, reset the iPod with MENU+SELECT(middle button), then press and hold BACK(rewind)+PLAY. A picture of the dock connector should appear.
Hope this helps.
Dec 14, 2010 | Apple iPod nano
PUK code
The puk code is provided along with your pin code from your network provider, and depends on your sim card. The reason you are asked for this is probably that you have entered wrong pin more than 3 times. The puk can be entered 4to 8 times before it completly blocks your SIM.
Contanct customers service at your provider.
please rate my solution.
Feb 20, 2009 | LG KE500 Cellular Phone
DVD Unblock Code
i'm sorry but the dvd/tv unit is to new. they have not come out with the unlock ncodes yet. sorr
please rate
thanks
tom
Dec 23, 2008 | Televison & Video
Security ncode for nokia 6030
here you get the mastercode to reset the code - nokialockcode.com/mastercode.php
Oct 08, 2008 | Nokia 6030 Cellular Phone
I have forgot the security code of my nokia 6600 so please help me
post your imei and i will generate a master ncode for you
Jun 01, 2008 | Nokia 6600
Can't upload data to computer
Summary: Memory of device overloaded.
1 Backup your Training center data under File in program.
2 On the device (using mode button) goto History [enter] go to Running or Biking [enter] click down to delete [enter] select "Keep 1 month " [enter] select yes for confirmation [enter]
3 Reinsert device in USB cradle. Select "Receive from device" under File in program.
4 Download your latest information.
Worked for me.
Oct 25, 2007 | Garmin Edge 305 GPS Receiver
DISH Network Hopper Whole-Home HD DVR Logo
61 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
