I have a 400W Power Box. Part# 11-2016-6. The AC adaptor on the positive end of the box is broken. Is it possible to get replacement parts? Of course the warranty has expired.
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 98 Answers
Hi! Please refer to the following sites (just some examples):
1. http://m.canadiantire.ca/en/automotive/batteries-accessories/power-packs.html?count=16;i=1;m_ct_sort=sort-rating-desc;q=*;q1=Automotive;q2=Batteries+%26+Accessories;q3=Booster+and+Power+Packs;site=ct_mobile;viewMode=grid;x1=c.cat-level-1;x2=c.cat-level-2;x3=c.cat-level-3
2. http://www.canadiantire.ca/en/automotive/batteries-accessories/power-packs.html
Please be careful! If you cannot find the exact replacement parts you are looking for, you could still repair it yourself, but ONLY if you know what you are doing, otherwise it might get dangerous!
Hope this helps!
Posted on Dec 03, 2014
I HAVE AN AC ADAPTOR,… CLASS 2 TRANFORMER FOR OUTDOOR USE THAT NEEDS TO BE REPLACED.. MODEL: KMUA - 240 - 05000- 66UL INPUT: 120V - 60Hz 570mA OUTUT: 24V - 50VA
Amazon has it.
AC Power Adapter 120V input 24V 50W (50VA) output, UL listed
www.amazon.com › ... › AC Adapters
Mobile-friendly - AC 24V Power Adapter; 50W Output (50VA); 120V AC Input; UL Listed; Ivory Color item in OEM box ... 24V20AC 24V AC 20VA Transformer Input: AC 110V / 120V 60Hz Output: AC 24V 880mA
Dec 09, 2015 | Computers & Internet
My hp pavilion dv6-2117ax laptop won't power up (no power light on where adaptor meets laptop). Replaced power adaptor / charger and laptop powered up and operated for a day and then next day woul
The laptop probably isn't charging. Could be a bad d/c connector on the laptop or the battery is bad. Remove the battery and plug in the a/c adapter and see if it powers on. Wiggle the a/c plug in gently while pressing the power button on the laptop. It powers on and off briefly then I'd say it's the d/c jack on the laptop, bad sodder joint.
Dec 04, 2012 | Computers & Internet
Lenovo laptop(8932) will go into a sleep like mode (you can still see the screen, very dim) when plugged into ac adaptor. Doesn't do it with battery power. Changed system board, power adaptor - no...
Good Day Psmith!
It looks like the AC adaptor is not making the right supply voltage needed for your laptop.
If you have a multi tester, you can test your ac adaptor to see if it has stable 20V voltage output supply needed for the laptop to make it work.
Set your tester to DC range. Plug the ac adaptor to your wall socket. Hold the other end of the ac adaptor (the one you connect to your laptop. Insert the red (positive) lead into the center of the adapter pin, then touch the black (negative) lead to the outside metal part of the pin.
Read the display in your tester. If the adapter is working properly, the meter should read between 19 to 20 volts of the rating. If the adapter is faulty, the meter will read below 18volts.
If that would be the case, I'm afraid you will need to replace your ac adaptor.
You can purchase online a replacement ac adaptor for lenovo 8932.
1. From this site, it costs $34.99 + $8 https://www.ebuybatteries.com/product/models/2_IBM-Lenovo-AC090W008T15_IBM+Lenovo+ThinkPad+R61+8932.htm
2. From this site, it costs $39.95 http://www.eznsmart.com/p-31667-lenovo-thinkpad-r61i-8932-laptop-ac-adapter-replacement-20v-45a-90watt-charger.aspx
Please accept my answer if this is the information you need.
Don't forget to give a four thumbs up rating!
Thank you for asking Fixya.
Jun 23, 2011 | Computers & Internet
My ibm think pad t40 is not switching on
Hi
Assume you are trying this on battery and mains?
1st thing is to check if the AC power adaptor is giving out any power, which you can do by obtaining a multimeter and setting it to 50 volts DC. Place the positive probe in the centre of the adaptor plug and the negative against the outside of the adaptor plug and see if you get a reading. this will confirm that there is power getting to the laptop
(NOTE: THIS IS TO BE TAKEN FROM THE DC END of the power adaptor NOT from where the kettle lead AC source enters the adaptor.. if in doubt, get someone who is competent with using a meter)
2nd, is to check that the power button is not sticking and that the small plastic pin between the laptop body and the screen ( I think these have one) is not stuck, preventing it booting
3rd, If you are getting power by AC to the laptop, check the condition of the DC jack socket, if it is loose, appears to spark whrn the jack is plugged in or crackles, this will need replacing
4th, If the above do not work, it is possible that the main fuse in the laptop has gone...specialist repairers job.
Dec 28, 2010 | IBM Computers & Internet
My ac adaptors light is orange and my x-box is not coming on
Send it back to microsoft the Motherboard is broken mate.
xbox.com/support
Aug 22, 2009 | Microsoft Xbox 360 Console
Laptop does not work with AC adaptor, does not charge. Mother board issue
You may be able to get a battery charger but its rare.
If you do wish to use the AC adapter, take care with positive and negative. Also the voltage of the battery is actually lower than the AC adapter in order to get charged. I don't know what is going to happen if you do choose to use AC adapter as battery. 75% chance that it will work.
Oct 08, 2008 | Dell Inspiron E1705 Notebook
Lightning strike ac adaptor is fried
Your phone did expirence a surge that probably blew the ac adaptor which happens most of the time, u can buy one of those universal adaptors and look on the back of the old adaptor for the output voltage it will usually read between 3 and 8 volts DC.Set the universal adAptor voltage to the setting right below the voltage output on the back of the ac adaptor.
Aug 04, 2008 | Uniden Cordless phone EXS9950
Compaq Armada 7400 AC Adaptor Pins
Below is the URL for compaq's Service Manual for that model. This shows you the details of every single part & how to disassemble and reassemble every screw. Surely it has to be in this document, somewhere. --> ftp://ftp.compaq.com/pub/supportinformation/forum/portables/7400msg.pdf
Aug 04, 2007 | Compaq Armada 7400 Notebook
Computers & Internet Logo
122 people viewed this question
David Payne
David Payne
