Question about Vizio VA26LHDTV10T 26" 720p LCD HDTV
How to connect bluetooth device
I HAVE TRIED ALL RED AND WHITE CONNECTORS.
    Top Expert:
  • Vizio Master
  • 74,887 Answers
Contact any service technician to seek help.
Posted on Dec 04, 2014
How do I sync my replacement ear piece
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone, PC or other device for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
1 Turn on the Bluetooth feature on your phone.
2 Turn the earpiece on. Press and hold the call control button until the indicator flashes red/white.
3 Use the commands on your other device to locate and select your earpiece. 9xx Plantronics.
4 If prompted for the PIN code or Passkey, enter 0000.
Pairing is successful when the indicator on your earpiece flashes white.
Note If your phone supports Secure Simple Pairing (SSP), you will not need to enter a PIN code or Passkey.
Good luck from Headsets Direct!
Dec 08, 2010 | Plantronics CS70 Wireless Headset
Hello I am trying to install a new headset to my CS70 desk phone. The ruber earpiece on mine broke. How can I pair the new earpiece?.
Oct 14, 2010 | Plantronics CS70 Wireless Headset
How to connect plantronics 330 bluetooth headset with my iphone 4
When joining (or pairing) a Plantronics bluetooth headset to another device a lot depends on the other device. Assuming that you know the necessary steps of your phone or PC for connecting a bluetooth device, all Plantronics headsets pretty much follow a set pairing procedure for connectivity. This one is for the Discovery 975:
3 Use the commands on your phone to locate and select your earpiece. 9xx Plantronics.
Jul 20, 2010 | Plantronics Explorer 330 Headset
Just bought the brookstone wireless tv headphones. I have a Westinghouse 40 inch lcd tv. I plugged in the rca red/white into the audio out and I don't get any sound into the headphones?
I had the same problem with Brookstone wireless headset the only solution I found was plug in the red and white connectors to your cable box it works perfectly that way. Just make sure the red cable connector from the transmitter is connected to right red input connector on the box. I have a Comcast cable box. Now I need a solution for them on my PS3?
May 09, 2010 | Brookstone Surround Sound Earbuds...
How to connect my Nokia E71 with Plantronics 330?
Mar 22, 2010 | Plantronics Explorer 330 Headset
I am trying to pair my Plantronics Explorer 330 headset to my new phone, an HTC Eris. the phone does not recognize the device. Do you have any ideas?
Dec 21, 2009 | Plantronics Explorer 330 Headset
How do i connect plantronics 330 to my new phone? i have the bluetooth connection on on my phone but it doesn't seem to read it. Its a Sony Ericson W980
Jul 14, 2009 | Plantronics Explorer 330 Headset
Ibm t43 laptop's bluetooth cannot find devices
This sounds like it is exactly what I scratched my head about when I first inhereted my T43 at work. If it is, you are going to laugh at how simple it issue is. IBM in their great wisdom made a custom control for the wireless network antenna and bluetooth antenna. Try:
Hit Fn+F5. This will bring up a window where you can control turning on/off each antenna. When you turn on the bluetooth, the symbol in the system tray should turn to blue and white and the little green bluetooth light just below the screen should come on. I hope this helps.
Mar 02, 2009 | IBM ThinkPad T43 Notebook
How to use bluetooth in aspire 5600awlmi Hello. I also have a Acer Aspire 5600 and I can see the bluetooth sign on the tools bar at the bottom of the screen, but when I click it it says: "bluetooth device...
Does the acer 5600awlmi have a bluetooth device installed?
Do you have a switch at the front to switch bluetooth on/off?
Check by opening back were the harddrive is also located.
If no card with 4 wires on white 8-pin socket is installed, you don't have a bluetooth device.
Also check the connector!
However it is possible to put one in yourself.
I have a 5601awlmi and mine has no bluetooth device installed.
On e-bay you can buy an bluetooth card for approx. €20 in germany.
On the back side open the casing were the harddrive is located.
(front left)
There you see a 8-pin white socket.
Connect the card to the socket and boot.
Next install the bluetooth drivers from acer website if neccessary.
I hope this answers your question.
Greetz. T.J.
Dec 07, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Black and White Only
I had a similar problem when I first connected my son's xbox using the Audio/Video cable (red, white, & yellow connectors). I connected the cable to the TV correctly, but incorrectly selected "component" as the input on the TV setup. Result was black and white display. Switch your TV input mode to "AV" or "Audio/Video" and you will get color.
FYI, "component" TV mode is only used with devices that use the red, green, & blue connectors.
Jan 30, 2008 | Microsoft Xbox Console
Vizio VA26LHDTV10T 26" 720p LCD HDTV Logo
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
