Question about LG 32LG30 32 in. LCD HDTV
Lg 32in tv from 2007 wont come on ,only after sitting for 45 minutes and turning it on and off will it come on
    Problem Solver:
  • 20 Answers
Fairly well documented issue. It is called a Thermal Shutdown. Very little to do at this point, There were service bulletins issued if you sent in your warranty card and kept your address current with LG. As I mentioned at this point not much to do about the problem. The warranty is long expired and the repair is more than a new 32" TV
Posted on Dec 03, 2014
Lg 32in tv from 2007 wont come on ,only after sitting for 45 minutes and tuening it on and off will it come on
The fact that it comes on at all is a good sign.
Due to how long you've had it, my first suspicion is to check the capacitor in the power supply of the set. Over time, the capacitors will dry out. You'll need to remove the back and look at the power supply for bulging capacitors.
If you haven't had much experience with electronics before, here's a few tips.
Always have the power cord unplugged before opening up a TV...
The power supply is the first board that is connected to the power cord. The capacitors on the power supply board look like miniature soup cans and the tops of them should be perfectly flat. Some capacitors have a small x on the top, this is to allow expansion as the capacitor fails. Look at the top of the capacitors to see if you can see bulges in the top, those would be the first ones to suspect are bad.
Dec 03, 2014 | LG 32LG30 32 in. LCD HDTV
Rca 32in TV Product serial#f483ceok5 RCA 32in
try unplugging the tv from all imputs and power and let set over night then plug everything back in.
Feb 10, 2011 | RCA TruFlat 27F520T 27" TV
My 32In hdtv from 2007 turns on just fine then flashes polaroid and doesnt respond after that. Wats wrong?
My 32in hdtv turns on, flashes Polaroid and shows there is no signal then turns off, what could the problem be?
Jun 12, 2010 | Polaroid FLM-3232 Television
Hi my 32in lg plasma was workin last night now wont turn on
this is the ysus board u can replace for around 100£
easy if u have a screwdriver and patients,,
and make shure the tvs switched off for a day before u replace board ,,
replacement type this in on ebay..
6871QYH053B
theres one guy on there 64.99 and 12£ swop your old one for this,,
i tend to replace the hybrid chip myself ,, but this guy has loads no its not me,,i dont have the time,i own my own tv repair business, so, hope this helps.
May 21, 2010 | LG 42PX5D 42 in. Plasma HDTV
Power turn off after 45 minutes to 1 hour used
Check the "Sleep Timer" settings. If set to 45 minutes then TV would automatically turn itself off 45 minutes from being turned on. The variance in the "on" times is due to the TV turning itself off after not getting a signal from the remote for fifteen minutes.
Good luck,
Techjoel
May 09, 2009 | Sony KDS-60A2000 60" HDTV
LG 50" plasma will turn on then shut off shortly there after.
Unplug the power from the power outlet and let it sit for a few minutes. Then plug it back and it should work normally.
Apr 27, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
Why when I watch my new 32in sharp flat screen I seen lines ?
What you need to do is call sharp and make them aware of this problem. If you are under warranty, they will take care of it. If the model number of your tv has SB in it, you will have to take the unit to one of their authorized service centers in your area(which could be anywhere from 1-45 miles away from you). If you have a AQUOS unit, they will send someone to your home, either way, they will take care of it. give em a call, you have a service issue on your hands. good luck 2 u
Jan 31, 2009 | Sharp LC-32SB24U 32 in. LCD TV
TV turn off every 45 minutes
6 blinks = thermal sensor. in rare cases its the power board but in this case its usually a faulty thermal fuse. it sits under the lamp and can be tested with a multimeter or ohm meter. you can short it out and the tv will work but it will lose its fire safety, but this can get a temporary fix until you get a new fuse. the new sony fuse is like $15 for the part i believe. let me know how you want to procede.. repair center cost = 100-200 $ hopefully
Jan 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Feb 06, 2007 | LG 50PX4DR 50 in. Plasma TV
LG 32LG30 32 in. LCD HDTV Logo
60 people viewed this question
Computer Repairing
Computer Repairing
