Question about Craftsman Garden
I have a Craftsman DLT 3000 that continually runs on high. Starts fine and blades engage properly. Tried adjusting the throttle but it continues to run on a very high speed. Any ideas? Started doi
Adjusting the throttle to lowest setting but it continues to run fast no matter what the setting.
    Master:
  • 373 Answers
Ensure the throttle Cale is actuating the throttle lever on the carberator. If so, then the trouble is in the carb itself.
Posted on Dec 03, 2014
Craftsman DLT 2000 with Briggs and Stratton 25 HP. Engine runs at wide open throttle.
What is the float set at? What about the jets and fuel screw? Do you know what the fuel pressure is?
Aug 26, 2016 | Craftsman Garden
Craftsman dlt 3000
You need a new alternator...Alternators regulate current to the battery to keep it charged.
May 19, 2013 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Idle rolling
are you talkin aboutit surgin up and downat high idel thats normal when you engage the blades it levels out under load
Oct 26, 2012 | Craftsman Garden
HOW TO ADJUST CARB. ON CRAFTSMAN 21 cc BUSHWACKER HEDGE TRIMMER
Does the unit have jet screws marked H and L? Turn (both) CW to stops (lightly), then turn each CCW 1-1/2 turns. This is a basic setting that should allow the engine to start and run. Make sure the fuel filter, air cleaner, and muffler are not plugged. Start the engine and allow to warm up, pull the throttle full on and adjust H needle CW until the engine starts to speed up, but continues to 4-stroke. Proper adjustment is when the engine 4-strokes unloaded, but immediately 2-strokes when trimming. Allow to idle and adjust the L needle CW for better idle, but allows the engine to 'follow the throttle'. Adjust the idle speed screw so that the engine continues to run, but doesn't run the cutter bar. Hope this helps!
Aug 12, 2010 | Garden
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Murray 22in throttle-free push mower
Throttle cable probably needs adjustment. If not adjusted properly it wont go to the shut off position. There is a clamp that should be on side of the engine, loosen the screw on the clamp, then move the cable-try pushing it forward or backward, but not more than 1/4 inch at a time, tighten after each adjustment. Engine is shut off while adjusting, once tightened crank the mower and see if that improves it. You will just have to try each direction until you find which way it needs to go.
Sep 10, 2009 | Oregon Scientific Gator Mulcher 3-N-1...
Garden Logo
113 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
