Question about LG 32LG30 32 in. LCD HDTV
Lg 32in tv from 2007 wont come on ,only after sitting for 45 minutes and tuening it on and off will it come on
  • 59 Answers
The fact that it comes on at all is a good sign.
Due to how long you've had it, my first suspicion is to check the capacitor in the power supply of the set. Over time, the capacitors will dry out. You'll need to remove the back and look at the power supply for bulging capacitors.
If you haven't had much experience with electronics before, here's a few tips.
Always have the power cord unplugged before opening up a TV...
The power supply is the first board that is connected to the power cord. The capacitors on the power supply board look like miniature soup cans and the tops of them should be perfectly flat. Some capacitors have a small x on the top, this is to allow expansion as the capacitor fails. Look at the top of the capacitors to see if you can see bulges in the top, those would be the first ones to suspect are bad.
Posted on Dec 03, 2014
My LG 32in.TV I have the volume up to 100 and you can barely hear it
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
https://www.abctay.com/tv-power-supply-c-2
Oct 16, 2017 | LG Televison & Video
Lg 32in tv from 2007 wont come on ,only after sitting for 45 minutes and turning it on and off will it come on
Fairly well documented issue. It is called a Thermal Shutdown. Very little to do at this point, There were service bulletins issued if you sent in your warranty card and kept your address current with LG. As I mentioned at this point not much to do about the problem. The warranty is long expired and the repair is more than a new 32" TV
Dec 03, 2014 | LG 32LG30 32 in. LCD HDTV
During 2006, a swimming lesson at a particular school lasted 45 minutes, In 2007 the time will be 50 minutes, Find the increase in the lesson time from 2006 to 2007 as a percentage of the lesson time
Percent change =100%*(new value-old value)/(old value)
If result is positive, it is an increase. If the value is negative it is a decrease.
100%*(50-45)45=100% *(5/45) =11.11 %
Mar 30, 2014 | Casio ClassPad 300 Calculator
Every day when I first turn on my LG HDTV model 42LH30 it has the left side completely black but the right side seems normal with a distinct center vertical line. After a few minutes the left side gets...
LCD TVs are side lit with either cathode tubes or LED's (depending on the model). This saves space and allows the TV's to be so thin. The newer LED TV's are backlit, so there is an array of LED behind the screen, but because your model is side lit, most likely with a cathode tube, that the tube is on it's way out and takes an excessive amount of time to warm up and get to full brightness. You culd try looking up a part number through LG, but my guess would be it's expensive and not easily replaced. Perhaps contact a local electronics store to see if they ofer repair service and see how much it costs versus buying a new tv.
Mar 02, 2011 | LG 42LG30 42 in. LCD HDTV
Rca 32in TV Product serial#f483ceok5 RCA 32in
try unplugging the tv from all imputs and power and let set over night then plug everything back in.
Feb 10, 2011 | RCA TruFlat 27F520T 27" TV
Hi my 32in lg plasma was workin last night now wont turn on
this is the ysus board u can replace for around 100£
easy if u have a screwdriver and patients,,
and make shure the tvs switched off for a day before u replace board ,,
replacement type this in on ebay..
6871QYH053B
theres one guy on there 64.99 and 12£ swop your old one for this,,
i tend to replace the hybrid chip myself ,, but this guy has loads no its not me,,i dont have the time,i own my own tv repair business, so, hope this helps.
May 21, 2010 | LG 42PX5D 42 in. Plasma HDTV
LG TV Turns itself off
Sounds like it could be a poor connection in the power plug or a ' dry joint ' on the power board, if it's the latter, it will respond to light thumping at the side of the tv. If that's the case it needs resoldering by a technician..
good luck !
Mar 30, 2017 | LG 32LG30 32 in. LCD HDTV
Why when I watch my new 32in sharp flat screen I seen lines ?
What you need to do is call sharp and make them aware of this problem. If you are under warranty, they will take care of it. If the model number of your tv has SB in it, you will have to take the unit to one of their authorized service centers in your area(which could be anywhere from 1-45 miles away from you). If you have a AQUOS unit, they will send someone to your home, either way, they will take care of it. give em a call, you have a service issue on your hands. good luck 2 u
Jan 31, 2009 | Sharp LC-32SB24U 32 in. LCD TV
LG Plasma TV 50PC3D
The TV should be under warranty. Send back. Sounds like the panel is faulty (half the value of the set).
Feb 06, 2007 | LG 50PX4DR 50 in. Plasma TV
LG 32LG30 32 in. LCD HDTV Logo
43 people viewed this question
Computer Repairing
Computer Repairing
