Question about Air Tools & Compressors
How do i troubleshoot a high sump situation on a es8 sullair coompressor
We relocated our Sullair 3700 about 30m from air receiver, due to excess dust. Now the compressor never stops running, trips on high pressure yet the receiver is not achieving the pressure required
would say dust has done something to do with it
before you had time to move it
will need the compressor serviced
first ..in simple words
to replace the compressor pressure shut off /turn on valve
that should fix the pressure trip build up limit problem
and maybe a partial strip down to clean out the casing
if dust build up is noted
Oct 14, 2016 | Sullair 350 Air Compressor; Sullair...
Type of d a torque fluid used in sullair 185Q air compressor
contact sullair for this as the correct oil is essential for good performance. You may find the information on the web under sullair compressors.
Jul 21, 2013 | Cars & Trucks
Sullair compressor
check condition of air filters and dryer filters.
May 16, 2013 | Sullair 350 Air Compressor; Sullair...
I need a workshop manual for sullair electric compressor model DXN20AC 92KW
You can contact your local Sullair distributor. Many of them will email a copy if it is available. You can find your dealer by going to Sullairs web site and on the industrial tab, look for reps.
Sep 07, 2011 | Air Tools & Compressors
Where is the oil filter and the bolt on a 1995 Isuzu trooper
Hi Cortina,
The oil filter is located on the opposite side of the engine to the intake manifold and is situated facing downwards. If you're talking about the sump drain plug, it will be situated at the lowest part of the sump. If you have the 4JX1 engine there are two oil filters, one of them is for the engine lubrication system and the other is for the oil rail lubrication and activation system. The latter is the larger of the two and is located between pistons two and three about half way down the side of the block on the same side as the intake manifold. If you have the 4JX1 engine the type of oil you use is critical in maintaining trouble free motoring, check and use only the oil type stipulated.
Regards Johngee10
Mar 03, 2011 | Isuzu Trooper Cars & Trucks
Where can I download a parts manual and a operators manual for a Sullair CSF 30 compressor
Here is the home web site for Sullair.. http://www.sullair.com.au/service/service.php in Australia..
I would use the customer service info to make your inquiry.
Dec 22, 2010 | Garden
LOOKING FOR WIRING DIAGRAM FOR A SULLAIR 750DP ROTARY SCREW COMPRESSOR. MANUFACTURED IN 1982 FOR U.S.N.
I would contact Sullair factory, they have a great support group that I have contacted not as a Sullair distributor and the still provided me with the information I requested. have the model and serial number when you call them. there number is 1-888-775-1604
Feb 03, 2010 | Air Tools & Compressors
We have a Sullair 100 GPQ lubricant recommendation
hi mate ask the manufacturers as different compressor take different oils like im a compressed air engineer and i use rcr 32 and rcr 46 but i have never had to work on a sullair as there not common in our area
Jul 30, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
145 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
