Question about Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range
Stopping cold air
There is cold air coming up from the exhaust grill on my Jenn Air range and cook top.
  • Anonymous Jan 03, 2008
    Oven is not on..cold air is pouring out of the vents. My kitchen is cold! The oven is built in around brick. Help!
You will need to put a damper in your exhaust vent line. depending on how the exhaust vent is terminated, there are vent caps with dampers built in.
Posted on Jan 10, 2008
  • 146 Answers
Depending on where it is vented you probably wont be able to stop the air. Take the grill out and see if there is a door flap that is supposed to close when the fan is off. If not your out of luck.
Posted on Dec 21, 2007
Cooling fan below range top goes on and stays on even when oven is off
That sure cools...
Jenn Air Oven SVD48600B continuous fan - ApplianceBlog
Dec 10, 2007 - 10 posts - ‎4 authors Turned the oven on to 250, and the cooling fan (not exhaust fan, not convection ...What part number would this be for our Jenn Air SVD48600B range? ... It may only be that the fan comes on and stays on when not needed. ... Caveat: the same thermometer says my Jenn-Air wall oven is also 50* below the ... Jenn-air JDS9860AAP Oven won't turn on - ApplianceBlog
Mar 24, 2013
Jenn-Air SVE47600 Downdraft Fan Not Working
Nov 30, 2010
Jenn Air Oven SVE47500B oven light and fan stay on ...
Nov 20, 2010
More results from
Nov 21, 2015 | Jenn-Air Kitchen Ranges
We have quite a bit of "COLD AIR" escaping from
Sorry to read about your problem, I hope this helps you out.
you can purchase a grill cover, or put tin foil over it..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 18, 2010 | Jenn-Air Cooktops
Does anyone make a cover to fit over the Grill exhaust vent. I get a lot of cold air coming up thru it and a cover would be nice.
Yes, we have the grill covers for your Jenn-Air range. Just contact us at: from 7 AM until 7 PM CST Monday through Saturday and we will get this out to you asap.
We look forward to working with you.
Thanks, Ella
Dec 11, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
My new home already has a hood vent for the range. I have a gas Jenn air downdraft range. I prefer to use the hood vent as the downdraft is not very efficient. Do I have to connect the blower on my range...
The poupose of either is to eliminate any smoke created by the range or grille and move as much of the cooking odors to the outside. I wouldn't use both at the same time, but if the hood is vented to the outside, it would be just fine to use only the hood. Aregular cleaning will be necesssary. The downdraft has limits as to the distance it will efficiently exhaust air. Flex hose should not be used. And excessive bends or vent length, cuts into the efficiency.
Oct 29, 2009 | Jenn-Air JED8230 Electric Cooktop
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Outside cold coming in thru downdraft exhaust vent
some times the wall nest to the vent when is wendy, it force the air in side, i recommend to replace the vent position out side.
Dec 08, 2008 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air element won't shut off
most likely its a faulty switch, not completly shutting down trickling power out.
Mar 15, 2008 | Cooktops
Jenn Air Not Exhausting During Grilling
is this down draft cook top or give me the m# thanks
Jan 13, 2008 | Jenn-Air JED8230 Electric Cooktop
Cook top exhaust
no. jenn-air never has had a good vent. they have always been weak. im sorry theres nothing you can do
Nov 26, 2007 | Jenn-Air JED8230 Electric Cooktop
Installation of down-draft exhaust duct for Jenn-Aire cook top
We're buying a JES9900BAF for an island and found ducting instructions in the installation guide. Go to and find the page for your range model. Then click on the "Specs/Literature" tab (it's about 2/3 down the page). The installation guide is a PDF document.
Nov 07, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Jenn-Air JDR8895AAS Dual Fuel (Electric and Gas) Kitchen Range Logo
261 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
